Old 02-21-2013, 09:46 AM   #1
Da Rooster OP
Oddometer: 2
Question NX650 Dead in the water - Electrical Problem - Any ideas?
I have an 89 NX650 that is in great shape. Just clicked over 4000 miles. I parked it yesterday, and when I went to start it, I put the key in the ignition, turned the switch, and nothing. No lights, no start, nothing. Unfortunately, I was not at home when this happened...
I checked the fuses, and the main fuse. All good.
I pulled the battery, and brought it home to test/charge. It seems to be fine.
I checked the connector off of the ignitions switch, seems fine.
I can't imagine what has happened that would cause a total loss of power like that. Is there some single point of failure in the electrical system somewhere that could cause this, or do I now have an electrical gremlin to chase down?
Any thoughts or ideas you could share would be most appreciated.
Da Rooster is offline   Reply With Quote
Old 02-21-2013, 04:43 PM   #2
buzybraza
buzybraza's Avatar
Oddometer: 377
Any modifications?
Does it run if bumpstarted? (Or you can take a battery jumper straight to the starter motor)
buzybraza is offline   Reply With Quote
Old 02-21-2013, 07:53 PM   #3
Claytonroy
Oddometer: 287
Kill Switch - Check the internals
Split the clamshell containing the guts of the kill switch. I suspect your problem is deeper, even though you already checked the wires exiting the switch. Clean out the internals and make sure the connection is working for both on/off with a solid 'snap' to the operation. There are tiny return springs inside the switch - it looks like they belong in a wrist watch. What happens is the old factory grease boogers up the mechanism giving you a false 'On'.
So basically, your bike is not firing because the kill switch is effectively 'Off'.
The switch grease gets especially boogery on low mileage bikes living in dry climates.
Good luck!
Claytonroy screwed with this post 02-21-2013 at 08:21 PM
Claytonroy is offline   Reply With Quote
Old 02-21-2013, 09:41 PM   #4
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,015
Follow the main ground off the battery and check connection to frame?
Batteries are funny animals, try some jumper cables to be sure.
TE630.KLX250S.GL1800.CBR900RRturbo.919
HoW (ForeverWest) 2014 CO/UT 2013
Northern Rockies 2013 IBA Key West 2014 Tentspace
DYNOBOB is online now   Reply With Quote
Old 02-22-2013, 11:28 AM   #5
Da Rooster OP
Oddometer: 2
Thanks gang. I'm definitely going to check the switch, and try swapping the battery with another one (fortunately I have a few extra bikes laying around). The bike is essentially bone stock, with the addition of heated grips and brush guards. The bike has had little exposure so there is hardly any corrosion anywhere - so I doubt wiring issues. My bet is with the switch, and I think from the wiring diagrams, that I should be able to jumper those wires to bypass it. I'll let you know what I find. Only one day without it so far, and I already miss it. The NX has become my new favorite!
Times are GMT -7.   It's 10:22 AM.
