Old 02-23-2013, 01:10 PM   #1
woodchuckexc OP
Oddometer: 801
Help H2O pump out in Desert
I am in the desert and my h20 pump is out. Lost oil pressure. Pull oil filter and got pressure back. Question, how far can I safely ride the bike? Do I send someone for the truck? 70 miles away or do I finish the ride? I'm roadside so quick responses are needed. Thanks
woodchuckexc is offline   Reply With Quote
Old 02-23-2013, 01:13 PM   #2
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,382
From everything I have read on this issue you can pull the oil filter like you did and ride. Yes your oil will be contaminated with trace amounts of water so you would not want to leave it that way but the engine will get lubrication so you could ride.
I would be gentle and get out of the boondocks where you have other options.
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 02-23-2013, 01:34 PM   #3
charlie264
charlie264's Avatar
Oddometer: 8,367
+1, change oil asap...and pump seal when you can.
Old 02-23-2013, 03:54 PM   #4
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,435
Wow....3 minute response time. I know we can do better..
Bgunn is offline   Reply With Quote
Old 02-23-2013, 11:14 PM   #5
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,170
Wait until we get outsourced !!
Building a KTM 690Exc - the ultimate dirt tourer
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally, 2012 KTM Adv990
Vicks is offline   Reply With Quote
Old 02-24-2013, 01:46 AM   #6
Peanuts
Peanuts's Avatar
Oddometer: 1,698
Run it with the radiator cap off if you can. No coolant pressure so it wont blow past the seal.
But dont do it if dirt can get in.
And coolant will evaporate as it is no longer a closed system, so check it a few times a day.
Peanuts is offline   Reply With Quote
Old 02-24-2013, 10:44 AM   #7
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 955
Wouldn't the engine speed over the water pump make a very significant quantity of coolant to come out?
I see your point about the pressure relief over the worn seal, yet i'm curious about side effects of such improving solution and if they're tolerable or not.
690R
Old 02-24-2013, 12:33 PM   #8
Peanuts
Peanuts's Avatar
Oddometer: 1,698
Done it on the trail with enduro bikes.e.g. low tech radiator repairs that can hold water but not stand pressure.
Old 02-24-2013, 03:21 PM   #9
charlie264
charlie264's Avatar
Oddometer: 8,367
Relieves the pressure but you need water, i.e. keep topping up. The steaming loss is counter intuitive, as the coolant boils its actually removing more heat from the engine due to latent heat.
Old 02-26-2013, 08:31 AM   #10
woodchuckexc OP
Oddometer: 801
Thanks for getting back to me. So I pulled the oil filter, topped off the oil, made sure I had plenty of coolant and rode the piss out of her. She's fine. From now on I will be stashing a stainless oil filter somewhere on the bike for emergency use. I will continue to run the paper ones as they are a good indicator that your water pump is going.
Old 02-26-2013, 08:48 AM   #11
killurtv
free range moron
killurtv's Avatar
Oddometer: 640
I love this site!!!! +1 on the stainless filter for emergencies, that is my routine as well. Nice job everyone!!!!,
one day I will learn, until that day... fuck it.
2001 HONDA XR650R
killurtv is offline   Reply With Quote
Times are GMT -7.   It's 03:42 AM.
