Old 09-19-2008, 07:32 AM   #1
Gobear OP
Oddometer: 21
Honda XR650L Larger Gas TANK
Hello Group,
From searching the web I've found three larger gas tanks that fit the XR650L.
IMS
Acrebis
Clark
Any advise on which brand is better would be helpful.
Ride safe
Gobear
Gobear is offline   Reply With Quote
Old 09-19-2008, 07:51 AM   #2
Dirtgeek
Guest
Oddometer: n/a
hi gobear and welcome. i'm running the clarke 4.7 on my L. no problems. i fabricated some struts out of aluminium for better stabilization instead of the wire cross-piece thingy that came with the clarke. the range is pretty substantial now.
good luck
al
Old 09-19-2008, 08:44 AM   #3
mcnut
Oddometer: 1,153
I have the IMS. Fits OK with some minor rubbing with the cylinder head bolts. Probably has 5000 off-road miles on it now.
Having said that, I have always been impressed with the Acrebis tanks I have seen and owned.
Bruce
mcnut is offline   Reply With Quote
Old 09-19-2008, 10:33 AM   #4
KHVol
Oddometer: 2,112
Had a Clarke on my L for 8 years now....never had a problem. Will continue to buy Clarkes. Have seen other brands have problems.
KHVol is offline   Reply With Quote
Old 09-19-2008, 10:47 AM   #5
truck6driver
The Fireman
truck6driver's Avatar
Oddometer: 5,824
Running an IMS 4 gal tank. No leaks or problems other than discoloration from the fuel over the years. It was white but is kinda tan now. it has been on the bike for over 10 years. I did have to replace the gas cap because the rubber gasket/vent ripped this year and I could not find just the gasket. I think that $12 in over a decade is pretty good. If I replace it I will go back with an IMS. I just cheap and don't want to spend the $$$.
Ray
truck6driver is offline   Reply With Quote
Old 09-19-2008, 01:02 PM   #6
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 10,224
IMS
Removed the stocker,and just bolted up the IMS 4 gallon.Used OEM petcock,and frame foam.I would like to put on thicker brakets then the ones that came with the tank,but haven't had any problem with the IMS brackets after,3,000 miles.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
"French fry when you shoulda pizza'd,your gona have a bad time".
AWM is offline   Reply With Quote
Old 09-19-2008, 01:03 PM   #7
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 10,224
Then got the XR's only stickers.
Old 09-19-2008, 02:46 PM   #8
Papa Pete
RIDES RED
Papa Pete's Avatar
Oddometer: 618
Send a message via Skype™ to Papa Pete
duct work
Honda had an issue with heat and put the wings on the stock tank.
I went with the Acerbis for that reason. Hey they built their tank with the wings as more fuel space. There are some that can't figure out how to mount the tank with the limited instructions that come from Acerbis, but don't let that stop you from considering them for your tank replacement.
Don't listen to the pin heads that couldn't figure out how to mount it and cut the tabs off the frame to make it work. The tank will fit and will come on and off quite smoothly once you get it on. The tank is really made well and the mounting hardware holds the tank in place.
Papa Pete is offline   Reply With Quote
Old 09-19-2008, 09:28 PM   #9
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 6,451
Cut the tabs off the frame? You are kidding, right? What peanut would do such a thing? The Acerbis is the easieast thing to fit, dead simple so even a moron (me) can do it.
God help them if they do their own servicing.
GodSilla is offline   Reply With Quote
Old 09-19-2008, 09:32 PM   #10
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 12,357
I've read that the Acerbis is a tighter fit on the XR-L because of the additional stuff mounted to the frame under there.
It is a super fit on the XR600R and plenty haven't had any fitment issue on the XR-L.
I've had Clarke, IMS, and Acerbis - I rank Acerbis tops, and Clarke a close second. IMS only took third because of what I considered a cheesy petcock setup (on a DR650 tank)
'12 VFR 1200 . '13 TR650 Terra . IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 09-19-2008, 11:02 PM   #11
Flycaster
Flycaster's Avatar
Oddometer: 25
Send a message via MSN to Flycaster
Originally Posted by Gobear
IMS
Acrebis
Clark
I have a Clarke 4.7 gallon on my 650L. No problems yet. Looks good and it was an easy installation.
2008 xr650l.
Flycaster is offline   Reply With Quote
Old 09-20-2008, 10:37 AM   #12
truck6driver
The Fireman
Oddometer: 5,824
I now nothing about the DR but my XR uses the stock petcock on the IMS tank. Fit was just like the stock tank.
Ray
Old 09-20-2008, 12:21 PM   #13
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 12,357
Ray
The IMS DR650 tank comes pre-drilled for the oem vacuum two-stem petcock, yet it doesn't fit due to interference with cooling fins.
They do provide a petcock, but it's single-stem and leaves lots of room for the gasket to pinch, squish, and leak.
Old 09-20-2008, 02:40 PM   #14
lewismedlock
#lewismedlock
lewismedlock's Avatar
Oddometer: 11,555
Acerbis tanks come with their own dual petcocks. I've got the one that is almost 6 gallons. It was easy to install, but you have to relocate or raise your stock turn signals. It has held up well.
I fairly anal about bike maintenance and keeping things tight. A month or two after I posted this my Acerbis began to leak near the backbone, so I switched to a Clarke. It holds a gallon less, but it feels better between the knees.
lewismedlock screwed with this post 06-24-2009 at 04:02 PM
lewismedlock is offline   Reply With Quote
Old 09-20-2008, 03:13 PM   #15
Papa Pete
RIDES RED
Papa Pete's Avatar
Oddometer: 618
Tab Removal
Yes if you check on thumper talk, there is advice to cut the tabs off the frame. I didn't and havn't had any problems. Yes you do have to relocate stock turn sigs on the front end. I went with the Acrbis hand guards with the turn sigs built into them.
Lewismedlock,
Is that the taxi driver bead seat your running there?
How well do rate them for long distance riding? With the bigger tank, I don't have to stop riding for about 200 miles before refuel and my ass would like
something between it and the seat.
Times are GMT -7.   It's 11:01 PM.
