Go Back   ADVrider > Riding > Regional Forums > Australia
Old 02-25-2013, 06:38 PM   #1
Adrian V OP
Oddometer: 520
Tubliss for Oz desert conditions?
A bloke I know has been running Tubliss for Oz desert trips (G'day Den )and reckons they are the dog's watsits. He has found them reliable and the extra traction a real boon in deep sand conditions (including the Canning).
I have always just used Bridgestone UHD tubes, with no probs, but the extra traction in sand has me interested, as sand riding is not my forte.....
This review seems to rate them as well: http://advrider.com/forums/showthread.php?t=831867
At the moment I'm thinking that I should try Tubliss and just carry a couple of tubes in case it all goes pear shaped, but I'd welcome some input from anyone else using Tubliss in Australia and any suggestions for other set ups that work well (such as some mousses)?
Cheers,
Adrian
Adrian V is offline   Reply With Quote
Old 02-25-2013, 06:44 PM   #2
geoz
Orange rules
geoz's Avatar
Oddometer: 238
I have not tried them myself, from what I hear there is a risk that inner tube does nto seat well with used tyres. But the guys I ride with who use them seem happy enough. They did remark that you can run very low tyre pressures which you really can't do any other way.
I've just installed a mousse in the front & found that less of an issue than I initially thought it would be, so I'll go with that. the rear will go in with a new tyre on the weekend.
cheers
hg
geoz is online now   Reply With Quote
Old 02-25-2013, 07:11 PM   #3
geoz
Orange rules
geoz's Avatar
Oddometer: 238
one more thought: not sure I'd run ultra low tyre pressures at speed, the risk you pull the tyre off would increase.
with the mousse you need to ensure you kepp it lubed, there is special mousse for high speed hot conditions
cheers
hg
Old 02-25-2013, 07:44 PM   #4
Adrian V OP
Oddometer: 520
Which mousse?
I would have thought that the continuous bead in Tubliss would stop the tyre from unseating more effectively when at low psi? I have read a few reviews from people using Tubliss in Baja, with mixed results, some people swear by them, others swear at them (including Neduro).
Do you know the name of the mousse that is recommended for high speed hot conditions?
I am thinking that I would increase the psi to 10 - 15 for general higher speed desert running and then just lower it down for the really deep sand, best of both worlds perhaps?
Old 02-25-2013, 10:28 PM   #5
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,505
The guy I bought my KTM 525 off, up in the golden triangle had tried them and had them fail on a trip into Laos. He junked them on the basis that he needed 100% reliability in the remote areas. I understood what he was about when I had a 5 day wait to get wheel bearings sent to me. I'd love to not have to carry a whole heap of tubes in the remote stuff.... but I can't see that in my near future
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is offline   Reply With Quote
Old 02-25-2013, 10:30 PM   #6
Woody2627
Skinny Decaf Latte Thanks
Woody2627's Avatar
Oddometer: 1,126
I think I read somewhere that mousse aren't legal on the road, is this true or am I off with the pixels again?:
Woody2627 is online now   Reply With Quote
Old 02-25-2013, 11:11 PM   #7
geoz
Orange rules
geoz's Avatar
Oddometer: 238
Probably not, says off road use only on mine ;)
cheers
hg
Old 02-26-2013, 12:07 AM   #8
MOLAHS
Sisyphus
MOLAHS's Avatar
Oddometer: 1,644
Tubliss
If you google "tubliss" you'll get a lot more information from the US including a number of ADV sites.
The Myth of Sisyphus
MOLAHS is offline   Reply With Quote
Old 02-26-2013, 12:25 AM   #9
Warin
Retired
Oddometer: 2,327
Humm sounds like another mouse type thing then?
The Dakar racers use them, the suported ones change the mouse DAILY ... if they are that reliable I won't be buying one. Rather fix a flat than have to throw money (mouses) away.
Warin is offline   Reply With Quote
Old 02-26-2013, 12:38 AM   #10
Adrian V OP
Oddometer: 520
Different conditions in the US?
I did google Tubliss, but the majority of reviews reflected on using it in woods riding, hare scrambles and the like and this type of useage seems very different to heading out bush on an unsupported desert trek, where reliability is paramount.
Re the failures mentioned, it seems that Tubliss has now been 'improved' and the beadlock liner is a lot stronger than it used to be.
Old 02-26-2013, 01:58 AM   #11
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,929
Just remember the real advantage of Mouses is that they provide the extra grip of low pressure without the risk of pinching of tearing out the valve.
They are not supposed to be a puncture proof tube, the can and do disintegrate, and are no where near as long lasting as a good tube.
If you don't need the grip that bad, then go for a super heavy duty tube with a bit more air in it, that would be the best for reliability.
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 02-26-2013, 07:12 AM   #12
"A"
numbum
"A"'s Avatar
Oddometer: 380
Adrian, my brother uses mousse on the front pretty often these days. He rode a DRZ back from Tassie with one. The rear is more likely to cause issues especially high speed running and on tar - he melted one down in the '07 Aus Safari. We reckon we will use Michelin Mousse at least in the front tyres when going down the CSR etc later this year.
"A" is offline   Reply With Quote
Old 02-26-2013, 10:42 AM   #13
geoz
Orange rules
geoz's Avatar
Oddometer: 238
Dakar racers also change the tyres every day, is that also a sign of lack of reliability? The guys merely err on the side of caution because they can. Mousse can disintegrate quickly if it overheats - how often do you ride hours on end at full throttle through the desert?
Some of the guys on dirtbikeworld have been using mousse for many months and changed many tyres in the meantime. Reliabllity does not seem an issue if maintained / lubed properly. Neither is weight btw.
It might still not be the right solution for you, simply an option.
cheers
hg
cheers
hg
Old 02-26-2013, 06:09 PM   #14
Chop Chop
Hector erector
Chop Chop's Avatar
Oddometer: 1,686
Cheers,
Adrian
I used one for the 2010 OCR. Travelled about 5500km with no problems. Ended up going out to Birdsville. I lowered the pressure to about 12psi for big red but mainly ran it at 25psi. This was on a 800gs with 1.6in front. You can run them down very low and have read somewhere that Ballards had slashed the sidewalls to see how they would perform, apparently all good.
I also ran 'Ride on" puncture sealant as well, but it cause balancing issues at low speed (60 and below) alright at highways speeds though.
It is critically important to check the inner bladder pressure daily to maintain the 100psi. If you puncture the inner bladder, you'll be on the deck before you know what happened.
I have the old style liner(red), and it is easy to nick it when changing tyres as I did. This was after the trip and first tyre change.
As the system is designed to reduce unsprung weight by eliminating tubes, it may be easier and cheaper to just seal up the rim and run rimlocks with tubeless type tyres.
I don't think I would run it again for the type of trip I did, knowing what I know now. Ignorance is bliss. But for enduro riding, I probably would.
My 2c anyway.
If you don't want the piss taken, stop giving it away!
Chop Chop is offline   Reply With Quote
Old 02-26-2013, 06:30 PM   #15
BergDonk
BergDonk's Avatar
Oddometer: 3,923
I had one in the front of my Berg and really liked it, until.........
The wire bead failed suddenly mid corner on the tar and I did a head plant. Broken helmet, concussion, lots of bruises and swelling and night in hospital with potential compartment syndrome.
The wire bead for no apparent reason let go and tore the side out of the high pressure tube and the tyre peeled off the rim bead and went flat almost instantly. Its a catastrophic failure with no warning.
Maybe I was unlucky, dunno, but Tubeliss did not respond to any of my inquiries. All I wanted to do was let them know it failed, but no response at all. It was suggested elsewhere that I must have damaged it when fitting the tyre. Maybe, but it was the third tyre I used and there was no sign of bead damage other than where the wire let go.
The bottom line is that if they go, it goes instantly.
I still have one in the back of my trials bike though, but not in anything else anymore.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Times are GMT -7.   It's 09:35 PM.
