Old 03-01-2013, 11:01 AM   #16
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,834
Good idea . . . I made my 1/4" X 1" aluminum rear support over an inch 1 3/4" higher. I should get my SE fender and 2nd brake line soon. This hybrid fender w/OEM fork guards is not designed for sticky mud . . . Only occasional vey light mud. If I do run into the sticky stuff . . . I will remove the fork guards etc.
The 800GS fender broke on a dry dirt road . . . Which is it what I was referring too. You definitely do not want a low fender in the mud. The Adv OEM fender sould be OK in dry conditions.
800GS fender snapping:
Yikes . . . Raising a low fender wouldn't help in this mud!
Motorcycles . . . my Happy medicine.
Live to ride . . . ride to Live . . . just like breathing to Live . . .
“One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure.” – Steve McQueen
mcmann screwed with this post 03-02-2013 at 10:32 AM
mcmann is online now   Reply With Quote
Old 03-02-2013, 08:22 AM   #17
Orangecicle
Orangecicle's Avatar
Oddometer: 2,572
Originally Posted by RedRupert View Post
Thanks for the link.
Your bikes looks like a 2004: seat (by 2005 they had a stepped seat) and the heat shield (looks as if yours stops at the frame - 2005s extended back further). If you're interested to know if your suspension is 210 or 230 travel, you can measure it with no load on the front forks - just measure from top of axle clamp to bottom of dust seal.
Well, I measured my travel with no load on the front forks, and it measures out at about 9.25 inches, which converts to 235mm??? So, I'm guessing that my bike has forks from the original '03-'04 bikes? It's at least 230mm, for sure. I always knew the dang thing was tall!!!
My bike is weird. The bike was obtained originally by a KTM rep. who was responsible for promoting the brand to dealers. I say "obtained" because he got the bike from KTM but didn't actually title it in his name for a couple of years, which greatly lowered the bike's cost to him. He traveled on the bike and displayed it at bike shows. He had access to anything he wanted from KTM, so if he wanted taller travel they just bolted it up for him. The bike came with everything KTM was selling at the time, including a Corbin seat that KTM was promoting.
I thought the stepped seat came along with the 2005.5 bikes. Dunno.
Orangecicle is online now   Reply With Quote
Old 03-02-2013, 08:30 AM   #18
Orangecicle
Oddometer: 2,572
Originally Posted by mcmann View Post
Good idea . . . I made my 1/4" X 1" aluminum rear support over an inch higher. I will remove the rear plastic fender material from behind my support when I eliminate the cross-over brake line. . . .
Just a suggestion, but I wouldn't put that brace on. The idea of removing the crossover brake line is to remove something that might one day fall down and grab the front tire. It's OK to destroy a front fender -- no big worries there. But, if what happened to LostRider happened on pavement resulting in a stoppie at speed. . . . That would be bad. So my goal was to remove anything that might grab the tire. I think your brace could grab the tire. So, I just offer the suggestion that you might not want to put that on. Raise the low fender and call it good. That's my plan.
Old 03-02-2013, 10:40 AM   #19
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,834
You make a very good point.
I made sure my rear support could not make contact with the tire. When it is bolted tight (w/lock-tight), it makes contact with the caliper bracket which keeps it in place. I loosened the bolts to check clearance . . . The bracket hits the lower shock housing and will not allow it to rub the tire.
Loose position:
I have good clearance when all the way forward if the bolts came loose and fender snapped from mud etc.
The plastic fender supports also help hold everything in place:
Old 03-02-2013, 10:43 AM   #20
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,806
You've clearly given this a bit of thought, and to each their own.
But I wouldn't run it. Gives me the heebie-jeebies just looking at it.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 03-02-2013, 11:01 AM   #21
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,228
Originally Posted by Pyndon View Post
2003 Adventure = 230mm travel
2003 Adventure 'S' = 265mm travel
2004 Adventure = 230mm travel
2004 Adventure 'S' = 265mm travel
2005 Adventure = 210mm travel
2005 Adventure 'S' = 245mm travel
2006 Adventure = 210mm travel
2006 Adventure 'S' = 245mm travel
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 03-02-2013, 11:41 AM   #22
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,834
After second thought . . . .I don't really need this support for fork guards . . . So I wacked it off . . . Then I went outside and cut my fender off with only enough material to help support the fork protectors.
Thanks again . . . Better to be safe . . . Which was my main intention when I ordered the 2nd brake line.
mcmann screwed with this post 03-02-2013 at 04:43 PM
Old 03-02-2013, 11:57 AM   #23
FakeName
FakeName's Avatar
Oddometer: 1,806
oh. Well...
2014 500EXC Black
Old 03-03-2013, 10:43 AM   #24
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,834
Finished.
My order came in @ 6:30 PM Saturday.
The SE fender fit perfectly. I added the 2nd right brake line similar to the left . . . Using a steel hose clamp to secure it to the OEM fork guards. The center portion of the fork guard is simiar to a dirt bike fork brace . . . Should not limit mud riding much. It keeps the top of the fork guards secure . . . Which holds the brake lines in place:
Old 03-04-2013, 06:40 AM   #25
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 581
Yes, I'm sure it's a 2004.
You can be 100% when you check the engine number and VIN:
Engine
04 600 xxxxx is a 2004 Adventure
05 600 xxxxx is a 2005 Adventure
VIN
Look for the number after the 'X'
X4 = 2004
X5 = 2005
You could also ask your dealer to print-out the KTM DealerNet record for your bike - it'll show production and shipment dates etc.
The stepped seat came in 2005 along with the change in height/suspension travel - you Yanks got the bikes a little late, so invented 2005.5
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 03-04-2013, 06:49 AM   #26
Orangecicle
Oddometer: 2,572
Engine
VIN
X4 = 2004
X5 = 2005
Hey, what do you know? You're right!
Old 03-04-2013, 07:00 AM   #27
Qwik
Adrenaline Addict
Oddometer: 6,712
You really don't need the top portion of the stock fender.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 03-04-2013, 01:32 PM   #28
mcmann OP
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,834
It helps support my brake lines. I do not ride much off road:
It is no different than a fork brace . . . Should not cause mud issues etc.
Old 03-04-2013, 11:32 PM   #29
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,406
I first saw this version of fender application done by another inmate XTREMJEEPN ( Cole Ford of Motul Magazine) using cutdown version of low fender as a brake line mount combined with a high fender. It's very similar to the late model OEM KTM 690 Super Moto fender set up.
For some fun facts... The early 950 race bikes had an oil cooler up front which warranted the lower fender for space, better airflow to the cooler and radiator... and the loop around low fender oil line was an OEM bolt on to what was originally raced as a single rotor front brake set up.
Glad you're having fun with it.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer screwed with this post 03-04-2013 at 11:39 PM
DesertSurfer is offline   Reply With Quote
Times are GMT -7.   It's 11:33 AM.
