Old 02-26-2013, 11:56 AM   #121
supershaft
because I can
Oddometer: 9,116
What alloy are the aluminum pushrods Dirk?
Old 02-27-2013, 02:37 PM   #122
pommie john
pommie john's Avatar
Oddometer: 1,467
The pushrods are in the shop now.
395 Euros a set.
I'll have to save up for them
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 02-27-2013, 02:48 PM   #123
supershaft
because I can
Oddometer: 9,116
395 Euros a set.
395 euros! I just looked and didn't see any pictures or info?
I am going to call up my supplier of 4130 rods and see if I can get them just a bit thinner walled. If you or anyone else is interested, the cost is way, way less than 395 Euros. I am going to be ordering some soon.
Old 02-27-2013, 03:10 PM   #124
pommie john
Oddometer: 1,467
They are in the shop, not on the site itself. You have to go to the webshop
Bertrand Russell
Old 02-27-2013, 03:46 PM   #125
supershaft
because I can
Oddometer: 9,116
Thanks pj. My German is pretty rough but I didn't see any alloy numbers. I need to know what specific alloy they are made out of before I would buy any but they are too rich for my blood anyway. For that kind of money I would rather fry bigger fish.
Old 02-27-2013, 03:51 PM   #126
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,544
you could have a machinist make a one off set for 400 euros. That's about $520. Start looking up tapered aluminum tube. He did say they were tubular right? Or just get a thick walled tube and taper down the OD toward the ends. I'd look at something like 7075-T6. I'd go as wide of an OD as absolutely possible in the center of the rod and taper down at the ends. That's how to make it as stiff as possible. You could pull the ends out of existing pushrods for the sake of simplicity or go to the trouble of making your own shorter tips if you're bent on minimizing weight.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler screwed with this post 02-27-2013 at 04:05 PM
Old 02-27-2013, 05:37 PM   #127
supershaft
because I can
Oddometer: 9,116
My guy makes tapered rods for WAY less than that. I think about $35 US each. I would think aluminum rods would have to be solid to be rigid enough? My guy will not make them out of aluminum for anybody period. He says they can't be made to not flex but, like I said, I think he is talking about way more spring pressure than I run. I run stock springs. Another thing I like about 336's! Dirk said up above that the stock tips break with more rigid rods. That does not surprise me since I would suspect so. Stock tips are out. Warning: Lots of places over here do not have the proper metric tip and fudge on a real close American sized tip including a US Pushrod manufacturer with a lot of airhead history. That might be PART of the story of why I have seen those particular pushrods bore through the top of a lifter within a 100 miles.
supershaft screwed with this post 02-27-2013 at 05:58 PM
Old 03-06-2013, 06:46 AM   #128
Sabre170 OP
Sabre170's Avatar
Oddometer: 282
So, I wanted to follow up with what I ended up doing. After all of your suggestions, which I greatly appreciate, I did like the looks of the EMGO shorty's, and to top it all off, they are dirt cheap. I got them off Dennis Kirk for under $30 each. For that price, I took the gamble. I figured that worse case, I'd be out $60.
I wasn't disappointed. Obviously, being a slip on, super easy to install. The hardest part was removing the old pipes. The short low profile gave it the clean look I wanted, and the sound was great. It has a much more "throaty" sound to it. It sounds fantastic.
These mufflers come with baffles that can be removed by taking out one bolt. As of now, I still have the baffles left in. I may take them out someday just to see how it sounds, however, even with them in, the bike is pretty damn loud.....I think I may be pissing some neighbors off :-P
Anyways, I took before and after videos and posted on YouTube. So many people post after videos of their exhaust, but no before videos. This never let's viewers see/hear the difference. I shot both of these videos with the same camera (iPhone 4S), in the same location and only a few minutes apart.
Before: http://youtu.be/ScWOLLoelmw
After: http://youtu.be/EKPKVu3hUqI
Sabre170 is offline   Reply With Quote
Old 03-06-2013, 10:13 AM   #129
BeardThrone
...in bat country.
Oddometer: 120
What is this, a comment related to the original post? Oh well, since it is your thread do with it what you will.
On a side note those shorties sound great!
BeardThrone is offline   Reply With Quote
Old 03-06-2013, 10:21 AM   #130
Sabre170 OP
Sabre170's Avatar
Oddometer: 282
Hahaha!
Yeah, it was a reply to my first posted question. I figured I'd post that so that if there was anyone in a similar boat as I, my "solution" could be viewed.
Old 03-06-2013, 04:40 PM   #131
igormortis
igormortis's Avatar
Oddometer: 1,371
I'm gonna openly presume that a lot of work went into those pushrods. I would not expect Dirk to give anyone the info for their guy down the road to make some up.
Then again, Dirk's generous nature so far might prove that he'll share. But I'd trust a 395 euro investment at 10,000 rpm over some guy's best guess.
igormortis is offline   Reply With Quote
Old 03-06-2013, 04:59 PM   #132
supershaft
because I can
Oddometer: 9,116
I recently shopped all over for pushrods. Here in America at least, all the manufacturers tell you what specific alloy they are made out of. Reminds me of American cam manufacturers giving specs with a lift check point. Anyway, my "some guy" is a major performance pushrod manufacturer. That company and another American company have recently 'reinvented' the pushrod all for one of them coming up with a way to film them in action. Much to everyone's surprise, they were flexing like a mofo. Since that discovery not that long ago, the big money pushrod tuners (NASCAR and NHRA) have doubled and tripled pushrod mass for rigidity and more power.
Old 03-06-2013, 05:34 PM   #133
Airhead Wrangler
Adios Mexico
Oddometer: 6,544
The way I see it, the notion of a "ROD" is barking up the wrong tree. A tube of wider diameter is a better use of the same amount of material and would create much stiffer push rod that would flex less. A solid rod in compression is just an inefficient use of material. If reducing flex and minimizing weight are two important goals, then a wider OD tube seems like an obvious choice to me. It may be necessary to make wider pushrod tubes to meet this objective, but that wouldn't be too tough.
Old 03-06-2013, 06:03 PM   #134
supershaft
because I can
Oddometer: 9,116
I don't know about aluminum rods but every steel rod that I have ever seen is a tube. They still call them pushrods instead of pushtubes.
Old 03-07-2013, 04:02 PM   #135
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,509
I have run these chromeoly pushrods before. They are under $100 for 2 bikes worth https://www.wolfgangint.com/store/pr...uncut-1109302/
but at the end of the day unless your turning 7500 plus RPM's stock works fine.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 07:04 AM.
