Old 02-25-2013, 10:31 AM   #1
Azmontana OP
Oddometer: 31
Regulator Rectifier failure 950 Adventure?
Was wondering whether this is a common problem as mentioned in HOW for the SE?
Going to Morocco in April and I'm taking the usual spare parts, was wondering if anyone has had a failure of the reg rec on there 950 Adv?
Azmontana is offline   Reply With Quote
Old 02-25-2013, 10:54 AM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,916
I had a failure on my 990Adv
Since then I realised R/Rs are expendable and should be replaced preventively.
They seem to expire on all bikes, including Hondas. Good option is the new Shindengen, carried on Yamahas R6 as OEM part.
Cheers.
Old 02-25-2013, 10:54 AM   #3
mousitsas
mousitsas's Avatar
Oddometer: 2,749
Not me (so far) but plenty others have lost an R/R.
Apart from taking a spare (essential!) relocate your current one, or wrap your exhausts (even better) with exhaust wrap. Removing some heat in Morocco will do good to you too apart from your rear suspension and R/R
Of course I assume temperatures of over 30C in Morocco in April, which might not be true.
Old 02-25-2013, 10:54 AM   #4
spafxer
spafxer's Avatar
Oddometer: 2,605
SE problem has been due to the mounting location near the exhaust pipes...
Less reports of problems on the ADV due to cool mounting location. More problems of the connectors corroding. Keep them clean and protected and the RR should be fine.
Now let's talk fuel pumps
spafxer is offline   Reply With Quote
Old 02-25-2013, 11:05 AM   #5
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,209
My 9 year old regulator has about 48000 miles on it.
So far, so good- knock on wood.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 02-25-2013, 12:22 PM   #6
Azmontana OP
Oddometer: 31
Thanks for the replies guys, anyone fitted one of these?
http://rickselectrics.com/proddetail...BBZHZlbnR1cmU=
Old 02-25-2013, 01:13 PM   #7
charlie264
charlie264's Avatar
Oddometer: 8,262
Not that one but the run of the mill Mosfet, solid state...the future.
Old 02-25-2013, 01:17 PM   #8
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
I have one on my SE. Plug and Play. Lucky I had it here in SA when my stock one fried.
DeepInIt is offline   Reply With Quote
Old 02-25-2013, 09:01 PM   #9
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,396
Lost mine quickly...
I lost my R/R after about 3k miles on my 950 Adv. It was within 2 weeks after a hot ride in Death Valley where outside temps were 120 degrees. I don't think it was simply a coincidence. Excessive heat is the weakness of these bikes. I spent a lot of time rock crawling on this ride and my speeds were down for most of the ride. There wasjust not enough air circulation through my bike.
My battery ended up going south not much later on too.
Relocating the R/R is a plus. Bring extra seals for the slave cylinder. They are heat sensitive too.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is online now   Reply With Quote
Old 02-26-2013, 02:32 AM   #10
LukasM
Oddometer: 5,415
Yes people have fitted them, and I already know of at least one low mile failure. Chinese part.
Get the proper Shindengen MOSFET for less money, it's OEM quality used on many top of the line Germand and Japanese bikes.
With that installed I would not bother with carrying a spare.
Old 02-26-2013, 02:36 AM   #11
mousitsas
mousitsas's Avatar
Oddometer: 2,749
Apart from the wattage (of course) are all R/R interchangeable? That is to say, are all 3-phase bike generators similar in their voltage output?
Old 02-26-2013, 04:05 AM   #12
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,470
This isn't a definitive answer, but every bike generator I've ever measured has had an output of about 50-75 V AC, when open circuit.
I think all RR do essentially the same job, if you can get it to physically fit, and if it can handle the wattage, I would expect them to be interchangeable. However I'm no expert so don't take my word for it!
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 02-26-2013, 04:05 AM   #13
charlie264
charlie264's Avatar
Oddometer: 8,262
Pretty much, it’s all about the design. I.e. a two stator impute wouldn’t be ideal as the lc8 has three…and the peak voltage/amps may be too high for a less robust one.
Old 02-26-2013, 04:33 AM   #14
mousitsas
mousitsas's Avatar
Oddometer: 2,749
This is good to know. I have an R/R from a yamaha thunderace that might do the job as a spare.
Old 02-26-2013, 05:14 AM   #15
charlie264
charlie264's Avatar
Oddometer: 8,262
Look at the part numbers, might even be the same.
Times are GMT -7.   It's 06:39 PM.
