Old 02-21-2013, 06:07 PM   #1
rwavaktm OP
rwavaktm's Avatar
Oddometer: 178
Idle Issue
My 06 950 just started some idle issues. It will intermittently die when idling in traffic, hit the starter and she starts right up. Does not happen real frequently but yesterday it happened twice on a 10 minute ride. It just shuts off like you hit the kill switch, but starts back up like nothing is wrong.
Any Ideas? Thanks in Advance!
___________
06 KTM 950
02 KTM 300
00 KTM 640
09 HD RKING
rwavaktm is offline   Reply With Quote
Old 02-21-2013, 09:05 PM   #2
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,594
first off, make sure that it is idling at 1400.
if it keeps doing it, then I would do the following:
1. drain the carb fuel bowls, leave open
2. pull the top air box cover and remove the air filter
2a. remove the upper black plastic carb adapters
2b. with nozzle attached, spray carb cleaner directly through the each of the three air jets, then blow clear with compressed air.
3. close bowl drains
4. reassemble and test
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 02-21-2013, 10:11 PM   #3
Qwik
Adrenaline Addict
Oddometer: 6,893
Mine is doing it as well. I believe it may have something to do with the carb sync (Or lack of) But I will try the cleaning method mentioned above as well.)
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 02-22-2013, 03:47 AM   #4
Sumi
Sumi's Avatar
Oddometer: 1,813
Mine is doing this as well from the day when I've bought it, 20k kms ago.. I've cleaned the carbs 10 times, readjusted the tps, ims, everything.. checked for leaks a dozen times, reset valve clearances, even changd the rear cyl. Head asy and timing chains (not because of this) etc. But nothing helped.. I just set the idle to 1800 and living with it.. with the higher idle it doesnt happen that often.. well it does, one of the cylinders missfire, but it has the momentum to avoid engine stall.. it's very annoying, but life is hard:))
Old 02-22-2013, 05:17 AM   #5
rwavaktm OP
rwavaktm's Avatar
Oddometer: 178
Idle Issues
Thanks Head2Wind I will try your suggestions.
Mine has never done this before.
___________
06 KTM 950
02 KTM 300
00 KTM 640
09 HD RKING
Old 02-22-2013, 08:42 AM   #6
Sumi
Sumi's Avatar
Oddometer: 1,813
http://www.advrider.com/forums/showthread.php?t=78596
Old 02-22-2013, 09:34 AM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,594
I would also suggest that you consider ensuring that all of the usual suspects are addressed in the electrical side as well.
1. side stand switch (i almost always disable this on my dirt-ish bikes)
2. battery and main power terminals, both + and -. Take them loose and CLEAN them, then reassemble to ensure that they are tight.
3. key ignition switch is clean
4. ignition and gear position switch plugs. (this was a recent bug that I found on a very poor running SE.... the ignition pulse harness plug was dirty, cleaned all the connectors and significant miss/stall issue went away).
5. coils COMPLETELY pushed onto spark plugs. I don't know how many bikes I have worked on that the coils are just sitting on the top of the plugs from the last maintenance work.... Pull the bottom boots off the coils and make sure the area is clean and free of all debris. All the crap that the arching creates then can cause misfire arching. Lube with dielectric grease and reinstall.
6. main start/fuse solenoid, the fuse terminals get dirty and/or the connector plug gets dirty.... clean it, grease it, put it back together.
On the 950 the clutch switch does nothing other than latch/unlatch the safety systems. Where on the 990 it tells the ECM to alter fuel/timing etc in addition to the safety latch systems.
Old 02-22-2013, 09:50 AM   #8
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,108
Good list. I could add the following:
  • Check the TPS to make sure it's not throwing off spark advance.
  • Is your front carb oily because of blowby on the balancer shaft seal? If so, change the seal and the plugs.
  • Are you running at different altitudes or temperatures than normal? 950 carbs are finicky, and I find I have to change IMS settings in the cold. Adjustments are minor but make a big difference. If I ride from my normal altitude (850 ft) to Denver, I have to go down one quarter of a turn to make it idle properly. Consider getting a set of FlexJet2s for the bike if you change altitudes or find that the problem is arising during big swings in temperature.
  • How does it start? Does it need choke to start? If not, it's probably rich to begin with.
  • Is your air filter clean? Are there any other air restrictions?
  • When's the last time you balanced the carbs? If it's been awhile, do it again. I've found that getting the carbs just a little out of balance can really impact the bike a lot.
Orangecicle is online now   Reply With Quote
Old 02-22-2013, 01:16 PM   #9
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
The other thing to look at is clutch. The clutch always has drag but it should be smooth. If the clutch is lurching, when you come to a stop it can kill the engine. Does the bike ever die in neutral at a stop? The faults here are plugged clutch oil jet or scratched final clutch disk. Mine was stalling similar to yours and cleaning jet fixed it.
DeepInIt is offline   Reply With Quote
Old 02-23-2013, 03:40 AM   #10
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 954
I've had a bad choke cable on the 950, it would not retract fully when i depressed the lever hence it was always choking the carbs a bit. At lower revs in 1st gear, and rarely in 2nd would shut the engine off.
New choke cable, correct slack and carbs synchronized solved the issue.
690R
Old 02-23-2013, 09:43 PM   #11
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,594
+1 on the choke cable failure. I have replace two so far to solve a poor running/intermittent idle problem. The single cable that comes down from the bar got smashed near the airbox and was enough to occasionally/most of the time, not allow the enriching plungers to fully seat. ran poorly, and coughed/sputtered. Have to purchase the whole cable assembly, cannot purchase from KTM just sections of the assembly despite it being modular... In a pinch and budget any one of the cables could be custom made by MotionPro or any shop that still knows how to make cables.
Times are GMT -7.   It's 06:46 AM.
