02-18-2013, 01:44 PM
#1 |
Type-A Introvert
Oddometer: 302
R1150GS / OEM bars - Oil Change?
I just picked up a clean '02 R1150GS with what I think are the factory crashbars. They might be the ADV bars?
Anywho..... Looking at an oil change, there's mounting tabs on the bottom of the bars with a 'strap' for lack of a better description. That strap and tabs are external to the skid plate, but use the same mounting holes. Looking at this to get the skid plate off, you have to get the bars off, but there's a top bolt behind the gas tank on both sides. Do these bars pivot at the top bolt on the engine when the bottom ones are removed? If not, it's looking like the gas tank has to come up to get to the top bolt? Or is there just some simple trick to getting the skid plate out of the way with these? Can anyone shed some light on this one? Topside ![]() Bottom side ![]() . M38A1 screwed with this post 02-18-2013 at 01:54 PM |
02-18-2013, 02:33 PM
#2 |
Yinz, blinkers are on.
Oddometer: 9,976
Naw your pretty much F-cked
Why no one bought the OEM bars You might be able to get just enough play and pull the pan straight forward after undoing the cross piece. without undoing the top bolts What alot of guys did. Drill out two holes in pan. 1 for drain plug 1 for oil filter Good Luck
If your looking for me. I will be at Rella's eating Blackberry pie. http://advrider.com/forums/showthread.php?t=791094 http://www.youtube.com/watch?v=_ampAFmwP_E gsweave screwed with this post 02-18-2013 at 02:40 PM |
02-18-2013, 03:07 PM
#3 |
Type-A Introvert
Oddometer: 302
If these aren't BMW bars, who's bars are they?
This sucks... Unless those top bolts behind the tank allow it to pivot?
02-18-2013, 03:10 PM
#4 | |
Oddometer: 9,976
BMW OEM. Get your hole saw out. Don't let it ruin your day
If your looking for me. I will be at Rella's eating Blackberry pie. http://advrider.com/forums/showthread.php?t=791094 http://www.youtube.com/watch?v=_ampAFmwP_E |
02-18-2013, 03:19 PM
#5 |
Type-A Introvert
Oddometer: 302
Isn't there two plates that make up the skid plate set?
02-18-2013, 04:30 PM
#6 |
Type-A Introvert
Oddometer: 302
After a bit of searching, I think this answers the question on the oil change....
http://advrider.com/forums/showthrea...ill+skid+plate . |
