Old 02-22-2013, 03:53 PM   #1
alongat OP
alongat's Avatar
Oddometer: 319
50mm suspension kit for ABS 990?
As some of may know, KTM sells a 50mm suspension lift kit in their powerparts catalog however they state that its for non-abs equipped bikes only. Does anyone know why and has anyone used this on a newer 990 adv such as a 2012?
Thanks in advance
Alon
Toronto, Canada
2012 KTM 990 Adv-R: the last new 990R in Canada. If Darth Vader rode an adventure bike, this would be it.
alongat is offline   Reply With Quote
Old 02-23-2013, 06:16 AM   #2
alongat OP
alongat's Avatar
Oddometer: 319
137 views and no one here knows?
Alon
Toronto, Canada
Old 02-23-2013, 07:58 AM   #3
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 884
linky
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 02-23-2013, 12:42 PM   #4
alongat OP
alongat's Avatar
Oddometer: 319
Originally Posted by LocuL View Post
linky
Linky no worky
Alon
Toronto, Canada
Old 02-23-2013, 01:37 PM   #5
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 884
Ahhh i´m drunk.
You should provide the link as i don´t knovv vvhich product you refering to.
KTM 530 EXC-R 08
Old 02-23-2013, 02:44 PM   #6
alongat OP
alongat's Avatar
Oddometer: 319
Since the KTM website sucks, here is the same kit from ktmtwins:
http://www.ktmtwins.com/ktm-950-990-...suspension-kit
Sorry, it's actually a 55mm increase. I through a leg over a new standard 2012 990 adv today and I'm shocked to learn that it's actually lower than my 2004 950 adv. I'm looking to replace my 950 with a new 990 and I can't seem to find any 990Rs left so I thought I'd get a standard one and raise it with this kit but alas...it claims to be incompatible with ABS equipped bikes.
Alon
Toronto, Canada
Old 02-23-2013, 02:56 PM   #7
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 884
I vvould say that more stroke on these bikes vvith the right valving should make it perfect for the more racing offroad. Though if you ride it more roadish, it vvould be better of vvith the right valving.
KTM 530 EXC-R 08
Old 02-23-2013, 03:53 PM   #8
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,866
The ABS bikes are low. In order to Raise the LOWER bikes you may also need to replace the chrome sliders as they may be too short and not allow the extra height. I'd check a micro fiche to make sure.
The earlier 950 std and 950 S had different tubes. I have no idea about the newer 990.
For example:
See item #51/52 - ABS bike
http://www.southeastsales.com/fiche_...12&fveh=137500
AXLE CLAMP LEFT ADV. CPL. 09
48600872S1
AXLE CLAMP RIGHT ADV. CPL. 09
48600873S1
1$422.49
1$388.49
Really stinks you can't just buy the tube, at least what I could find in a quick search.
You may also need to modify the side stand and center stand, unless a longer one that comes stock on the bike is an option from KTM.
Going this tall WITH ABS may be a liability thing for KTM, I don't know for sure.
Notice that all the NEW 1190 ADVs are VERY LOW. Lower than the current 990 bikes.
You may also have to make, or replace all brake lines and wiring with longer parts as the LOWER bike parts can't be stretched that far.
Just my thoughts off the top of my head.
Send me an ABS bikes and the kit and I'll see what I can do.....
Good luck.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products.
www.outriderjournal.com FREE STUFF!!
cjracer is offline   Reply With Quote
Old 02-24-2013, 01:37 AM   #9
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,122
I believe brake lines are setting the limits. Also sidestand and center stand will need some lengthening.
Cheers
There is always a reason!!
Old 02-24-2013, 03:18 AM   #10
Sumi
Sumi's Avatar
Oddometer: 1,144
Have a look at this thread
http://advrider.com/forums/showthread.php?t=859977
2005.5 950 Adventure
Old 02-24-2013, 03:20 AM   #11
Sumi
Sumi's Avatar
Oddometer: 1,144
Hm.. in my memories this thread used to be longer, some guys explaining how the raise in the suspension affect the performance of the ABS.. but I can't find it in the thread anymore..
Old 02-24-2013, 10:38 AM   #12
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 415
weren't pre 2009 990/950 fork internals different than post 2009?
I'm aware that later non S 950 models are 210 mm, and 990 ABS are also 210mm, however i think i've read somewhere, that post 2009 (or something close), the internals were different for the ABS 210 models thus required other parts not fully interchangeable with pre 2009 non S models.
Think i've seen this discussed in another thread that i can't find now.
also this kit now on sale by KTM, was long awaited, however does not seem to be possible to choose different spring rates..
690R & 990Adv
Old 02-24-2013, 01:26 PM   #13
alongat OP
alongat's Avatar
Oddometer: 319
The kit offered by KTM is literally comprised of the parts different on a current 990R versus the 990 Standard. No choices of spring rates but I've ridden a 990R ad love the setup it comes with for my riding. I'm tall and I want that extra travel. I'm also likely to go with a 19/17 setup which will bring it back down a bit and likely take care of the centre and side stand issue - Yes, I am aware that centre and side stands will be short once the bike is raised but I just don't understand KTM's disclaimer with respect to ABS equipped bikes.
Alon
Toronto, Canada
Old 02-24-2013, 01:29 PM   #14
alongat OP
alongat's Avatar
Oddometer: 319
This link supports my suspicion: KTM did not test / homologate the "taller" bike with ABS - I'm hoping there's no technical reason for "no ABS" for this kit.
Alon
Toronto, Canada
Old 02-26-2013, 01:20 AM   #15
LukasM
Oddometer: 4,915
For example:
48600872S1
48600873S1
1$422.49
1$388.49
Good luck.
This is the first time I head of the chrome tubes being longer, and I don't think that is correct. I have quite a few disassembled forks in the garage including LC8s and they are all the same, except the newer (06+?) chrome tubes are a bit tapered on top.
The longer internals should fit perfectly in any 950/990 ADV/SE set of forks. The would also fit inside all other 48mm open cartridge fork tubes from KTM dirt bikes, but those have shorter upper tubes, so you have less overlap and less support.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Times are GMT -7.   It's 05:56 PM.
