Old 03-01-2013, 02:43 PM   #16
Moto Vaquero OP
Trail less traveled
Moto Vaquero's Avatar
Oddometer: 300
Originally Posted by 250senuf View Post
Below those options, kind of greyed out, don't you have "Data Card Setup" to scroll down to and select to go to the next page? What firmware version is installed?
Blank screen below "color". I have Cartagrafia E-32 installed.
I'm not day dreaming, I'm prerunning
21 days exploring Baja
http://advrider.com/forums/showthread.php?t=922187
Moto Vaquero is offline   Reply With Quote
Old 03-01-2013, 02:48 PM   #17
Moto Vaquero OP
Trail less traveled
Oddometer: 300
Originally Posted by Countdown View Post
Have you set "Welcome Message", Page Sequence, etc. lots more you need to do to be happy user.
Yes, Thank You for the tutorial. I did make some changes that will make life easier. The page sequence is nice. Still no "data card setup"
Old 03-01-2013, 03:01 PM   #18
Warin
Retired
Oddometer: 2,122
The other setting you need to be aware of is "follow road" - this makes your track log follow a road .. not what you want if your track logs are to be used to represent what YOU found rather than what is already on your maps...
Get pdf of your manual and search for those terms in the pdf manual. Saves every one here typing out that bit of the manual again.
Warin is offline   Reply With Quote
Old 03-01-2013, 03:02 PM   #19
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Yes see above
With the new "x" models there is no reason to ever save an active log to a "saved track".
In fact if you do save it, a lot of information gets stripped out of the file being saved so it's better to just let it archive.
Old 03-01-2013, 03:03 PM   #20
250senuf
250senuf's Avatar
Oddometer: 2,331
I meant the version of the software running the GPS.
Go to Main Menu
Select "Setup", Enter
Select "System" Enter
Press "Menu" key
Select "Software Version" Enter
There you should see: Software Version; Gps SW Version; and Unit ID.
For example: 4.20; 2.30m; 37xxxxxxxx
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 03-01-2013, 03:16 PM   #21
Moto Vaquero OP
Trail less traveled
Oddometer: 300
Version 2.50
Old 03-01-2013, 03:33 PM   #22
250senuf
250senuf's Avatar
Oddometer: 2,331
Head over here:
http://www8.garmin.com/support/colle...t=010-00422-00
Old 03-01-2013, 04:29 PM   #23
Moto Vaquero OP
Trail less traveled
Oddometer: 300
Yah, that was it 250senuf! You da Man. After the update to the 4.00 viola, there popped up the data card option. I did check the box to log tracks to data card.
Will this now automatically record the complete trip for a month as long as the gps is on? IE; there is no action on my part to save that days tracks before shutting it down for the night and disconnecting the power. I will unload the card when I get back as BigDog stated
Old 03-01-2013, 05:50 PM   #24
250senuf
250senuf's Avatar
Oddometer: 2,331
As long as you have tracks turned on at the initial Tracks page you will get a .GPX file for each day you power the GPS on. Each one should be no more than 400kB. Even if you save your track midday and clear the track log you will still have that .GPX on the card with the whole day. Experiment/play with the GPS before you really need it.
Old 03-01-2013, 06:07 PM   #25
Countdown
Oddometer: 5,454
Yes, day by day
Yes, not action
Did you mean "Upload" after you "unload" it from ger bag? Don't if you will but you can any time you want, forever. You have to erase card, it will not overwrite, just stop recording when full.
Jerry Counts
Countdown is online now   Reply With Quote
Old 03-01-2013, 06:27 PM   #26
Moto Vaquero OP
Trail less traveled
Oddometer: 300
Experiment/play with the GPS before you really need it = wise words
I should have some interesting tracks when I get back.
Thanks for the help
Old 03-01-2013, 06:30 PM   #27
Moto Vaquero OP
Trail less traveled
Oddometer: 300
Yes, day by day
Yes, not action
Yah, upload after I unload my shorts
Thanks for your help too
Old 03-01-2013, 07:10 PM   #28
Moto Vaquero OP
Trail less traveled
Oddometer: 300
BTW, I also downloaded a current manual which has info on the SD Cards. Mine didn't have any of the info regarding SD Cards, therefore much of the confusion
HTML code is Off
Times are GMT -7.   It's 12:45 PM.
