Old 02-06-2015, 09:22 PM   #1
Strawdog OP
Strawdog
Strawdog's Avatar
Oddometer: 113
F800GS Fault Code 10151
Okay just did my valve clearance check all good Now # 2 cylinder dead fault code 10151 injector valve 2 confirmed by GS 911 no heat on exhaust runs only one cylinder.
# 2 fuel injector test its not working checked out connections all seems to be good.
Anyone got suggestions my first thought clean connections/ swap injectors.
If that failed drink beer and hope it goes away on its own
Strawdog is offline   Reply With Quote
Old 02-06-2015, 09:55 PM   #2
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,345
Check spark plug caps.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 02-07-2015, 08:44 AM   #3
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,429
OK so #2 injector isn't clicking.
You can jump it with 12v and check manually. You could swap the plugs on #1 and #2 and see what happens. Edit:see what happens when testing it with the 911!!!
The wiring is Ground Seeking, meaning a constant 12V + at the plug and the ground side is switched on/off. Check the plug with the key on.
Assuming the injector plugs are fully seated and clipped of course.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver screwed with this post 02-07-2015 at 10:01 AM
Reaver is online now   Reply With Quote
Old 02-07-2015, 09:29 AM   #4
Strawdog OP
Strawdog
Strawdog's Avatar
Oddometer: 113
Thanks heading to garage now
Strawdog screwed with this post 02-07-2015 at 10:36 AM
Old 02-07-2015, 10:40 AM   #5
Strawdog OP
Strawdog
Strawdog's Avatar
Oddometer: 113
I guess it helps to have connector for properly seated I should save the celebrating beers for when job is completely done Arrgh
Old 02-07-2015, 10:51 AM   #6
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,429
And now it's recorded for all eternity.
We never did hear back from the guy who wanted to prove to his wife that he was capable of changing his spark plugs. He started a HELP, I f'd it up thread.
Great you figured it out. Another wad of cash saved for the beer fund. Valve check - check!
Times are GMT -7.   It's 05:42 PM.
