Old 05-23-2011, 12:15 AM   #1
Rajaviento OP
Ride with the wind..
Rajaviento's Avatar
Oddometer: 7
gs1200 / change abs brakes for standard anybody?
I have a gs1200 / 2006 with abs/servo assisted and i would like to exchange it for a regular ''japanese'' system, anybody has knowledge on how to proceed?
Emilio
Rajaviento is offline   Reply With Quote
Old 05-23-2011, 06:05 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,379
Do a search over on G-Spot. It has been done, and the process fairly well laid out.
Jim
Old 05-23-2011, 11:30 AM   #3
Apxgrndr
In the snow
Apxgrndr's Avatar
Oddometer: 999
Can I ask why you want to switch ? I took the GS out and really tried the brakes out for the first time a couple of nights ago. I couldn't believe how well the abs works.
I've always been dubious about abs on a motorcycle but not anymore, especially threshold braking with that pea gravel on the road.
You're stronger than you think.
Apxgrndr is offline   Reply With Quote
Old 05-24-2011, 11:02 PM   #4
Rajaviento OP
Rajaviento's Avatar
Oddometer: 7
because,,,,
The brakes are servo assisted and do not work well with engine off,,, problem when dirt riding
Old 05-25-2011, 05:50 AM   #5
JimVonBaden
"Cool" Aid!
Oddometer: 52,379
You ride in the dirt with the engine off???
Jim
Old 05-25-2011, 05:55 AM   #6
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,834
Don't turn off the key and wheel into the garage.
Don't do that. Don't ask me why........
DELTATANGO is offline   Reply With Quote
Old 05-25-2011, 08:20 AM   #7
MJS
MJS's Avatar
Oddometer: 1,889
I've done mine
I'll try to answer any questions
http://www.advrider.com/forums/showt...=343508&page=2
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 05-25-2011, 09:17 AM   #8
Rajaviento OP
Rajaviento's Avatar
Oddometer: 7
down hill
When rolling down a very steep downhill..... is good practice to turn off the engine and use the clutch as a rear brake (with the bike in first gear). Simply
Old 05-25-2011, 02:41 PM   #9
JimVonBaden
"Cool" Aid!
Oddometer: 52,379
Maybe I am missing something, but why not use the brake? Using the clutch is hard on the clutch, and if you suddenly find you need power you are SOL!
Jim
Old 05-26-2011, 12:55 AM   #10
mazinger
mazinger's Avatar
Oddometer: 87
Emilio is right if you are really doing hard offroad.
Sometimes, when you are descending a really steep hill, with lots of loose stones and gravel, best way to assure your stability and not to fall and roll down is to put both feet on the ground; the problem is that you need to break and your right foot is touching ground, avoiding you to fall rightwards. In this situation is very helpful to stop the engine and use the clutch as a rear break, while using also the front lever with care...
Besides there has been some reported crashed caused by the electric breakes failuring for lack of voltage. In fact I think this system was a failed experiment by BMW because they never used it again (later series were manufactured with standard hydraulic system). Also the electric brakes are very rude at low speeds...
In my experience I had to ride thru more than 2500 kms in Bolivia and Chile without the electric powered brakes due to a failure in the lever contacts, and believe me it is hard (and long) to break without the assistance...
Rgds
Miguel
(mine is a '04 GS12)
mazinger is offline   Reply With Quote
Old 05-26-2011, 06:05 AM   #11
JimVonBaden
"Cool" Aid!
Oddometer: 52,379
Miguel,
Seems like an extreme situation, and to be honest I would probably not have used a GS for that, but if I did I would not have a servo-GS just for that reason. But if I did, I would have carried a couple standard connectors and converted my dead servo-ABS to standard brakes.
At any rate, for 99.9% of the people on a GS riding with the motor off is a non-issue.
Jim
Old 02-18-2013, 07:50 AM   #12
ONandOFF
-ROAD-
ONandOFF's Avatar
Oddometer: 6,297
Right on. Personally I would consider that an emergency situation - one to take every effort to avoid!
Let's ride!!! - No offense, but there've been a lot of people over time who were just as sure, yet got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. - "you know that I could have me a million more friends and all I'd have to lose is my point of view" (Prine)
ONandOFF is online now   Reply With Quote
Old 02-18-2013, 11:46 AM   #13
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,585
Originally Posted by MJS View Post
You made it difficult for yourself.
Just unscrew the small electrical unit from servo (4 screws) and leave it plugged into the loom. Remove the rest of servo and dispose of
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 02-18-2013, 11:53 AM   #14
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,825
I find that riding is enhanced with the motor running.
Servo brakes are weird voodoo..
" You need a new sig line."- H14
"I despise you and want my refrigerator magnet back!" - VB Divers ex-girlfriend
bloochdog is offline   Reply With Quote
Old 02-18-2013, 03:12 PM   #15
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,385
quit making me laugh out loud in the middle of a room filled with solemn people not interested in fun or laughter.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Times are GMT -7.   It's 07:20 PM.
