Old 03-25-2013, 05:07 AM   #61
craydds OP
craydds's Avatar
Oddometer: 1,167
Originally Posted by Scootern29 View Post
Hey Ray, maybe it's the photo.....but the fork tube looks bent in that one pic fo the forks disassembled. I hope not. And BTW I don't know that much about YZ400's. Only a small amount.
Fork tubes are straight, must be a funny picture. One of the tubes is pitted with rust spots. I sanded and polished it, hope it holds air and oil... we shall see. Otherwise, I'll buy a new fork tube.
ABC #12947
'75 R90S
craydds screwed with this post 03-25-2013 at 04:43 PM Reason: spell
craydds is offline   Reply With Quote
Old 03-28-2013, 01:37 PM   #62
craydds OP
craydds's Avatar
Oddometer: 1,167
steering stem
Triples going together:
Stem is FROSTY, it's been in the freezer:
Bit of grease on the stem, heated up the bearing in my girlfriend's favorite skillet, bearing drops on with a light tap:
Races in the freezer, bit of grease and heat up the steering head (heat gun), and the races drop right in:
As Valleryrider recommended, I now have new tapered roller bearings from All Balls for the steering head:
ABC #12947
'75 R90S
craydds screwed with this post 03-28-2013 at 02:05 PM Reason: spell check
Old 03-28-2013, 02:16 PM   #63
craydds OP
craydds's Avatar
Oddometer: 1,167
swing bearings
Time for new All Balls swingarm bearings. Same process, grease (I use anti-sieze) and heat up swingarm:
Bearings have been in the freezer for hours, they drop in with a light tap, used a socket as a drift:
Coat of paint:
All Balls parts:
Swingarm is ready for installation. Soon... I hope:
ABC #12947
'75 R90S
Old 03-28-2013, 02:21 PM   #64
craydds OP
craydds's Avatar
Oddometer: 1,167
flywheel puller?
Question I posed to Scootern29, but I'll ask all, how do I pull off the flywheel? I've got the nut loose, I suppose I need a flywheel puller?
ABC #12947
'75 R90S
Old 03-28-2013, 03:07 PM   #65
Scootern29
Scootern29's Avatar
Oddometer: 515
Hey Ray, sorry I missed your question in my thread. Yes you will need a flywheel puller. I am at work right now so I don't have time to look up the part # for you. Do a search on Ebay for Yamaha flywheel pullers. That's where I got mine and it works on many other models as well.
BTW the threads in the flywheel are left hand. Make sure you run that puller in as far as you can get it or it will pull the threads. That would be a bad scene. I almost did it. Ha Ha
Keep up the good work.
Scootern29 screwed with this post 03-28-2013 at 03:12 PM Reason: info
Scootern29 is offline   Reply With Quote
Old 03-28-2013, 03:43 PM   #66
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,372
Oh so very true and costly
JeffS77 is offline   Reply With Quote
Old 03-28-2013, 04:50 PM   #67
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,870
Just trashed my puller.... Threaded in as far as I could get it (into the rust) and after several attempts to loosen the flywheel, No Mo Threads.
The build is looking great Ray!!
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 03-28-2013, 08:06 PM   #68
JeffS77
cheap bastard
JeffS77's Avatar
Oddometer: 3,372
If it only pulls the pullers threads it's all good... Just don't bugger up that flywheel
Old 03-29-2013, 05:03 AM   #69
craydds OP
craydds's Avatar
Oddometer: 1,167
Does this look like the right puller - http://www.ebay.com/itm/Motion-Pro-F...sories&vxp=mtr ???
ABC #12947
'75 R90S
Old 03-29-2013, 03:32 PM   #70
Scootern29
Scootern29's Avatar
Oddometer: 515
I would imagine it is. That's how I bought mine by what bike it fit.
Old 03-29-2013, 03:34 PM   #71
Scootern29
Scootern29's Avatar
Oddometer: 515
I have a question for you Ray, your user name is craydds. Is dds for dentistry? That may explain the jackhammer trick maybe. Just kidding my fren.
Old 03-30-2013, 06:19 AM   #72
craydds OP
craydds's Avatar
Oddometer: 1,167
Yes, I am a DDS. I have finely developed motor skills. That's why I use a JACK HAMMER.
ABC #12947
'75 R90S
Old 03-30-2013, 10:11 AM   #73
Scootern29
Scootern29's Avatar
Oddometer: 515
Old 03-30-2013, 07:36 PM   #74
Valleyrider
I Survived The '60s
Oddometer: 1,870
Yes Ray, that looks like the right one.
Dentistry and Jackhammers.... Scarin Me!!
Old 03-30-2013, 08:16 PM   #75
craydds OP
craydds's Avatar
Oddometer: 1,167
I promise I'll be gentle. Open wide.
(some progress made today. pictures tomorrow morning.)
ABC #12947
'75 R90S
Times are GMT -7.   It's 12:07 AM.
