Old 02-23-2013, 08:13 AM   #1
pizellu OP
Oddometer: 44
R1100 gs throttle body mixture screws
Hi everyone, just bought an 1100gs, and was wondering
How much turns should the mixture screws on the throttle bodies
Be out? My gs is having a hard time starting, and wasn't wirking good at all.
Furst it was back firing , then i put the screws 2 1/2 turns out and it is better now but still is stuttering when i drive it!!! Any help would be appreciated ;)
pizellu is offline   Reply With Quote
Old 02-23-2013, 08:21 AM   #2
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,821
they are called "BBS"
big brass screws, or something like that.
start here
http://advwisdom.hogranch.com/Wisdom/
or here, the BBS are referred to in these articles.
page 13 of this one ----> http://advwisdom.hogranch.com/Wisdom/TBS4Dv1.0.pdf
http://www.ibmwr.org/r-tech/oilheads...bod_sync.shtml
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 02-23-2013, 10:31 AM   #3
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,916
They are not really mixture screws.
What do you know of the bike's history?
I'd start by putting the screws back where they were and running a full tank of clean gas through the bike with a bottle of injector cleaner in it.
Read up on the valve adjust and throttle-body synch procedure in the Hall of Wisdom (see link provided above or at the very bottom of the page). If you don't know the bike's history, you should plan on doing those maintenance items along with oil changes, check the air filter, change the plugs, and then see how its running. Longer term, you might think about changing the fuel filter and internal hoses in the fuel tank and cleaning the injectors.
Mechanically, apart from normal maintenance items and a careful check of swingarm and final drive bearings, replacing the brake hoses is probably the only thing you need to consider right away.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 02-23-2013, 11:22 AM   #4
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,611
Well, realistically, they are mixture screws in that these screws control the amount of air by-passed around the throttle plates at idle. The amount of air by-passed controls the idle air/fuel mixture and tip in throttle response. The fuel delivered at idle is considered to be constant (controlled by the Motronic) and therefore, idle mixture (and idle RPM) is adjusted by these screws. In my experience, the idle by-pass screws (BBS) have no affect on engine performance once the engine is off idle.
Here is the reference from my REPROM (2001 GS)
Adjust idle speed by turning the air bypass
screws while checking that the carburettors are
balanced.
Idle speed: .......................................1,100 50 rpm
Note the reference to carburetors. The engine is fitted with fuel injection throttle bodies not carburetors. The technical writers got it a bit incorrect.
As for BBS initial settings, those on my model (2001) are at ~1 1/2 turns from seated.
def is offline   Reply With Quote
Old 02-24-2013, 10:49 AM   #5
pizellu OP
Oddometer: 44
Bbs turns
Well at 1 1/2 turns the bike works pretty bad, and smells of petrol! I have ordered a carb sync to tune the throttle bodies first and see how it goes. Funny thing is one day worked fine, and the day after works rubbish !!!??!
Old 02-24-2013, 11:13 AM   #6
Pekkavee
Oddometer: 329
Have you checked the throttle cables. If the throttle cable is stuck in the right hand side it means a lot of trouble. Like this.
Pekka
Pekkavee is offline   Reply With Quote
Old 02-24-2013, 02:32 PM   #7
def
def's Avatar
Oddometer: 10,611
Have the factory sealed (blue paint) idle stop screws been disturbed on the throttle bodies?
If so, you're going to have to start from the beginning and set your throttle bodies, possibly your throttle position sensor and your idle air bleed screws (BBSes).
I would begin by inspecting the throttle body throats for dirt and deposits. Cledan as needed.
Check the air filter and replace as necessary.
Check for vacuum leaks in the intake runners and replace o-rings as needed.
Adjust valve lash. Remove inspect and replace spark plugs as necessary.
Report back.
Old 02-26-2013, 01:40 AM   #8
pizellu OP
Oddometer: 44
Stuck Cable
Pekka
Either you're a fortune teller or I am dumb!!!!
The cable was stuck as you said, and the bike is already feeling better. Though at 1 1/2 - 2 turns the bike works shitty!!. to get it working near to ok I had to turn 2 3/4 turns out, and also there is a huge petrol smell!!!
Old 02-26-2013, 05:02 AM   #9
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,962
Wow guys, it took that long for someone to suggest the cables?
You really need to start simple before going to the extremes. KISS!
Jim
JimVonBaden is online now   Reply With Quote
Old 02-26-2013, 08:59 AM   #10
def
def's Avatar
Oddometer: 10,611
Jim
JVB, you're right. At this point in our collective careers of boxer troubleshooting, I suspect many of us just assume that the OP is aware of the unseated throttle cable thing and has determined all is well.
But, now we still have a poorly running boxer.....
What's next?
Old 02-26-2013, 09:21 AM   #11
Pekkavee
Oddometer: 329
Jim
Ha haa. I did it.
Thanks for the guy who made the picture some time ago. It is not mine.
And I don't remember who did it.
Sorry for using it without your permission.
It is a very good picture.
Pekka
Old 02-26-2013, 09:41 AM   #12
Pekkavee
Oddometer: 329
Petrol smell.
You have a leak somewhere.
Have you looked under the tank. The plate fastening the pump etc. may leak.
Or some fuel hose connection is leaking.
Time to change all fuel hoses maybe.
Don't burn your bike before you find the reason.
Pekka
Pekkavee screwed with this post 02-26-2013 at 10:11 AM
Old 02-26-2013, 01:18 PM   #13
pizellu OP
Oddometer: 44
Question Smelly beemer
The smell is coming from the exhaust, i guess the bike is rich(better than me).
Old 02-26-2013, 08:15 PM   #14
slartidbartfast
Oddometer: 4,916
What's next?
You would certainly hope that someone new to the forum would read back at least four or five threads to the last "Help, my boxer is running like crap ..." question - But if we didn't learn from the last fifty times, why should we expect any different.
Still, I've seen a guy call for a tow truck while a dozen of his buddies stood around trying to troubleshoot his bike, when the only "problem" was that somebody had flipped the killswitch.
If the OPs bike was running ok up until the poinit that it didn't and he (or somebody) had obviously disturbed the throttle cable, the next question becomes: What else was disturbed? If he can undo all the things that were changed, he should get it back to running ok.
Don't know if all 1100's have rev 2.2 of the Motronic brain or whether it might have 2.4 which would benefit from resetting its memory (pull the motronic fuse or disconnect the battery for a minute). Do it anyway - can't hurt.
I wouldn't just drop the cable back into its adjuster but would check for any other clues that something might be out of balance, such as a twisted or kinked cable or grit in the cable wheel groove on the TB.
slartidbartfast screwed with this post 02-26-2013 at 08:36 PM
Old 02-26-2013, 08:27 PM   #15
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,177
First things first.
Remove both screws and clean them. I suspect you will find the tips to be covered in a tar like goo.
I use lacquer thinner to dissolve.
Then dip a Q tip in thinner and clean the passageways thoroughly. It may take several of them before the come out clean.
Gently blow thru with compressed air and screw the screws back in lightly oiling the O ring. Then balance the bodies.
You many find that this solves the problem.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Times are GMT -7.   It's 02:21 PM.
