Old 03-02-2013, 01:40 PM   #16
vintagerider
vintagerider's Avatar
Oddometer: 1,726
Roger04 RT fueling threads- great info there
for sale: 1968 R 69 S-us original condition
vintagerider screwed with this post 03-27-2013 at 10:31 AM
vintagerider is offline   Reply With Quote
Old 03-02-2013, 09:13 PM   #17
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,488
Originally Posted by vintagerider View Post
See Roger04 RT fueling threads. Trust me, approaching this for what it is, a system, has very rewarding results. Not sure if this 1100 is new to you but if it is the best advice is to pull the tank, and go through the entire fuel prep/delivery system (easier then it sounds). Check which vs of the TB's are installed, pre or post '97. Plan on replacing cables, rubber intake manifolds, cleaning TB's, injectors, tank ect. It is actually quite a primitive and simple f.i. system. By beginning with verification of fuel and air delivery you will save much time and grief. Increased performance will amaze. Re-paste the exhaust joints. Only other things likely to cause major perf issues on 1100 are HES (read Donnie's thread), worn out TPS, bad ignition key sub harness, bad main ground and switches. Happy GS'ing.
Did you read what the fix was?
Jim
Old 03-03-2013, 04:35 AM   #18
roger 04 rt
roger 04 rt's Avatar
Oddometer: 837
Jim
Reported fixed in post #8, back a page. Displaced cable. ;) ;) ;)
roger 04 rt is offline   Reply With Quote
Old 03-03-2013, 09:22 AM   #19
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 2,572
If I had a nickel for every time................
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 03-03-2013, 10:35 AM   #20
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 887
Has anyone ever tried using a dab of some kind of silicone, RTV, or something like that to just help make sure the cable stays out while doing routine maintanance?
Something that can easily be removed and cleaned off for cable service and cleaning, but will hold the cable end in place during normal use and service?
Just a thought.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 03-03-2013, 10:38 AM   #21
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 2,572
Just a thought.
Once it has happened to you, you will never forget.........to check
Old 03-03-2013, 10:38 AM   #22
JimVonBaden
"Cool" Aid!
Oddometer: 41,488
Just a thought.
It could be done, but would get in the way during throttle body syncing.
Jim
Times are GMT -7.   It's 11:40 PM.
