Old 02-26-2013, 04:20 AM   #16
Deviant666
Present
Deviant666's Avatar
Oddometer: 534
Abs in mine works fine....
Have made the swap since new in my 09 white ABS and everything works fine....not with the above kit but by changing internal components in the original forks...plus ofc a new sidestand and center stand...brakelines weren't an issue even with rox risers....
KTM 990 Adventure White 2009 R specced
ZZR1400 ABS 2008
Deviant666 is offline   Reply With Quote
Old 02-26-2013, 04:38 PM   #17
alongat OP
alongat's Avatar
Oddometer: 1,057
That is exactly what I wanted to hear - thank you very much.
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 01-15-2015, 07:33 PM   #18
WanderBeaver
Wanderer
Oddometer: 134
Originally Posted by alongat View Post
The kit offered by KTM is literally comprised of the parts different on a current 990R versus the 990 Standard. No choices of spring rates but I've ridden a 990R ad love the setup it comes with for my riding. I'm tall and I want that extra travel. I'm also likely to go with a 19/17 setup which will bring it back down a bit and likely take care of the centre and side stand issue - Yes, I am aware that centre and side stands will be short once the bike is raised but I just don't understand KTM's disclaimer with respect to ABS equipped bikes.
That's good to hear.....I was considering getting the 265 height with or without the kit (i.e. without the kit so I can custom pick springs for my 240 lb weight and load carrying capacity as I carry 175 lb of gear including Gobi weight but not rack weight) but didn't want to change the valving since I can install parts but am not confident in doing the valving and could also stand to save the money it costs to re-valve.
WanderBeaver is offline   Reply With Quote
Old 01-16-2015, 12:09 AM   #19
2stroked
Oddometer: 59
How does it raise the rear?
The front is easy with the longer cartridges but wouldn't we need a longer shock shaft?
08 KTM 990 Adv, 10 Beta 400rr, 07 Husky WR 250
2stroked is offline   Reply With Quote
Old 01-16-2015, 12:39 AM   #20
Salzig
Salzig's Avatar
Oddometer: 250
For the rear, there's a spacer under the piston that limit the stroke: thick spacer->short stroke, thin spacer->long stroke.
For the front is more or less the same, but with more stuff involved.
Lifted my '07 ABS up to 245mm 40000km ago, and i'm very happy with it.
Actual rides:
'10 Husqvarna TE310 - '07 KTM 990 Adventure ABS (S'd) - '04 Husqvarna SM450R - '99 YAMAHA R6
"A donkey! A donkey! My kingdom for a donkey!"
Salzig is offline   Reply With Quote
Old 01-17-2015, 11:22 AM   #21
2stroked
Oddometer: 59
Got ya, the shock needs to taken apart
Times are GMT -7.   It's 07:29 PM.
