Old 02-17-2013, 07:24 AM   #1
gspdbill OP
noobie allover again
Oddometer: 404
Removing registration decals from forks
I don't think there's a bike cleaning forum on here so I'll ask it here.
New to me GS has the registration stickers on the forks, TN doesn't do stickers. What's the best way to remove those stickers? I've spent about 5 min. on them and gotten no where. What's the trick? Heat? Solvent?
Maybe I should post this in the HD forum....
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 02-17-2013, 07:30 AM   #2
LaurelPerryOnLand
Oddometer: 3,482
Removing depends on the backing material...
While removing some ALUMINUM foil backed non-skid black material (sand like) from a LIFT I purchased over the weekend:
Option 1.
Tried a HEAT GUN and heated up one of the non-skid strips. The underlying adhesive partially melted and I was able to remove the strip. Left a residual quantity of 'adhesive'...NOT really removable with Goo-Gone, gasoline, or even a wire brush!
Option 2.
With a HEAT GUN...lifted just a corner of another strip...and then forcefully TUGGED at the strip to remove it. The entire strip released along with ALL of the adhesive on the back. There was NO residual adhesive left.
Note: Do not HEAT the entire strip...heat just enough so that you can get a hold of something to TUG with.
I had to cut the original strip into manageable size strips...6" wide...to be able to TUG to remove it. Any bigger...it would have been impossible.
Recommendation:
If you have ALUMINUM foil backed graphics/surfaces that you want to remove...try the TUG method.
If you have NON-ALUMINUM backed graphics/surface...the HEAT GUN/Goo-Gone might work better.
LaurelPerryOnLand screwed with this post 02-17-2013 at 09:02 AM
LaurelPerryOnLand is offline   Reply With Quote
Old 02-17-2013, 08:59 AM   #3
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,052
Ya, I have the adhesive on my fork and nothing seems to touch it.
Not sure what the states that do this are thinking with regards to adhesive but it sucks.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 02-17-2013, 09:09 AM   #4
gspdbill OP
Oddometer: 404
Originally Posted by LaurelPerryOnLand View Post
Option 2.
That's not really an option with the state decals though, those things are designed to tear up if someone trys to steal them for another vehicle. I already tried scraping/pulling on them, they came off in pieces the size of a pencil lead.... would take a lt of effort to remove the whole thing that way.
Bill
Old 02-17-2013, 09:58 AM   #5
srpuywa
Big 'G'
srpuywa's Avatar
Oddometer: 490
try a scotch bright pad and glue remover
IBA 53683
2015 R1200 RT
srpuywa is offline   Reply With Quote
Old 02-17-2013, 10:02 AM   #6
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,567
Found a bunch of answers on Google. Plastic razor blades came up. Lighter fluid goo gone WD40 and heat.
scooteraug02 is offline   Reply With Quote
Old 02-17-2013, 03:01 PM   #7
gspdbill OP
Oddometer: 404
Never heard of plastic razor blades, thanks. I've been using plastic putty knifes, left a little bit to be desired.
Bill
Old 02-17-2013, 03:15 PM   #8
Delta61
Delta61's Avatar
Oddometer: 260
decal and adhesive remover
Best stuff i have ever used is aircraft decal and adheseve remover. Get it at autozone for sure but have seen it at other auto parts stores
"Keep the Greasy Side Down"
10 1200 GSA
07 X Challenge
04 1150 GS(SOLD)
Delta61 is offline   Reply With Quote
Old 02-17-2013, 03:41 PM   #9
Boondox
Travels With Barley
Boondox's Avatar
Oddometer: 3,061
As luck would have it, I just finished removing the residue of mine. The dealer had applied it over the previous year's sticker and it never adhered very well, though the 2011 sticker sure did!
I used the heat gun to get the plastic off, then removed the residue with what I had on hand: Nev R Dul. Five minutes of very gentle rubbing removed every trace.
I got a sidecar to travel with my dog. He never complains, is delighted to be with me, approves of my dietary choices, is a social butterfly who helps me meet folks, appreciates a good beer, snuggles better than my wife, and hangs on my every word as if it's the most profound thing he's ever heard. TravelsWithBarley.com
Boondox is offline   Reply With Quote
Old 02-17-2013, 04:06 PM   #10
GrouchyGeezer
GrouchyGeezer's Avatar
Oddometer: 971
To Stick or Not To Stick
In my semi-retirement job I often have to remove stickers and such. I usually do it in steps: 1) Alcohol. If that doesn't work. 2) WD40. If that doesn't work. 3) Lacquer thinner. If that doesn't work. 4) Industrial Graffiti Remover. If that doesn't work. 5) Very Hot Soapy Water and scraping with an old credit card.
I've never had to use a heat gun. Most of the things I'm removing stickers from are a bit delicate and wouldn't stand up to a heat gun. Hey, if it was easy to do they wouldn't call me!
BTW, be careful with items 3 and 4. They might damage the product.
Happy ungluing.
GrouchyGeezer is online now   Reply With Quote
Old 02-17-2013, 04:40 PM   #11
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,520
Once you get them off, if you need to put more on, try this:
Jim
Old 02-17-2013, 04:58 PM   #12
Izzy3
Freak of Unnature
Izzy3's Avatar
Oddometer: 230
Jim
My dealer did the "sticker tag" and I didn't even need to ask. Thank goodness for Morton's in Freddieburg.
'12 R1200 GSA
Izzy3 is offline   Reply With Quote
Old 02-17-2013, 05:04 PM   #13
NoVa Rider
Oddometer: 2,960
Morton's just slapped mine on. . ..
Guess I looked like a fork guy.
NoVa Rider is online now   Reply With Quote
Old 02-17-2013, 05:58 PM   #14
The Evil Twin
Boxer Freak
The Evil Twin's Avatar
Oddometer: 474
The plastic blade works well on delicate surfaces but you still must be careful. So far as the adhesive, I found that Motul Wash n Wax cuts through most gunk. I have also used ATF to remove the sticky foam that wheel weights leave behind. The ATF has a lot of detergents and is petrol based. After the adhesive is removed the area can be washed with soap and water.
CCS #132 Sponsors: DC-Moto.net, Amsoil, Manassas Honda Kawasaki, MARRC
2014 RCGT #1, Superbike #2 OA Mid Atlantic
2013 Amateur of the Year
2013 RCGT #6 OA Mid Atlantic
The Evil Twin is offline   Reply With Quote
Old 02-17-2013, 06:59 PM   #15
Skyhawk
Ex Navy Jet Jockey
Skyhawk's Avatar
Oddometer: 1
Decals
Morton's put the decal plates on my bikes, too. Had to pay a few bucks, though. Maybe they're free for new bikes purchased there.
Skyhawk is offline   Reply With Quote
Times are GMT -7.   It's 07:08 AM.
