02-28-2013, 06:18 PM
#1 |
Oddometer: 1
950SM Jet kit required?
I've got a stock 950 SM. Aside from raising the needles, will it benefit from bigger main jets? Trying to decide if I need a jet kit.
02-28-2013, 10:17 PM
#2 |
KOTW 2010 Finisher
Oddometer: 3,007
NEED a jet-kit for where you are at sea-level, no. Would the bike benefit from it a little bit? Yes. In my opinion it would not be enough to talk about.
But if you have done exhaust or air-filter or air-box mods, that is a different question and you would benefit from the jet-kit more then.
Brents347 Truckee, CA. 07 Yamaha R6 07 KTM 950 Super Enduro 04 KTM 250exc- plated two-stroke |
02-28-2013, 10:26 PM
#3 |
Oddometer: 2,147
With stock exhausts and filter leave the jetting stock.
With filter/exhaust mods its a different story. |
03-07-2013, 12:13 AM
#4 |
Zoob
Oddometer: 988
The Flex-Jet remote screws always make a difference.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
03-08-2013, 07:16 PM
#6 |
I <3 Energizer Bunny
Oddometer: 556
Needle makes a HUGE difference. I wouldn't own one with out them.
![]() I'm the guy that tested and tested and tested jets and these damn god forsaken CVR carbs to death. O2 sensor, dyno, every combination possible, seriously. The stock needle is an on/off switch. When you fatten up the fuel on top of the rev range, the stock needle will throw everything into oblivion. Thing will gag and cough when you twist the throttle big time. Only way to make them work is to keep the top lean...which sucks and isn't the way to do it. Flex jets are nice, especially if you move wildly in elevation. Not necessary though imho.
Yet Another New Air Filter for the KTM 950 - $150 |
03-09-2013, 04:13 AM
#7 |
Oddometer: 393
Search for 'x-bike' jet settings for 950SM. Requires a filter, remove airbox triangle, new main jets (and possibly idle ..can't remember). Really wakes the bike up.
EDIT, here you go: Front Main Jet: 170 Rear Main Jet: 175 Floats set to stock 3mm height Mixture screws set to 2.5 turns out Slide Needles set to 3rd notch. Vent hose lengths are critical too, the ends of the vent hose must be in clean, still air, otherwise you'll get surging. The above requires free flow filter and more importantly, removal of triangle access holes in the airbox. This gave me fantastic throttle response and great low-mid torque, with pull to redline. FYI, Once I dyno'd, I was a touch lean at low rpm low throttle opening, and opened idle mixture screws to 2.75 turns. |
03-09-2013, 03:45 PM
#8 | |
Life is a trip
Oddometer: 3,126
How about consumption?
Cheers.
There is always a reason!! gefr screwed with this post 03-09-2013 at 11:31 PM |
03-09-2013, 10:27 PM
#9 | |
Oddometer: 2,147
In case you haven't got it, do you remember your AFR up top? |
03-25-2013, 06:59 AM
#10 |
Oddometer: 554
As Aero has said the X-Bikes solution has worked well for many.
Prior to learning of the X-Bikes jetting spec, I had mine re-jetted using a dyno AF etc. at a local shop that's done great work on some of my previous bikes. I wasn't trying for top end power, just great driveability. While I don't have specifics I can say that the needles did cause problems and the factory pro kit I provided didn't offer a solution. The shop spent a ton of time finding a needle that worked. For sure the jetting changes improved the ride, no more surging it pulls from idle to the limiter in one smooth surge. I picked up 11hp in the mid-range, it's making 98hp at the wheel. Mileage is in the 32-40 range, same as stock. I am happy with the results, it was worth the time and expense. NM |
