Old 02-20-2013, 12:52 PM   #1
walkingbear OP
walkingbear's Avatar
Oddometer: 3,502
o e m points and condensors for airhead
I have a R90S that I'm trying to keep stock. Looking for a new set of points and condensors instead of going to electronic .
Had a long talk with
Motorrad Elektrik yesterday and he suggested keeping it as stock as possible.
The new stuff being sold by BMW dealers where all made in China. any sources for oem points here?
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 02-20-2013, 01:20 PM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,598
It's the crap Chinese points and condensers that are forcing me down the electronic ignition route with my 100/7. The last set of proper points ad condenser I had fitted had been on for over 10 years. I've now had three sets of points and condensers in the last three and they need frequent adjustment and tidying up. The arcing across the crap points, even when new, is sight to behold.
At least if I fit a Boyer I'll be fitting something that's made in England (albeit the South which always makes me suspicious).
Rob Farmer is online now   Reply With Quote
Old 02-20-2013, 01:26 PM   #3
elite-less
As above, so below
elite-less's Avatar
Oddometer: 542
I've always run Noris points and never had issues.
Try Hucky: http://www.bmwhucky.com/010012.html
Slash 5 Revive
elite-less is offline   Reply With Quote
Old 02-20-2013, 02:03 PM   #4
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,637
I'll second Noris. Good quality.
I added a Dyna Points Booster about 3-4 years ago. The points last longer (no electrical pitting) but the rubbing block wears slowly and the point gap needs to be adjusted at 3000-5000 intervals. Been reliable.
--Bill
'73 R60/5 Toaster
Old 02-20-2013, 06:13 PM   #5
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,547
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 02-21-2013, 07:58 AM   #6
cycleman2
Oddometer: 568
Try Motobins in the UK. They have lots of parts for these old airheads.
2013 DL650 Adv
cycleman2 is offline   Reply With Quote
Old 02-21-2013, 08:44 AM   #7
homere
Oddometer: 132
Question bmw points
Huckey sells a"Bremi", made in germany ? anyone try these?
homere is offline   Reply With Quote
Old 02-21-2013, 12:35 PM   #8
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,598
Motobins supplied the cheapo points and condensers currently in my bike.
Old 02-21-2013, 06:37 PM   #9
supershaft
because I can
Oddometer: 9,116
A lot of reasons in this thread as to why I like electronic. Service every 3 to 5k miles? With the timing constantly changing in between? Nein Danke! I'll stick to servicing my electronic ignition every 100 to 200K miles or whenever it breaks with rock solid timing and spark the whole time in between.
Old 02-21-2013, 10:04 PM   #10
DaveBall
DaveBall's Avatar
Oddometer: 1,163
I feel the same as Supershaft. I like to ride, not futz with stuff so I can take a short ride and futz some more. Therefore, I will keep my OEM electronic ignition until it fails. Actually, have yet to have one fail on any of my bikes. I guess as I get closer to the 300,000 plus miles, I may be looking at a replacement.
Sure, electronic is more expensive than points at the stealership, but if you add up all the points needed to last 300,000+ miles, I think the costs actually are in favour of the electronic. And a whole lot less time spent futzing.
DaveBall is offline   Reply With Quote
Old 02-21-2013, 10:24 PM   #11
walkingbear OP
Oddometer: 3,502
stockvs electronic = $value
I understand the value of electronic ignition on a reg rider. I have the option to change from points to electronic. The value of a motorcycle is more if it is stock. I'm just looking for good replacements and I will have them put away for the next 10years so I can pass it along to my son or grandson.
Old 02-21-2013, 10:25 PM   #12
supershaft
because I can
Oddometer: 9,116
And your bike is running better most of the time. Brand new points only work like brand new when they are brand new.
Old 02-23-2013, 11:04 AM   #13
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
Geez, I got over 20k on my points and still function nominal, as new. With the Dyna Booster they just need a few minutes maintenance every few years at my pace. There are advantages and disadvantages to either points or electronic. What is best for one is not wanted by another. Super's opinion is no better or worse than any other, just another DIYer but with the attitude that if you don't do it his way, you must be wrong.
It's just a bogas premise on it's face to suggest over and over again one way is better for everyone until all are convinced.
Bad opinion stated "McMillions" of times does not convert it to good opinion.
DoktorT is offline   Reply With Quote
Old 02-24-2013, 07:24 AM   #14
Bill Harris
Oddometer: 7,637
Well put. As I said earlier, one advantage to the Dyna Booster is that the Dwell (the "coil saturation time interval") is set electronically and the electrical load on the points is reduced to milliamps. As the wear on the points rubbing block closes the point gap, the ignition timing will slowly shift towards retarded. A quick periodic check with a timing light will tell where the timing is and whether or not the gap need to be opened. At that time, I'll refresh the point cam lube and run a strip of business card through the points to clean up any residual oxidation (the latter is not really needed, I'm just being picky).
--Bill
'73 R60/5 Toaster
Old 02-24-2013, 09:12 AM   #15
JimX
Oddometer: 710
Originally Posted by DoktorT View Post
Geez,
So a preference for electronic ignition is just a "bad opinion"? No charlatan references? You're slipping, Dok.
JimX is offline   Reply With Quote
Times are GMT -7.   It's 11:54 AM.
