Old 02-28-2013, 09:30 PM   #31
Ride4Coffee OP
Ride4Coffee's Avatar
Oddometer: 212
Roger that!
Originally Posted by JimVonBaden View Post
Send it to me. If I can get it to work, I will swap bolts with you and give the Kaoko back.
Jim
PM on the way!
Ride4Coffee is offline   Reply With Quote
Old 03-01-2013, 07:53 AM   #32
wbrisett
hmmm....
wbrisett's Avatar
Oddometer: 321
Wow...
So, around the corner from me is a bolt company. I have been able to acquire pretty much any bolt or screw there for the past several years. I took the bolt off my 2011 GSA and told him I needed one that was 90 mm instead of 80 mm in length. So, off he went into the back and came back 10 minutes later and told me he didn't have anything similar to it. Wow... Talk about a hard bolt to track down.
2011 BMW R1200GS Adventure (back to one bike)
wbrisett is offline   Reply With Quote
Old 03-01-2013, 10:18 AM   #33
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,875
BTDT see my post #6
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 03-01-2013, 10:24 AM   #34
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,837
I had the same reaction at SoCal Bolt.
I can weld one up for anyone, but I can't weld stainless so it will have to be painted.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 03-01-2013, 12:25 PM   #35
ACD
old nOOb
ACD's Avatar
Oddometer: 271
Originally Posted by Osmin C View Post
All, is this only a pre 2006 issue? Would I have this issue on my 2012 GSA?
My 2011 GSA uses the 90mm. If you take off the alu spacer that holds the handgard, then 80mm is enough but since the Kaoko is longer than the OEM bar end weight, you need a longer bolt.
Thanks, Kaoko and re-sellers, for offering this kit for the 2011 GSA and not mentioning the need for the longer bolt beforehand.
ACD is offline   Reply With Quote
Old 03-02-2013, 08:19 PM   #36
Ride4Coffee OP
Oddometer: 212
We may have a winner
Gentlemen (and I use that term loosely),
I'm in comms with a bolt shop in the UK who is looking into this. If they can do it, I'll turn the bolts around (at cost) here in the flea market.
Simply put, stand by...
Old 03-31-2013, 02:28 PM   #37
Ride4Coffee OP
Oddometer: 212
Stand by is over! Got my first shipment of bolts in, and we're good to go! Kaoko is installed and works fine. Look for a Flea Market thread soon. PM if interested, and I'll forward you the link when it's created.
WooHoo!
IBA# 57940
Need the 90mm bolt for your Kaoko?
Old 03-31-2013, 03:31 PM   #38
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,837
This is all rather odd.
I got two Kaoko just a week or so ago for BMW R1200GS, one for 2006 one for 2008, they are the same.
They both bolted straight on. Stock handguards, stock bolt, stock washer/ spacer thing.
The Kaoko looks to be exactly the same size as bar end weight, so why would you need a longer bolt?
Old 03-31-2013, 05:15 PM   #39
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,243
James,
Some of the R1200Gs bikes have a slightly deaper threaded insert. I have seen them both ways. I took mine off and comparred it with Jason's and both of ours were deaper in. Both of us have 05 bikes, though I have seen newer bikes with this issue as well.
Jim
Old 03-31-2013, 06:43 PM   #40
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,837
So the ones with deeper inserts come with a longer bolt?
Old 03-31-2013, 08:49 PM   #41
JimVonBaden
"Cool" Aid!
Oddometer: 52,243
Not necessarily. The Kaoko is just a bit deeper than the standard bar end weight for the early bikes, so it won't work with the stock 80mm bolt.
Jim
Times are GMT -7.   It's 12:58 AM.
