Old 02-20-2013, 06:10 PM   #1
ritetwist OP
ritetwist's Avatar
Oddometer: 178
airbox to carb fitting
Does the rubber hose connect the 45* plastic fitting to the airbox,or to the carb?
I see Max shows the hose at the carb end but I realize this is just a schematic drawing.
On bikes, I swear I have seen both ways.Is one correct or hook it up as best fit?
Trying to make it right.
Thanks.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 02-20-2013, 06:12 PM   #2
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,540
Thanks.
Whatcha riding? But usually they connect the elbow to the airbox outlet.
Old 02-20-2013, 06:52 PM   #3
ritetwist OP
ritetwist's Avatar
Oddometer: 178
1982 r65ls,sorry,I thought all of them would be the same?
They sure can be fun to connect,esp. when new.
Old 02-20-2013, 09:21 PM   #4
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,838
On both my R75/5 it's on the carb end.
Big Bamboo is offline   Reply With Quote
Old 02-20-2013, 09:36 PM   #5
hardwaregrrl
ignore list
Oddometer: 7,540
So rubber from elbow to airbox, elbow connects to back of carb, front of carb to head via rubber.
Old 02-20-2013, 10:15 PM   #6
ironjack63
Oddometer: 66
what kind of rubber is between carb and engine? Looks just like a piece of radiator hose. Can something from an auto parts place be used?
ironjack63 is offline   Reply With Quote
Old 02-20-2013, 11:05 PM   #7
ME 109
ME 109's Avatar
Oddometer: 2,990
It's such a crap fit up, it prolly doesn't matter where the rubber hose goes.
I once read there was a left and right side for the plastic elbow? I don't see much difference between them.
Rubber needs to be fuel proof. Cheap enough to buy from aftermarket supplier, maybe even bmw
Lord of the Bings, kangaroo farmer
ME 109 is online now   Reply With Quote
Old 02-20-2013, 11:25 PM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,803
According to the parts fisch the rubber part goes on the carb side of the suction funnel (that's what they call it);
There is also a right side and a left side of the plastic elbow. I don't have mine put together like the picture either. The rubber tube I have has an internal step and fits the air box to plastic suction funnel better. The connection to the carb doesn't need any rubber on mine anyway.
These parts are put together numerous different ways. The idea is to seal out dirt on the airbox side and to seal in the vacuum on the head intake side.
I have proposed using radiator hose for the rubber parts but many have objected and said the anti freeze resistant radiator hose may not be gasohol resistant. Maybe. But in a pinch it might work for some time before a proper material can be found.
---Albert Einstein
Old 02-21-2013, 12:07 AM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,803
Sorry. I posted the fisch of my bike and of course it has nothing to do with a more modern piece of art such as the R65ls such as yours.
The suction funnels appear to be on the inside of the box. They are right and left side parts. #14 is called a pipe. And the plastic elbows are the same on both sides, not different like on us older bikers, er, bikes.
The rubber grommet is still on the carb side at least in the picture.
That's not clear to me at all because I don't have one of these. Is my impression correct about the tubes inside the air box, are they different tubes inside the box? And the same on the out side?
You can't always depend on the micro fisch picture being correct in details.
---Albert Einstein
Old 02-21-2013, 04:59 PM   #10
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,606
I was relatively ignorant when I had my R75/5. I had only the plastic tubes and two clamps per side between the carbs and the airbox. They never really fit right (just a leetle beet too short) and I always cursed them. Is it only now that I'm finding out the source of my frustration? Or were there two different versions of tubes?
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 02-21-2013, 05:15 PM   #11
supershaft
because I can
Oddometer: 9,116
So I hope everyone figured out it depends on the model per the ETK.
I think the square airbox snorkels are much easier to deal with than the clam shell snorkels. I always custom grind on the late model setups and get them fitting perfectly. Easy on and off. Just lower the radiator hose at the airbox and off they come. A lot of them will never fit close to right for the carb/head radiator hose being too long. That includes the clam shell types and the square airbox types.
Old 02-21-2013, 05:39 PM   #12
craydds
craydds's Avatar
Oddometer: 1,167
I have a '75 R90S with Dellortos so my airtubes are easy on and easy off (with my TOP SECRET modifications).
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 02-21-2013, 05:42 PM   #13
craydds
craydds's Avatar
Oddometer: 1,167
Originally Posted by supershaft View Post
I always custom grind...
Are you sharing my TOP SECRET modifications? Great! Free to all - who run Dell's.
ABC #12947
'75 R90S
Old 02-21-2013, 05:46 PM   #14
supershaft
because I can
Oddometer: 9,116
Same here with my Dellorto's on my '92 RT but it isn't secret. I used the velocity stack threads on my Dellorto's as a depth gauge to file off about one third of the threads and keep the carb mouth perfectly round. I then put my RT's stock snorkels on my Dell's just like they were Bings. I have had more than a couple of people in the know tell me it was about the cleanest Dellorto setup they had ever seen. The setup looks exactly like the R65 up above but with Dellorto's instead of Bings. Well, that and different carb spigots but they have the same rubber hose style mount as Bings. Rigid mounted carbs was old fashion in '74! I was sure to get rubber mounted ones.
Old 02-21-2013, 06:01 PM   #15
craydds
craydds's Avatar
Oddometer: 1,167
Very cool! I also grind off the plastics numbs/bumps - what ever you call them - on the airtubes so the rubber rings slip on/off with ease. This may apply to Bings, too - I will look at my '74 R90/6. Will make some pics if that will help fellow inmates.
ABC #12947
'75 R90S
Times are GMT -7.   It's 03:56 AM.
