02-18-2013, 07:09 PM
#1 |
Oddometer: 32
How to seal threads on emblem screws
Hi,
I'm going to be modifying my BMW K75 tank to accept /5 tank emblems using screws rather than adhesive. This means drilling and tapping the aluminum. Will I need to use a sealant (such as Locktite 242 or RTV) to seal the threads when installing the badges, so that there is no possibility of fuel leakage later? Or is the rubber gasket between the badge and tank sufficient to stop leakage? I had also contemplated using slightly longer screws with flanged nuts on the inside of the tank. Bad idea? BTW, posting in this forum since it's more likely to have someone in the know read this than in another forum, like Road Warriors.
- Robert |
02-18-2013, 08:04 PM
#2 |
Wacky Bongo Boy
I have a hard time believing that this idea won't leak regardless of the sealant.
1974 BMW R75/6, 1974 BMW R90/6, 1969 BMW R60/2 hack, 1929 Ford Model A, Metal casting, Part 2/Part 1 among others.. |
02-19-2013, 12:34 AM
#3 |
Mad Scientist
Oddometer: 3,005
Weld in an aluminum nutsert. You could also cut the heads off of the screws, JB Weld them in place and use 3M double sided tape to hold the emblems on.
BOXER Metal BMW Biker Scum BMW Mad Scientist! VBMWMO #7770, BMW MOA #48694 & Airhead BMW Club #600 |
02-19-2013, 04:03 AM
#4 |
flyfishandride
Oddometer: 993
I second the "fake screw" idea. just glue the heads onto the emblems and use the tape to hold the emblem on, nobody gonna know!
02-19-2013, 05:45 AM
#5 |
More tacos than you
Oddometer: 5,201
I wouldn't penetrate the wall of the tank if I were you. That seems like a losing proposition no matter how you seal it up again. I'd have someone weld or braze a blind threaded insert into the wall of the tank and screw them into that.
EDIT: Considering the difficulty involved in doing the above, the 'fake screw' and adhesive method mentioned earlier is what I would do.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. Airhead Wrangler screwed with this post 02-19-2013 at 06:43 AM |
02-19-2013, 06:25 AM
#6 | ||
Confirmed Curmudgeon
Oddometer: 4,019
--Bill
'73 R60/5 Toaster |
02-19-2013, 07:25 AM
#7 |
Oddometer: 1,705
plus 1,000,000+!!!!!
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85 |
02-19-2013, 08:05 AM
#8 |
Oddometer: 1,068
Most folks here try and seal old tanks that have holes in them, here you want to go and make holes.............
Fake the screws, nobody will know, whereas if you drill the tank and it leaks it will show |
02-19-2013, 06:53 PM
#9 |
Oddometer: 32
Well, good I asked. I got consensus on faking the screws and using double-sided tape so that's the way I'll tackle this modification. Thanks to everyone who responded.
- Robert |
02-19-2013, 06:54 PM
#10 |
Still on 3 wheels
Oddometer: 3,470
Go ahead admit it...you want a /5
02-19-2013, 10:36 PM
#11 |
Oddometer: 740
If I recall, the K bikes have a double wall tanks. In any case, cut off the heads, and glue it on.
02-20-2013, 11:57 AM
#12 |
Mad Scientist
Oddometer: 3,005
Nope on the double walls.
02-21-2013, 12:16 AM
#13 |
Oddometer: 740
02-21-2013, 05:09 PM
#14 |
Oddometer: 32
Ya. Wouldn't mine in the least!!
- Robert |
