02-17-2013, 06:58 AM
#1 |
Oddometer: 2,458
Loose front end? How to troubleshoot?
Hi, all,
on my '09 R1200GS, I feel a distinct "click" in the front, when rocking the bike back-and-forth, with the front brake applied. What is the best method of determining where the lash exists? I was rocking the bike while holding my fingers by the steering head bearings, but felt no movement. Neither, when touching the ball-joint on the Telelever swing arm. Also, I jacked up the engine to lift the front and tugged on the wheel - needles to say, felt no movement, either. Is this a valid test? How to approach the diagnostics? What else could be loose beyond head bearings and the ball joint? TIA. Robert.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT -->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour -->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour rdwalker screwed with this post 02-17-2013 at 07:04 AM |
02-17-2013, 07:18 AM
#2 | |
Oddometer: 2,289
10Cup - WR250R - BMW R1200GS Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker SpearMotorSports, Inc. The cost of living's going up, and the chance of livin's going down. |
02-17-2013, 09:02 AM
#3 | |
Oddometer: 2,458
I am used to the round-button style rotor mounts on my '06 GS and all my older K and R bikes; that explains why I did not feel the "click" on those bikes. The '09 is my first one with the rubber-suspended rotors. Thanks.
Robert in Northern NJ __ '09 R12GS, '03 R1150RT -->> James Bay & North Road Solo Blitz -->> Patagonia / Tierra del Fuego Cappuccino Tour -->> Trans-Labrador Highway Solo Blitz --->> South African Cappuccino Tour |
#4 |
"Cool" Aid!
Oddometer: 41,921
Hi Robert,
As mentioned, it could just be your rotors moving. I would take a torque wrench to all the bolts on your front end, skip the ball joint, and make sure they are all tight. Also, check your caliper bolts as well. Jim
02-17-2013, 09:19 AM
#5 | |
Oddometer: 2,458
Personally, of course, I like the theory of the rubber-cushioned rotor buttons the best. ![]() Regards, Robert.
02-17-2013, 12:45 PM
#6 |
"Cool" Aid!
Oddometer: 41,921
The fork tube clamp bolts are an old, but very valid issue that I have no heard in a while. Seems they would loosen up and the forks would twist.
Jim
02-17-2013, 04:16 PM
#7 |
Oddometer: 2,494
I have the same click. Checked the front end. Found the bar mounts loose tighten them still didn't go away.
Time to do some more checking.
Bigger Better Faster More----4 non blondes Feel the Power of the Wheel |
