02-28-2013, 02:15 PM
#16 |
Oddometer: 993
damping, etc.
I thinks we have posted on threads about proper suspension set-up time and time again. In general, SS pretty much covered damping, spring rates, sag, preload, etc. We can go into intimate detail in anyone wishes, or you can go to sportrider.com where there a many good suspension articles available. A few words about damping... one main purpose of forks/shocks is to keep you tires in CONTACT with the road, this usually means you want your suspension to react QUICKLY (hence the advent of cartridge forks). More damping (heavier fork oil for you 30 wt guys) means the suspension moves SLOWLY. You want your suspension to respond FAST and return to neutral without BOUNCING, that is all! We can get into rebound vs. compression, but I will call it quits for now.
Ray ABC #12947 '75 R90S |
02-28-2013, 02:52 PM
#17 |
Oddometer: 165
This has probably been gone over a number of times, but what's the word on replacement springs? I'm planning on replacing the springs on my R75/5 during the NorCal Airhead Tech Day. Huckys sells a fork rebuild kit, which I'm going to order, as well as progressive wound springs. Anyone tried these, or should I stick with the Heavy Duty OEM spring?
02-28-2013, 03:06 PM
#18 | |
Oddometer: 993
02-28-2013, 04:23 PM
#19 |
Along for the ride
Oddometer: 912
As has been stated previously in this post, the viscosity of different brand oils are not the same even though the weight may be. This site shows some common oils and the variations : http://www.peterverdone.com/wiki/ind...spension_Fluid
__________________________________________ "There's a fine line between a skinning and a shearing" |
02-28-2013, 04:37 PM
#20 | |
because I can
Oddometer: 6,046
02-28-2013, 06:15 PM
#21 |
Oddometer: 993
Ha! So true. Been there, done that. Anybody want my Progressive springs? Free. You pay shipping.
02-28-2013, 06:49 PM
#22 | |
Oddometer: 993
chemistry
p.s. I am a chemistry major. I have a degree in chemistry. That means I am qualified to dig ditches with a DIPLOMA in my back pocket.
Ray ABC #12947 '75 R90S craydds screwed with this post 02-28-2013 at 06:52 PM Reason: p.s. |
02-28-2013, 07:32 PM
#23 | |
Oddometer: 904
The way I understand it: changing oil weight is not an optimal cure for wrong sag/preload or wrong spring rate, and changing sag/preload is not an optimal cure for the wrong spring rate. Of course for fine tuning and getting the best out what you've got, you can blur the lines a little maybe, but first things first. For a lot of us who have done front end swaps recently (the 'unholy union threads' etc), when off-the-shelf springs in ideal rates were not available we've ended up getting springs custom wound to our specifications. It doesn't cost all that much and you get exactly what you are after. Relying on 'heavy' or 'regular' (with virtually no, or alternatively heaps of, preload) seems about as antiquated as our forks are... they might work well for a few lucky people and bike set-ups but the compromises would seem to stack up for everyone else. My point here is basically (and it is not at all my original idea, just my understanding of the basics of suspension set-up)- get the right spring rate first. If it is not for sale, that is not really an excuse, get them made, then set sag with preload, and tweak damping performance with oil weight and/or valve modifications. FWIW, my R90 came to me with heavy progressive springs and personally I like the way it rides- it is possible I could do with a slightly lighter spring weight, but I do not like the feel of the regular ones- way to soft for my preferences. I am around 100KG though, and like a firmer ride. Each to their own and YMMV. It does take a bit of pressure to get the cap down, but you don't have to be Mr Universe. After my first fork oil change I didn't like it with the (oft recommended) 5W fork oil so after a bit of experimenting I've settled somewhere around 7.5W. It seems to be a compromise that works OK for when my bike is both loaded down for touring and completely unloaded. It works brilliantly for neither. Personally I'm not fussed about keeping things 'original', so if I was looking to get the most out of the forks on my R90 or another airhead I'd probably be looking towards using more modern forks to start with (as I've done with the G/S). oh, and craydds, are you trying to say that those of us who have mixed different rate fluids have come up with some sort of special dual rate fork oil? I have mixed (currently 5 and 10 mix in my R90 due to not being able to buy 7.5W at the time) and have been happy enough with the results, so I'd be interested to actually know what is going on physically in there.. |
02-28-2013, 08:12 PM
#24 |
Oddometer: 2,051
I gave my so called progressive springs away too - too stiff for me.
If you actually measure the spring rate of a so called progressive spring in the normal working range the degree of progressiveness is almost too small to measure - less than 1% so you aint missing much without them. Stock springs work just fine, if you know how to fine tune them. And balance them front to rear , which is probably more important. Some current BMW adventure bikes have three switchable suspension settings, soft, medium and , err, hard, with electronic control of front and rear preload, and compression and rebound damping. Works well. Other manufacturers have similar systems which only change the damping but they are still able to make it work, although the range is not as wide is the systems which also change the spring preload. The adjustable HPN inserts in my GS forks work best with about 80% of the available rebound and 20% of compression. The HPN springs give 55mm rider sag. The rear Ohlins has a 450 lb spring with damping at the stock setting, which is around 50 % of the available compression and rebound, but that is preset as you only have one adjuster for both.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST |
02-28-2013, 09:07 PM
#25 | |
because I can
Oddometer: 6,046
You are right: Preload does not change spring rate. Preload changes the rate of the shock from the begining of its travel to the end. It's the same spring but as far as the fork of shock is concerned, it's a higher rate spring. This seems to throw some people and it seems like it is throwing you a bit? Preload is not a cure for the wrong rate spring. Having said that, there is nothing inherently wrong with preload. There is absolutely no advantage in having custom made springs down to the point that you don't need preload. There is absolutely no advantage in having no or a lot of prelaod as long as you don't have so much as to cause coil binding. The shock or fork could care less. All it cares about is the amount of energy it takes to compress it from the beginning to the end of its travel. As far as the shock or forks are concerned, the EXACT same results can be had with a custom made spring that needs no preload or a weaker spring that is preloaded. |
02-28-2013, 09:08 PM
#26 | |
Stay Horizontal
Oddometer: 1,600
The bottom line is that the mix will be somewhere b/w 5 & 10, and no matter what it is in the end, if it works, it probably doesn't matter too much. I s'pose for some, it's about knowing exactly what you've got, verses thinking you have it. I usually just do a 50:50 mix of whatever I have on the shelf to get in the 5-10 zone. If you're keen to be exact you can use this...but it doesn't adjust for brands. http://widman.biz/English/Calculators/Mixtures.html
R100RS Gallery, over 800 pictures... boxerboy81 screwed with this post 02-28-2013 at 09:45 PM |
02-28-2013, 10:37 PM
#27 |
Oddometer: 165
So, for my particular situation I have no idea what the current state of my fork springs are. I only know the front end dives significantly when braking with fresh 7.5 wt fork oil. I'm not particularly large: 5'10" and 160 pounds after dessert.
Swapping the front springs is mostly for my peace of mind. The previous owner left the bike in a miserable state, and it's only now up and running. At 40 years old the front end could probably stand to be freshened up. Seems like everybody hates progressives, so it's down to the OEM regular springs or the OEM heavy duty springs. Supershaft, your ideal setup is non-HD stock springs preloaded to taste? Preloaded with some cut-down pipe? |
02-28-2013, 11:08 PM
#28 | |
because I can
Oddometer: 6,046
02-28-2013, 11:19 PM
#29 | ||
Oddometer: 904
Please explain more. Quote:
My whole point is that selecting from two options of 'regular' or 'heavy' springs is kinda like shopping for underwear in XS or XL sizes only. That is why I mention custom winding springs, to get a given rate, not to eliminate preloading the spring. I also find it difficult to imagine any correct weight spring (custom wound or not) that gave the correct sag and required NO preloading... no spacers required for preloading maybe, but no actual preloading? I doubt it. FWIW, my custom wound springs have about 3 inches of spacer, for preloading, on top. So yes, I am a little thrown by how you describe all this, it seems blatantly contradictory to my theoretical understanding of the relation between spring rate and preload- but I am more than open to learn where my mistakes have been made. |
03-01-2013, 01:50 AM
#30 |
Oddometer: 997
Tom cutter was of the view that if you fitted progressive springs, with the tight windings to the bottom, this resulted in very stiff suspension because the tight windings raised the oil level too high
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
