Old 02-19-2013, 06:20 PM   #1
burmbuster OP
burmbuster's Avatar
Oddometer: 1,444
Brake Disc Locks....
So my fork lock is malfunctioning and I have a trip coming up. If you use a disc lock for security, which one do you use?
_______________
2013 KTM 690 Enduro R
burmbuster is offline   Reply With Quote
Old 02-19-2013, 10:40 PM   #2
pingvin
pingvin's Avatar
Oddometer: 522
ABUS Granit Detecto X-Plus 8000 with alarm. Also got the chain so lock 2 of my bikes together. Only downside is the weight so for travel a smaller one maybe would be better but it does make mesleep well.
http://www.abus.com/eng/Mobile-Secur...to-X-Plus-8000
2006 KTM 950 SuperEnduro
2010 KTM 530 EXC-R
2006 Suzuki RM-Z 250
1981 Husqvarna 420 AE
pingvin is offline   Reply With Quote
Old 02-19-2013, 10:53 PM   #3
Vanishing Point
A very sad panda
Vanishing Point's Avatar
Oddometer: 3,629
I have an older Xena (14 mm locking pin) It's like the XN15 but not stainless steel. It has an alarm.
It does give you peace of mind. I found the alarm feature to be more of an annoyance as it would go off too easily and often go off as I was trying to put the key in to unlock it. I gave up on the alarm feature. I'd not recommend that. Also mine was not stainless steel and it does get a little rusty. It left a rust stain in the package rack of my Suzuki which is where I would lock it for travelling. I'd spring for the extra money to get a stainless steel one.
Also come up with some with some foolproof feature to keep you from forgetting it. It cost me a $225 dollar rotor on my Ural when I tried to leave with it locked in place. Now I take a bandana with me and tie it around my grip and clutch lever. When I come back I think "what darned fool tied that there" and when I remember I also remember that I have the disc lock on. It also takes a few seconds to untie the bandana which reinforces my thought time.
Vanishing Point is offline   Reply With Quote
Old 02-20-2013, 02:41 AM   #4
overlandr
Dystopist
Oddometer: 5,883
Are these immune from a can of CO2 and a few hammer blows?
overlandr is offline   Reply With Quote
Old 02-20-2013, 03:06 AM   #5
foxtrapper
Oddometer: 819
I just use a generic padlock.
foxtrapper is offline   Reply With Quote
Old 02-20-2013, 05:28 PM   #6
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,403
How badly does this fellow want to steal your bike that's he come equipped with pressurized gas and tools?
Disc locks are generally to prevent someone a theft of opportunity. Some schlub walks by your hotell room and sees your bike, rolls it away.
Otherwise I have a cordless grinder at work that, with a zip disc, will make quick work of most any lock/chain.
I have also ridden off with a disc lock installed-- on the front wheel.
It doesn't flip you over, like you'd think, first it sucks the disc lock past the fork leg and bends the tar out of your rotor. Then the disc lock rolls around until it hits the caliper so the motor stalls. If you're lucky, you can perform this display of idiocy in front about a pub and about a dozen patrons, all off their faces. Be sure and do it on your buddy's WR426 (no key, thus the disclock) with a wide open FMF exhaust. Also, make sure it isn't tuned for piss and won't start even after kicking it 55 times.
I would have been less exhausted and my knee would feel better had I just pushed that lump back to his house.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 02-20-2013, 05:38 PM   #7
ERD
Custom Rider
Oddometer: 352
1. Use a disc lock reminder cord. It cost a few dollars and prevents making a a** of yourself riding off with the disc lock in place.
2. Disc lock works - generally. Its pretty hard to defeat. Freon can and hammer _might_ break it, but it will also warp the rotor to the point of not able to ride.
3. A determined thief can quickly bypass and/or disable _any_ security system, including disc lock.
I personally use the Xena alarmed disc lock with reminder cord. Every little bit of deterrence works for me. If I accidentally trip the alarm while unlocking the disc lock, so be it. If it's tripped in the dead silence in the middle of the night, I know what caused it and thats what matters.
I've had enough bikes stolen with the disc lock to know what works and what don't.
ERD screwed with this post 02-20-2013 at 06:54 PM
ERD is offline   Reply With Quote
Old 02-20-2013, 05:44 PM   #8
foxtrapper
Oddometer: 819
[QUOTE=ERD;20773039]Freon can and hammer _might_ break it, but it will also warp the rotor to the point of not able to ride.
/QUOTE]
Nah. If they bend the rotor it's because they didn't get the lock cold enough and just stood there pounding a warm lock with a hammer, bending the rotor over.
Old 02-20-2013, 06:16 PM   #9
burmbuster OP
burmbuster's Avatar
Oddometer: 1,444
This is what I'm looking at.
http://www.revzilla.com/motorcycle/a...rake-disc-lock
_______________
Old 02-21-2013, 05:47 AM   #10
Speedo66
Transient
Oddometer: 6,777
I use a Kryptonite lock through the disc, preferably attached to something else with their "noose" chain. http://www.kryptonitelock.com/Pages/...PNumber=999546
I like their locks because it's easier to carry it attached to something on the outside of the bike, like a passenger peg bracket, or a grab rail. No need to remove the seat, or go digging through a case or bags to find it. The easier it is to get to, the more you'll use it.
On my key ring I carry a small yellow ziptie. Before I put the lock on, the ziptie gets inserted into my ignition lock. I remove the lock from my disc before I remove the ziptie. Stops those hilarious (for your friends) little episodes.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 02-21-2013, 10:21 AM   #11
moggi1964
Tiger Keeper
moggi1964's Avatar
Oddometer: 637
Originally Posted by burmbuster View Post
I use this one
http://www.revzilla.com/motorcycle/a...-68-chain-lock
Disk Lock fits under the seat of my Triumph when not in use and the reminder cord means I haven't yet tried to ride off with it.
I occasionally use the chain that attaches to it for when I want to attach the bike to something (depending on where I am and the risk of carry-off theft).
It's not cheap I know and maybe just the disklock would work for you. I tend to overkill
Moggi1964
Triumph Explorer
moggi1964 is offline   Reply With Quote
Old 02-21-2013, 02:16 PM   #12
burmbuster OP
burmbuster's Avatar
Oddometer: 1,444
Originally Posted by moggi1964 View Post
I use this one
Thats a little more than I want to spend, however I am looking at the same lock that you have with the reminder cord shown. It has great reviews as well. I really dont need a chain as it will only be used when away from home over night.
_______________
Old 02-21-2013, 03:08 PM   #13
Riot
Tiger Rider
Oddometer: 105
So whats the problem with the fork lock ??
Riot is offline   Reply With Quote
Old 02-21-2013, 05:42 PM   #14
burmbuster OP
burmbuster's Avatar
Oddometer: 1,444
I own a 2012 Tiger 800 XC. The pin that extends from the ignition lock to the top triple clamp does not extend far enough. My dealer is working with Triumph to get it resolved but I have a trip coming up earlier than when it can be repaired so I need a disc lock for the two nights we are moteling it. The other nights we will camp.
Just a little extra insurance for the road.
_______________
Old 02-22-2013, 02:10 AM   #15
kamikazekyle
Oddometer: 140
I keep all my bikes outside and use disc locks on each, so I've tried a few. Some quick suggestionts:
Firstly, make sure to use a lock reminder cable or something else, as others have mentioned. I haven't damaged any braking equipment yet, but broke a fairing. Which on my former Ducati cost more than a new wave rotor ($375 for half a front fender...really?)
Secondly, put the lock on the rear disc if possible. For many motorcycles, this makes the lock harder to defeat. Less chance of someone swapping out a tire or removing a disc vice the front. Nothing says "son of a bi-" like finding your disc rotor with lock attached sitting in a pile of bolts. YMMV on mounting location, though.
Third, skip the alarmed locks. Many of these locks use LED's or lasers with a mirror to detect vibration or movement. Such mirrors are prone to condensation and fogging resulting in false alarms. Plus if you get a model that doesn't have a remote or decent RFID proximity badge in the key, it can tend to go off while disarming it (as some others have mentioned).
Kryptonite brand disc locks are pretty good bang for your buck. You might have to fiddle with getting the key through the anti-picking mechanisim, but they're less expensive than the Xena counterparts. I've been using one on my CBR for 1.5 years exposed to the elements year round. Dropped, banged, and generally abused it still functions fine and without rust.
I've found Xena locks to be the best, specifically the ones with dual arms (forget the model name/number off hand). They lock/unlock easy and the anti-picking mechanisim lines up easy. I've had one exposed year round for, well, a year and again, no issues. Bit more expensive than a Kryptonite and I'd go with one if you're going to use it frequently, but for a few one-off days a cheaper Kryptonite would be fine.
Trimax locks are...enh. They're really inexpensive ($14 for a 5.5mm pin, short throat on Amazon right now) but don't appear as secure as a dual arm Xena. I've had two models -- the 5.5mm short neck and 10mm long neck. The short neck model I have to putz with frequently. The key goes in fine, but it sometimes just doesn't seem to want to release or set the pins right. I haven't had it that long, and it does seem to be working in with use. By contrast the long neck model was easy on, easy off. Even more so than the Xena. Maybe I got a dud on the shortie. All models have a little cap that folds over the key mechanisim to keep out contaminants. It's nice, but a little cheap and gets in the way at times. Trimaxes include a reminder cable and the master key has a built-in red LED for finding the lock at night while retaining your night vision.
Anyway. For infrequent use I'd prolly go with a standard Kryptonite (which include reminder cables, IIRC) or a Trimax if you just want to save money. $15 for everything you need to use one or two days is hard to beat and is plenty to ward off a casual theft. A Xena XX or dual arm model I'd vote for the best, but they're pricey.
kamikazekyle is offline   Reply With Quote
Times are GMT -7.   It's 11:11 AM.
