Old 02-25-2013, 07:45 PM   #1
Ride4Coffee OP
Ride4Coffee's Avatar
Oddometer: 210
Bluhduh EDIT! 90mm Bolts Found!
EDIT: 90mm bolts are available again! The thread is here: http://www.advrider.com/forums/showthread.php?t=875146.
Original post:
I picked up a Kaoko from another inmate here for my '05 R1200GS. As seen in many posts, I need the 90mm retaining bolt (part # 32717698103). However, I called Bob's BMW, only to learn that the bolt is discontinued!
Even McMaster-Carr doesn't carry a bolt that will fit. Does anyone have any suggestions? Tomorrow, I'm calling Bike Bandit and A&S Cycles, as they both listed the part online, but no promises that it is in stock.
Perhaps it'll have to go back on the FM...
IBA# 57940
Need the 90mm bolt for your Kaoko?
Ride4Coffee screwed with this post 05-23-2013 at 05:08 PM Reason: Bolts found.
Ride4Coffee is offline   Reply With Quote
Old 02-25-2013, 08:08 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,527
I have installed a few with the short bolt. Have you tried it?
Also, by all means, do not stop with Bob's (who is by far NOT the only authority on all things BMW). Call Mortons and Max BMW and see what they say.
Also, if still no luck, try fastenal. http://www.fastenal.com/web/home.ex
Jim
Old 02-25-2013, 08:29 PM   #3
Ride4Coffee OP
Oddometer: 210
80mm too short
Thanks for the tips, Jim! I definitely tried the 80mm bolt, making sure the pieces were lined up, no strippage, no extra space, etc.
It turns out the 80mm bolt sank 10mm into the threads inside the handlebar (the precious ten mils that I lost with the Kaoko).
I found a few close options at Fastenal, but not quite the match. Still checking all their nooks & crannies.
Mortons and Max were closed today. They're definitely on my list for tomorrow!
Old 02-25-2013, 08:31 PM   #4
UAS
Oddometer: 106
Same here. Instructions said to use a different length bolt. I ordered one but that was months ago. I asked about it a couple of times since, the last time probably 6 months ago, but it was still back ordered. I used the bolt that came with it; seemed to have more than an adequate amount of thread. Actually I had totally forgot about it until reading this thread.
2012 GSA Triple Black
UAS screwed with this post 02-25-2013 at 08:37 PM Reason: Grammar
UAS is offline   Reply With Quote
Old 02-25-2013, 08:59 PM   #5
Ride4Coffee OP
Oddometer: 210
Sanity check
Okay, I figured that I must be missing something here, so I revisited the situation. I took it all apart to see what could be affecting the bolt.
The bolt by itself has plenty of length through the Kaoko. I reinstalled it, without the washer for the handguard, and Voila! It seats:
As you can see, the washer has significant depth to it:
Normally, I'd see about going without it (even though it's not aesthetically pleasing or symmetrical). However, the bolt hole in the handguard is just a fraction smaller than the bolt head. So the washer is actually important:
Someone, somewhere has a 90mm bolt, I'm sure. More to follow tomorrow.
Old 02-25-2013, 09:39 PM   #6
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,127
A few months ago I spent a considerable amount of time to find a 90mm bolt off the shelf.
I struck out at Canadian dealers as well as my industrial fastener suppliers.
The only alternative was have a machine shop make one up. The owner was not willing to spend the money.
If you find a source let us know.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 02-25-2013, 10:04 PM   #7
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,159
Can you order one from Kaoko? I see this on their web site.
please check your OEM Bar End Weight central retaining bolt prior to ordering. If 80mm long part CCF400-08 is required. If 90mm long part CCF400 is required).
Marc
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is offline   Reply With Quote
Old 02-26-2013, 03:57 AM   #8
wbrisett
hmmm....
wbrisett's Avatar
Oddometer: 320
M12x90MM??
I think this is a stock M12x90MM countersunk bolt. Anybody know for sure?
Wayne
2011 BMW R1200GS Adventure (back to one bike)
wbrisett is offline   Reply With Quote
Old 02-26-2013, 04:11 AM   #9
jdbalt
Oddometer: 195
Options
http://www.shop4fasteners.co.uk/acat...l_DIN_7991.asp
http://www.ebay.co.uk/itm/M12-X-90-C...item51850f6e97
Both hex head. Torx really makes it tough.
jdbalt is offline   Reply With Quote
Old 02-26-2013, 04:16 AM   #10
jdbalt
Oddometer: 195
Another
http://www.allfastsolutions.co.nz/pd...0Stainless.pdf
Call them. Maybe they sell you a couple. Instead of 25
Old 02-26-2013, 04:32 AM   #11
Hennepinboy
Have battery will travel.
Hennepinboy's Avatar
Oddometer: 457
If I recall properly the tread pitch on the bar ends is 1.50 threads per mm fine thread. 1.75 TPMM coarse thread appears to be the most common in the M12.
I have been also searching for M12 X 1.50 70mm to 90mm countersunk flat head bolt either torx or hex for mounting barkbuster type hand guards on a R1200GS, I will watch this posting close, maybe someone will come up with a source for this odd size.
I am currently running a Kaoko throttle lock on a 08 R1200GSA and found the stock bolt long enough to secure the stock plastic hand guard using the aluminum bushing.
The Minnesota Airmarshal
Hennepinboy screwed with this post 02-26-2013 at 10:59 AM Reason: spelling
Hennepinboy is offline   Reply With Quote
Old 02-26-2013, 05:36 AM   #12
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,855
Anybody looked for a 100mm length and then cut to suit?
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 02-26-2013, 05:48 AM   #13
Ride4Coffee OP
Oddometer: 210
Originally Posted by Hennepinboy View Post
If I recall properly the tread pitch on the bar ends is 1.25 threads per mm fine thread. 1.50 TPMM coarse thread appears to be the most common in the M12.
The stock bolt is:
32 71 7717802 COUNTERSUNK HEAD SCREW M12X1,5X80-MKL
I wonder if the 1.5mm is comparable to any other designated tpmm, like a DIN.
I figure the mounting part must be stuck down just a little too far.
The search continues...!
Ride4Coffee screwed with this post 02-26-2013 at 05:55 AM
Old 02-26-2013, 07:36 AM   #14
Ride4Coffee OP
Oddometer: 210
supply update
Nothing at Bob's, Max's, Morton's, or Bike Bandit.
How difficult would it be to rethread a bolt of a different pitch? Or maybe put threads on some bar stock?
Old 02-26-2013, 07:45 AM   #15
Dexter2811
Dexter2811's Avatar
Oddometer: 298
Sure it is a 12x1.5 90mm bolt? I could get you a pair of stainless steel allen head countersunk bolts here in Arg. and mail them... In fact I could get quite a few, they are unexpensive if you want to sell'em or just give'em for free up there...
2010 NX4 Falcon, 440cc Wiseco Big Bore, Stage II Hotcams, XR400R clutch, XR600 40mm Mikuni carb, MX handlebar (Wirtz), Custom exhaust.
Dexter2811 is offline   Reply With Quote
Times are GMT -7.   It's 12:18 PM.
