Old 02-25-2013, 06:09 PM   #1
McVick OP
McVick's Avatar
Oddometer: 234
Need Help - Oil Change IN PROCESS!
Hi,
Need some live play by play help!
Silly question - Does the oil drain plug on the bottom of the engine loosen to the left or right?
I figure it is normal left to loosen thread but it won't budge!! and I would hate to force it the wrong way.
Waiting
Brian
Brian McVickers
'88 Honda NX650, '05 KTM 950Adventure, '01 Land Rover DII
www.overlandjournal.com, www.expeditionportal.com, www.overlandrally.com
McVick screwed with this post 02-25-2013 at 11:14 PM
McVick is offline   Reply With Quote
Old 02-25-2013, 06:13 PM   #2
McVick OP
McVick's Avatar
Oddometer: 234
Never mind
Actually needed impact to get it loose!
Brian McVickers
Old 02-25-2013, 06:14 PM   #3
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,082
lefty loose
normal righty tighty, lefty losse
dogsslober is offline   Reply With Quote
Old 02-25-2013, 06:30 PM   #4
catalina38
Contrarian
Oddometer: 1,681
Careful on the reinstall, these are easily stripped. Check the owners manual for the spec
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 02-25-2013, 06:35 PM   #5
sieg
sieg's Avatar
Oddometer: 2,929
Maybe you shouldn't be changing your own oil
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 02-25-2013, 11:12 PM   #6
Capt.saveaho
Capt.saveaho's Avatar
Oddometer: 313
Yeah no impact. Next time hit the back of the wench with your palm, it should break it loose and not break it. Also it had a crush washer so you don't need to wrench on it, a little RTV wouldn't hurt either.
2007 525exc
2011 990 Adventure with 08 S suspension!!!
13hp road race 50
Capt.saveaho is offline   Reply With Quote
Old 02-25-2013, 11:17 PM   #7
McVick OP
McVick's Avatar
Oddometer: 234
I called it! I think I actually just won a bet with a buddy!
I said, man I hate asking silly questions but better safe than a broken bolt. I bet someone comes back telling me to take it to the shop or something!
Brian McVickers
Old 02-25-2013, 11:19 PM   #8
McVick OP
McVick's Avatar
Oddometer: 234
I agree on the no impact.
This is a fairly new to me bike and first time I have done the oil on it. Apparently the last time it was done the drain bolt was really tightened!
The impact broke it loose but a standard socket put it back.
Brian McVickers
Old 02-26-2013, 04:57 AM   #9
DirtyADV
DirtyADV's Avatar
Oddometer: 2,414
First oil change I did on my own I had a long pipe on the wrench to break free the plug, autorized dealers you know!
Since I have used a torque wrench and never had a problem!
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 02-26-2013, 09:58 AM   #10
Sadlsor
Oddometer: 691
Originally Posted by SFKLR View Post
A better description would be clockwise ("righty-tighty") and anti-clockwise (or counter clockwise) ("lefty-loosey")--and always when facing the bolt.
This.
Then again, when faced with undue / unexpected resistance, I would have come calling on my specialized-knowledge-equipped OC buddies too.
No condemnation... assume NOTHING.
You must be the change you wish to see in this world.
Sadlsor is offline   Reply With Quote
Old 02-26-2013, 10:14 PM   #11
adcolor
Oddometer: 20
My general thought: The plug may have been installed on a warm day and/or warm engine. Aluminum & add in a little gorilla arm and - stuck.
I am a big fan of anti-seize, but anti-seize acts as a lubricant (there are torque de-rate multiplier numbers out there, unique for each brand/model), so you have to be reasonable when you tighten bolts. Crush washers help in that instance.
Do the KTM drain plugs come with a magnet? Eventually installed one in my Triumph. Cheap insurance.
adcolor is offline   Reply With Quote
Times are GMT -7.   It's 08:57 AM.
