Old 03-12-2013, 04:35 AM   #46
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 582
Originally Posted by Vicks View Post
but on a low mileage '08 990, it might be worth the risk not taking every thing off - if you don't need to ?
I agree, but it only amounts to two piston circlips extra.
As Peanuts mentioned, you can get the cylinders off without removing the pistons from the cylinders - in fact, according to the manual, you are not supposed to remove the pistons from the bottom of the cylinders, but only from the top. I don't know why they say this, and I'm not convinced that it needs to be so.
Also, you can keep the head attached to the cylinder, so as not to disturb the expensive head gasket.
So, by removing the cylinder and the head as one, you'll only need to buy two piston circlips (about £10). Then you'll have the option of replacing the base gasket, which I think should be done.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 03-12-2013, 06:17 AM   #47
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,154
All good points and thanks for that. Learn something everyday.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 03-12-2013, 02:59 PM   #48
JLC640 OP
Oddometer: 27
Good information guys Keep it coming. Plan to have motor sitting on work bench by this weekend and start digging into it.
Is there any issue with just using a long 8mm bolt to lock the crank instead of having to order and wait for the tool?
If I'm understanding you guys correct? You recommend removing cylinder and head as one pull cylinder up until I can remove circlip leaving pistons in bottom of cyl. and replacing base gasket.Not removing head from cylinder.
The bike only has just over 12k.
JLC640 is offline   Reply With Quote
Old 03-12-2013, 03:11 PM   #49
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
I lifted the cylinders and heads as a unit when replacing the base gaskets.
Did the rear last autumn and was able to get 250 kms before winter hit and it seemed to hold up fine.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 03-12-2013, 03:48 PM   #50
Peanuts
Peanuts's Avatar
Oddometer: 1,642
A fully threaded set screw or length of threaded bar with two nuts locked together. Grind it to a shallow (45 degrees) point at the end.
Peanuts is offline   Reply With Quote
Old 03-14-2013, 04:37 AM   #51
RedRupert
RedRupert's Avatar
Oddometer: 582
Yes. But be very careful - just move the piston down enough to expose the circlip/gudgeon pin fully. It's too easy to go a little too far, and have the rings out of the bore - it's not the end of the world if this happens, but it's worth the effort to prevent it happening.
No need to remove the head from the cylinder.
Replace the base gasket - there's no reason to risk reusing. Some owners have experienced weeping base gaskets.
Yamaha WR 450 F
Old 03-14-2013, 04:57 AM   #52
RedRupert
RedRupert's Avatar
Oddometer: 582
Special Tools
Are you aware of the special tools that you'll need? For example:
* Ignition rotor puller (an M16 x 1.5 mm grub-screw + an M20 x 1.5 mm screw or bolt).
* A 46 mm socket for the big nut on the crank-shaft.
* A means of getting to, and correctly torquing, the 13 mm cylinder nut that's obstructed by the cam-casing while assembling. You can use the KTM bottle opener along with a 1/2" torque wrench.
* A gear puller.
* Clutch tool.
* Sparkplug spanner (not many fit - needs very thin walls).
Photos of my engine locking tool:
It needs to be 100 mm or longer.
The tip:
The head - I cut a slot with a hacksaw for a screwdriver:
Yamaha WR 450 F
RedRupert screwed with this post 03-20-2013 at 04:06 AM
Old 03-14-2013, 05:07 AM   #53
RedRupert
RedRupert's Avatar
Oddometer: 582
Engine Stand
I made an engine stand from plywood scrap (I didn't have the material, tools or skill to make a metal one). I hate struggling with the motor, while trying to torque tight nuts etc.
It makes working on the engine a pleasure, rather than a struggle. It was well worth the effort to make.
It's only necessary to remove the motor from the stand just before splitting the crank-case. By then it's pretty light anyway.
Yamaha WR 450 F
RedRupert screwed with this post 03-20-2013 at 04:02 AM
Old 03-14-2013, 06:15 AM   #54
Peanuts
Peanuts's Avatar
Oddometer: 1,642
That would look sweet on my dining table :)
Old 03-19-2013, 02:29 PM   #55
JLC640 OP
Oddometer: 27
Got her split open this is pics of damage.
http://tinypic.com/r/262lkpf/6
http://tinypic.com/r/2r3kx8g/6
http://tinypic.com/r/16jg08o/6
http://tinypic.com/r/2lc9y7r/6
Still have no idea what caused it but it sure made a mess.
Old 03-19-2013, 02:45 PM   #56
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,621
That totally blows, but I'm sticking with my story.
Originally Posted by Boon Booni View Post
Looking at the damage to the gear tooth, I'd surmise that there is another chunk of something floating around in the sump of his bike, probably from the factory. when he layed it over the something moved around and got caught up in his first gear and then tried to go through it breaking off the tooth.
I don't think he's got bent shift forks or anything else beyond a broken first gear.
.02c
Boon Booni is online now   Reply With Quote
Old 03-19-2013, 03:47 PM   #57
JLC640 OP
Oddometer: 27
That is the only thing that really makes since to me.
The only other thing that might have happened. If you notice the pin on oil injection tube is bent. I laid the bike down on the left hand side. If the tube shifted slightly to the left and the pin came out off the groove in the case it would have hit the teeth on first gear. Even if it just broke one tooth the rest could have been caused by that tooth.That is unlikely but my only other idea.
Just glad I have it torn down, ready to order parts, and get it back together.
May have some questions for you guys during reassembly. Appreciate your help!
Old 03-20-2013, 02:24 PM   #58
Peanuts
Peanuts's Avatar
Oddometer: 1,642
Old 03-20-2013, 08:12 PM   #59
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,154
crap !!! thats MAJOR damage and i'm sure not many LC8 engines have suffered. I'm simply unable to think of the reasons that led to teeth shearing off a gear wheel in this manner. What are the chances of taking this up with KTM ? A simple drop should not cause such damage !!!
If KTM doesn't cover it, i would defn. keep the parts as a (dark) memorabilia.
hope you get her running back soon.
Old 03-20-2013, 08:25 PM   #60
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,621
Make sure you collect the broken bits. Count them and see if you come up with 1 more than you have teeth missing.
...and for those of us that seem to have some problem with your photo hosting site..
Boon Booni screwed with this post 03-20-2013 at 08:31 PM
Times are GMT -7.   It's 03:47 AM.
