Old 02-22-2013, 11:23 PM   #1
Beezer OP
Oddometer: 5,874
soften hard rubber
sooooo... teach an old dog a new trick. I recently ran into a formula for softening age hardened rubber... couple ounces of wintergreen oil in a pint or so of xylene. I just did some intake boots & they went from rock hard to like new flex in 24 hours. I am astounded at how well it worked. the wintergreen is supposed to have a natural plastisizer in it called meythyl salicylate. the test bits did not swell up noticeably and are still pliable after a couple days sitting on the bench. I put another set in mix yesterday & they show improvement, but not as dramatic as the first set. I intend to leave them in until tomorrow & see if they continue to improve. It's the same mix though, so maybe some fresh materials would speed things up.
I got the oil from a local health food store, another source is homeopathic medicine. I hear that sports medicine uses it too.
Beezer is offline   Reply With Quote
Old 02-23-2013, 12:38 AM   #2
Shadow 9er
renegade
Shadow 9er's Avatar
Oddometer: 510
That's a great tip! Thanks!
Shadow 9er is offline   Reply With Quote
Old 02-23-2013, 01:08 AM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,940
It would be a really great tip if the results last. We can often restore the looks of rubber but then it goes back to it's aged appearance after a month. The treatment is needed again. Please report if your method seems to have longer lasting results.
Terrific tip if it stays soft.
---Albert Einstein
Old 03-16-2013, 08:59 PM   #4
Beezer OP
Oddometer: 5,874
so.... it's about 3 weeks since I made the original post. I also treated a 2nd pair of intake boots, and today I installed them. the first set I did had some small cracks (before the treatment) so I used the better set. anyway, all the boots are still soft as when they came out of the mix.
Old 03-17-2013, 08:11 AM   #5
Gramp-Z
Gramp-Z's Avatar
Oddometer: 826
A great tip ! Now if I can remember it for the next time I need it .
Save yourself $5 us my SmugMug coupon b87YWgTeSWxEc
Couple volcanos , stonehenge and some peg scraping
http://www.advrider.com/forums/showthread.php?t=620436
Old Man plays with his Wee
http://www.advrider.com/forums/showthread.php?t=608068
Gramp-Z is offline   Reply With Quote
Old 03-18-2013, 02:17 PM   #6
Gonzodog
Gonzodog's Avatar
Oddometer: 305
That will work with synthetic rubbers used in the fuel system. Other natural rubber type compounds like tires, etc will be excessively swollen by the xylene.
Bikes
"Human culture, the antidote to intelligence." Reg Morrison
Gonzodog is offline   Reply With Quote
Old 03-19-2013, 11:36 AM   #7
zap2504
Dave E.
Oddometer: 629
I got the [wintergreen] oil from a local health food store, another source is homeopathic medicine. I hear that sports medicine uses it too.
Also (from previous posts):
"With nothing to lose, I immersed them in lacquer thinner and checked them twice a day. The things swell up and you would swear that they are ruined, but they shrink back to normal in a few days. Some guys also use wintergreen available at drug stores and make some sort of brew mixing it with the solvent. I just use the lacquer thinner until the boots soften enough and then soak the boots in the wintergreen for a day. As they start to shrink, the wintergreen sucks in to the rubber. The wintergreen at a cheaper price is also known as Thor Tire Prep #12 and available at kart shops to soften racing tires."
zap2504 is offline   Reply With Quote
Old 03-19-2013, 01:07 PM   #8
ttpete
Oddometer: 6,039
The wintergreen oil also is great for use on badly rusted fasteners. We used it on flange joint bolts on steam lines.
Old 05-06-2013, 04:14 PM   #9
Beezer OP
Oddometer: 5,874
bump,,,,
about 10 weeks now & the test boots are still soft. the other set is on the bike & running fine
Old 05-08-2013, 07:03 PM   #10
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,329
Cool tip, thanks for posting!
GreaseMonkey is offline   Reply With Quote
Old 06-25-2013, 08:59 PM   #11
Beezer OP
Oddometer: 5,874
almost 5 months now..... test parts still soft
Times are GMT -7.   It's 04:37 AM.
