Old 04-07-2013, 04:51 PM   #91
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,883
Originally Posted by craydds View Post
Now, if I can get that flywheel off...
You having any luck with the flywheel Ray??
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 04-08-2013, 04:43 AM   #92
craydds OP
craydds's Avatar
Oddometer: 1,167
Yes, I am having BAD luck. Got a flywheel puller, tried every trick in the book, no luck. Time to find a puller that will grab the flywheel externally. May try O'Reilly Auto this evening, see what types of pullers they have. Bought another flywheel from eBay, has threads in good condition, should arrive this week. That way if I totally destroy existing flywheel I'll have a replacement.
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 04-09-2013, 08:28 AM   #93
Valleyrider
I Survived The '60s
Oddometer: 1,883
When you get the puller, try applying some heat around the area where the threads should be. Hope things go better!
Old 04-09-2013, 04:17 PM   #94
heliyardsale
Always looking for Dirt!
heliyardsale's Avatar
Oddometer: 420
Old:
Zero damping:
Back from Race Tech:
A trick I learned from Scootern29:
No swingarm yet, but the monoshock is ready:
New:
What did race tech charge for the rebuild?
An Alaskan bush pilot once told me "every great adventure begins with piss-poor planning"
Heli (Doc Mike)
heliyardsale is offline   Reply With Quote
Old 04-10-2013, 05:33 AM   #95
craydds OP
craydds's Avatar
Oddometer: 1,167
The total was $202; $177 for the rebuild plus $25 for their shipping charge. It cost me $28 to ship it to Race Tech so actually my total cost was around $230 for my BRAND NEW rebuilt shock.
ABC #12947
'75 R90S
Old 04-10-2013, 05:53 AM   #96
craydds OP
craydds's Avatar
Oddometer: 1,167
swingarm
Got swingarm installed with new All Balls bearings/seals/thrust washers, new swingarm "thrust cover" and chain guard to replace the chewed-up piece:
Bet that the NEW monoshock will work well:
ABC #12947
'75 R90S
Old 04-10-2013, 01:07 PM   #97
craydds OP
craydds's Avatar
Oddometer: 1,167
Put puller in freezer, heated flywheel. Tapped puller into flywheel (no threads), trying to get a friction fit:
Heated everything up to smoking HOT, flywheel won't budge. Puller slips out of flywheel:
Next attempt - going to O'Reilly's for a puller that will grab the slots in the flywheel or grab the outside edges. Cutting torch... anybody?
ABC #12947
'75 R90S
Old 04-10-2013, 01:12 PM   #98
craydds OP
craydds's Avatar
Oddometer: 1,167
tank
Sanded off old flat black paint that PO must have sprayed on. Sanded down through a red primer down to the original yellow. Tank is pretty well beat up, will likely strip it and attempt to do some metal work:
ABC #12947
'75 R90S
Old 04-12-2013, 02:31 PM   #99
Scootern29
Scootern29's Avatar
Oddometer: 533
Here's a little tip for ya Ray. Loosen up the monoshock so you can move it around before you install the pipe.
Scootern29 is offline   Reply With Quote
Old 04-12-2013, 07:30 PM   #100
craydds OP
craydds's Avatar
Oddometer: 1,167
Originally Posted by Scootern29 View Post
Here's a little tip for ya Ray...
Cool! Thanks, Scooter!!
ABC #12947
'75 R90S
Old 04-12-2013, 07:36 PM   #101
craydds OP
craydds's Avatar
Oddometer: 1,167
need advice
So, should I just sand and repaint the old tank, or should I try to strip it and do some metal work? I have some ideas about how to pop out the dents, etc. But, it's just an old dirt bike, and I am going to RIDE it, that means I will crash it, too. If I make that tank too purdy, I'll be afraid to put a scratch on it. Need opinions from the faithful.
ABC #12947
'75 R90S
craydds screwed with this post 04-12-2013 at 07:54 PM Reason: words
Old 04-12-2013, 08:24 PM   #102
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,744
Id be trying to get as much penetrating fluid in there as possible and put a rattle gun on it, if that doesn't work tighten the puller up then smack the head of the pusher bolt with a brass hammer.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 04-12-2013, 09:11 PM   #103
Scootern29
Scootern29's Avatar
Oddometer: 533
Depends on how good you want it. I am concerned with your "metal work". That tank should be aluminum. Get something plastic and keep the stock tank in the rafters. I have a desert tank if you want it.....cheap. It may be an old dirt bike but it is a one year bike........keep that in mind.
Old 04-13-2013, 06:33 AM   #104
craydds OP
craydds's Avatar
Oddometer: 1,167
I am going to give it another try later on today. Will post results.
ABC #12947
'75 R90S
Old 04-13-2013, 06:39 AM   #105
craydds OP
craydds's Avatar
Oddometer: 1,167
I may take you up on that desert tank. I found a source for tanks, they had everything except a 1976 YZ400 tank, I'll try to find the link. Got pics of your tank? Price? PM me if you like.
edit: Found this at Clarke - http://clarkemfg.com/yz250125-7476-s...ity-p-244.html , says YZ250 but it might fit the 400 (?).
ABC #12947
'75 R90S
craydds screwed with this post 04-13-2013 at 06:47 AM Reason: link
Times are GMT -7.   It's 06:41 AM.
