Old 02-22-2013, 01:57 PM   #1
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Oil Cooler lines -- Aftermarket?
I just ordered a Spiegler brake line today for my RT to S conversion.
Some of my conversion is cosmetic as well as the fairing conversion.
Like for instance, I would like to change out the oil cooler lines to something more blingy.
I bought the Spiegler with Titanium ends and Smoke colored line.
Anybody know of something available for the cooler lines?
Here's an example of the Titanium/Smoke combo
Les_Garten is offline   Reply With Quote
Old 02-22-2013, 02:55 PM   #2
pommie john
pommie john's Avatar
Oddometer: 1,448
If you want the satisfaction of making your own ( which isn't hard) you could buy the fittings and hose from a place like Earles or Goodrich. I don't know if they do Ti fittings but the braided steel hose with anodised aluminium fittings looks quite bling.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 02-22-2013, 03:25 PM   #3
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
I made all the lines when I did my Porsche. For a few lines, I'm thinkin' I would prefer to buy them. As soon as you posted that, my finger started hurting from the wires that used to live in them. If you don't have the factory cutting tool, they can be a bear with the little wires on the frayed end. I cut them with a air cutoff tool and had all sorts of fun! On small lines like this maybe a dremel would work.
I'll look into it, but for instance, that Custom Brake line from our friend Ted Porter was $61 and he charged $5 shipping.
That Titanium above is just a color. No issues there.
Old 02-22-2013, 04:09 PM   #4
supershaft
because I can
Oddometer: 9,116
That's what I do. One word of caution. The new regular fittings rust big time in no time. I have some regular Earls (made by Goodrich) fittings on my bike that I have had for 25 years but they don't cadnium plate them anymore. My advise is to go stainless.
Old 02-22-2013, 04:29 PM   #5
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Do you know the specs on the "ends", and what size line to get?
Old 02-22-2013, 05:24 PM   #6
supershaft
because I can
Oddometer: 9,116
Most run #3 line. You just get ends for #3 lines with the right tread pitch where needed.
Old 02-22-2013, 06:03 PM   #7
100RT
100RT's Avatar
Oddometer: 701
Those are unique threads on the fittings, cant remember what they are.
100RT is offline   Reply With Quote
Old 02-22-2013, 07:09 PM   #8
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
I'm guessing the Banjo's may be something at least Metric as well.
Old 02-22-2013, 09:00 PM   #9
supershaft
because I can
Oddometer: 9,116
None of the threads are unique. All you have to do is measure them. That's what I do since I don't have the thread pitches memorized. Earls has all the threaded parts needed.
Old 02-22-2013, 09:04 PM   #10
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Are they AN or pipe?
Old 02-22-2013, 09:05 PM   #11
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Somebody knows what fittings are on there.
http://www.motoren-israel.com/produc...-tubes-SS.html
Old 02-22-2013, 09:14 PM   #12
supershaft
because I can
Oddometer: 9,116
The #3 line recommendation was for brake lines. The threads are metric for both the brake and oil cooler lines. The line size is AN but the threads are metric. I don't know what size those oil lines are. 4 or 5? Does that thread you linked list the thread and line sizes? You could always go measure them yourself. That would do you more good if that link doesn't list the sizes and you want to shop around. Or if that link has a typo and gets you the wrong size from somewhere else.
Old 02-22-2013, 09:40 PM   #13
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
I pinged RGregor to see if he is plugged into someone at MI.
I don't trust my expertise on determining the thread type.
If it is pipe thread, then it would be easy.
Old 02-22-2013, 09:59 PM   #14
supershaft
because I can
Oddometer: 9,116
No, none of it is pipe thread.
Old 02-22-2013, 10:12 PM   #15
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
So it's AN?
Times are GMT -7.   It's 04:08 AM.
