Old 02-18-2013, 10:17 PM   #1
BRUTSQD OP
Don't touch me.
BRUTSQD's Avatar
Oddometer: 119
Wheelies?
This may be a silly question.. But how does one go about clutching up a wheeling on a f800? The bikes I've had in the past I could pop the front end up off of torque. I don't know if being 250lbs is my problem but I've had a hell of a time getting my f800gs to bring the front end up. I'm not familiar with technique on clutching so I thought I'd put it up here to kick around.
-T
2012 F800gs farkaliscious triple black
Ireland http://advrider.com/forums/showthread.php?t=777499
CO back to CA http://advrider.com/forums/showthread.php?t=850524
"I never drive faster then I can see and besides that it's all in the reflexes." -JB
Old 02-18-2013, 11:06 PM   #2
motomuppet
Oddometer: 158
Heaps of throttle, dump the clutch. Sorted. Well, sort of.
Start with not quite heaps of throttle and not quite dumping the clutch but releasing it quick. Start small and build up. Always cover the rear brake.
On my T800XC I get to about 6000-7000rpm in first, chop the gas and dab the front brake while pulling the clutch in, and as the forks spring back up from the brake dab grab a handful of throttle and relase the clutch pretty much simultaneously and the front comes up quite quickly.
Be ready to shut the throttle and dab the rear brake if it comes up too fast.
motomuppet is offline   Reply With Quote
Old 02-21-2013, 07:49 AM   #3
Eddy Alvarez
Addicited to ALL bikes!
Eddy Alvarez's Avatar
Location: Chester,VA. Growing on me or getting used to it?
Oddometer: 1,714
It's all in revs and clutch. 99.99% of all streetbikes can do a nice wheelie! Buy a cheap, 200cc, four-stroke dirtbike and become very profiecient at riding l-o-n-g balance point wheelies (on grass) before even attempting your first power wheelie on your $10,000/470 pound GS.
Me: BMW F800GS/DRZ-400S, Gabriel: KTM 50 Senior Adventure!
Eddy Alvarez is offline   Reply With Quote
Old 02-21-2013, 07:55 AM   #4
ragtoplvr
Oddometer: 4,539
This. It has the power to come up very quickly, if you pass the balance point it WILL be expensive. Clutch is not needed, just run up to about 5 or 6 K in first, chop the throttle, let the front settle and gas it. You will be up in the air right away.
Rod
ragtoplvr is offline   Reply With Quote
Old 02-21-2013, 10:07 PM   #5
BRUTSQD OP
Don't touch me.
BRUTSQD's Avatar
Oddometer: 119
Wicked
All good info, thanks guys!
Old 02-22-2013, 08:07 AM   #6
biodieselandon
biodieselandon's Avatar
Oddometer: 292
So you are saying the F800 forks compress when you chop the throttle?.... Hmmm I haven't noticed that
Just don't do what I did in This Video. I decided not to try any crazy wheelies on my 800 until I have a cheaper bike to practice the balance point/rear brake stuff.
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is online now   Reply With Quote
Old 02-22-2013, 11:11 AM   #7
JSkinner
SeattleRider
JSkinner's Avatar
Oddometer: 29
X2 on chopping the throttle in first. Once you get good at it you can shift into 2nd and 3rd. I haven't made it out of 3rd yet and probably don't want to. You could drop down to a 15 tooth front sprocket and it will make things easier but you will lose your top speed (sucks on freeway)
09' F800GS
JSkinner is offline   Reply With Quote
Old 02-22-2013, 11:54 AM   #8
4TooMany
4TooMany's Avatar
Oddometer: 228
Yeah, and DON'T do THIS!
MSF RiderCoach
2012 BMW F800GS Trophy
2011 Suzuki DRZ-400S
4TooMany is offline   Reply With Quote
Old 02-22-2013, 01:48 PM   #9
biodieselandon
Oddometer: 292
I can't believe how far the bike kept going! That was pretty good.
Old 02-22-2013, 01:52 PM   #10
Bayner
Oddometer: 1,236
Must have had the luggage packed pretty evenly!
Bayner is offline   Reply With Quote
Old 02-22-2013, 05:57 PM   #11
Keithert
Oddometer: 159
My XT225 is supposed to be good at wheelies.
https://www.youtube.com/watch?v=ica2E4uk4fo
Keithert is online now   Reply With Quote
Old 02-23-2013, 07:41 AM   #12
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,203
Hmm, it's been a while since I've ridden an 800 but from what I remember the standard gas it, let off, and crack the throttle popped the front wheel right up. It's all in the timing, no clutch should be needed. Dumping the clutch is how you can get in trouble, like the video showed.
AviatorTroy is offline   Reply With Quote
Old 02-24-2013, 06:52 AM   #13
RobbieO
Muskokatard
RobbieO's Avatar
Oddometer: 3,846
Get it into 2nd gear and 1/2 pull in the clutch, give it some gas and release the clutch.........easy!
"Now this is the shit!" Drcool
I can no longer wheelie..
RobbieO is offline   Reply With Quote
Old 02-24-2013, 09:14 AM   #14
ixab
just Aaron, really
ixab's Avatar
Oddometer: 345
Send a message via Skype™ to ixab
I'd agree about the open-close-open the throttle technique. My F800GS will only wheelie like this in first, but it's easy and much less likely to go horribly wrong. Don't forget to cover the rear brake! That habit kept my 950A from going over backward a couple times. Same for my old Ducati, and my VFR, and my XR400, and ...
I have yet to learn to get a bike to the balance point, and I've also never managed to shift gears while doing a wheelie. I'm hoping eventually get that, but vowed to not practice new tricks on the big bike. I've thought about going to one of those 1 day wheelie schools, but never seem to get around to it.
Youtube - Death, Death, Everywhere!
ixab is offline   Reply With Quote
Old 03-10-2013, 07:57 PM   #15
sailer
trained Cirus Bear
sailer's Avatar
Oddometer: 698
what was your plan if you had caught up to the bike before in went down ?
just asking
cool video, hope your buddy was ok
get out and live
sailer is offline   Reply With Quote
Times are GMT -7.   It's 01:36 AM.
