Old 03-31-2013, 05:29 AM   #76
craydds OP
craydds's Avatar
Oddometer: 1,167
threads?
Threads? Where are the threads?
All I see is RUST:
Will keep it soaked until my puller arrives. May need to get a puller that will grab the outside of the flywheel:
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 03-31-2013, 05:41 AM   #77
craydds OP
craydds's Avatar
Oddometer: 1,167
triples
A few more coats of rattle can:
Triples going on with new bearings:
Purdy:
Forks:
Mock-up:
Will fill 'em with fork oil today:
ABC #12947
'75 R90S
Old 03-31-2013, 05:50 AM   #78
craydds OP
craydds's Avatar
Oddometer: 1,167
swingarm
Swingarm was chewed up by the chain:
I ordered a new thrust cover and seal - waiting upon its arrival:
Got a new guard to go over the thrust cover:
Load it with grease. Will install swingarm after new thrust cover/seal gets here:
ABC #12947
'75 R90S
Old 03-31-2013, 09:45 AM   #79
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,883
Nice work Ray!! It's going to be too nice to get dirty!!
If the threads are gone, O'Reilly auto parts loans tools.
I got a valve spring tool for the TT500 head. No cost just leave a deposit.
A finger puller might be your answer
http://forums.pelicanparts.com/off-t...ml#post3372393
Applying heat around the opening may help loosen the grip the flywheel has on the crank end.
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 03-31-2013, 10:06 AM   #80
Scootern29
Scootern29's Avatar
Oddometer: 533
Did you get the fork boots from the vintagespoke.com? They look good.
Scootern29 is offline   Reply With Quote
Old 03-31-2013, 03:10 PM   #81
craydds OP
craydds's Avatar
Oddometer: 1,167
Yes, Vintagespoke, on eBay. Pics later.
ABC #12947
'75 R90S
Old 03-31-2013, 06:02 PM   #82
dannyb278
Oddometer: 43
Keep up the good work! I restored a 1976 yamaha IT400 two years ago. Very similar to the YZ400. Tuned right the things can go like a bat out of hell on the straights and climb up a wall if necessary. Just dont try to turn.
Are you having any trouble finding parts?
There is a shop called Yamaha Speed and Sport. i believe they are out of Pennsylvania. Have most anyting for vintage yamahas. Also, Yamaha has a online data base with parts numbers and component breakdowns.
Cant link them now, but if you need the links, let me know.
dannyb278 is offline   Reply With Quote
Old 03-31-2013, 07:10 PM   #83
craydds OP
craydds's Avatar
Oddometer: 1,167
Been able to find most everything I need so far. The bike was almost totally complete and unmolested, hadn't really been trashed as is the case with so many old dirt bikes. Seems like it had been left outside in the weather for too many years, but down here in the desert at least it is dry and fairly kind to machinery.
Bike is starting to come back together... slowly and carefully.
Thanks for the tips!
ABC #12947
'75 R90S
Old 03-31-2013, 07:15 PM   #84
craydds OP
craydds's Avatar
Oddometer: 1,167
I have restored several old motorcycles, pickups, Jeeps, VW Bugs, Camaros, etc. Sold my '83 RM250, still kicking myself. Always set them up to RUN. No trailer queens here. Going to RIDE this YZ and crash it. No powder coating for me, I paint with rattle can, that way I can give it a shot of paint after I scratch it up.
(thanks for the tips on a puller)
ABC #12947
'75 R90S
craydds screwed with this post 03-31-2013 at 07:24 PM Reason: thanks
Old 03-31-2013, 09:42 PM   #85
Valleyrider
I Survived The '60s
Oddometer: 1,883
Yo se` Rattle Can...
My TT500 project is a real rust rat. I won't worry about racing it.
I went a little overboard with my '68 DT1. Can't bring myself to put it on the track again.
Old 04-01-2013, 04:47 AM   #86
craydds OP
craydds's Avatar
Oddometer: 1,167
Keep that one on the mantle above the fireplace.
ABC #12947
'75 R90S
Old 04-01-2013, 05:08 AM   #87
craydds OP
craydds's Avatar
Oddometer: 1,167
Yo se` Rattle Can.
Rattle can esta muy bien.
ABC #12947
'75 R90S
Old 04-01-2013, 05:16 AM   #88
craydds OP
craydds's Avatar
Oddometer: 1,167
forks done
before:
after:
Forks are done. Filled with 415 cc of 10 wt. fork oil according to service manual specs, seems like a lot. May draw some out, service manual said measure 163 mm to oil - range of 146 to 195 mm - might take it down to 150 mm. Easy to add more if needed. Fork boots from vintagespoke:
ABC #12947
'75 R90S
craydds screwed with this post 04-01-2013 at 08:38 AM
Old 04-01-2013, 08:38 AM   #89
craydds OP
craydds's Avatar
Oddometer: 1,167
Race Tech Monoshock
Old:
Zero damping:
Back from Race Tech:
A trick I learned from Scootern29:
No swingarm yet, but the monoshock is ready:
New:
ABC #12947
'75 R90S
Old 04-01-2013, 09:00 AM   #90
craydds OP
craydds's Avatar
Oddometer: 1,167
It's fun seeing the big stuff go back together, might start to look like a dirt bike. But so much time is spent doing little things:
Little details, lots of work:
Not too exciting, but necessary:
Now, if I can get that flywheel off...
ABC #12947
'75 R90S
Times are GMT -7.   It's 01:34 PM.
