Old 03-01-2013, 02:03 AM   #1
paulk46 OP
Katoom
paulk46's Avatar
Oddometer: 227
Starter Solenoid grief
It would seem that the starter solenoid has decided to pass away, I can get one good spin of the engine from it then it just clicks its heart away, jumping across the terminals makes for a good sparking display, but does crank the engine.
this will be my 4th in 3 years, i think this is a bit of a high attrition rate.any one else get through this many?
it gets all 'mastic-ed' up to help protect it from the elements.
i did see an inmate who had relocated to behind the airbox, but the search the forum can't seem to find it, if anyone knows a link, would be greatly appreciated.
It is big and it is clever!...and blooming heavy,
but the new ones a racing whippet
690 Enduro R
KTM 950 Adventure (05) (resting)
I'm not lost, just never been here before
paulk46 is offline   Reply With Quote
Old 03-01-2013, 10:40 AM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
Is the starter relay your problem?
http://www.ktm950.info/how/wotf/wotf.html
http://www.advrider.com/forums/showt...=678780&page=2 post #20
It is known to have an external bronze connector that rusts and gets cut. If this is your problem, you can use some extra cable to repair the lost connection.
Cheers.
gefr screwed with this post 03-01-2013 at 10:46 AM
Old 05-23-2013, 08:17 AM   #3
Eriksson
Isthatdirtinyourpocket?
Eriksson's Avatar
Oddometer: 368
Now going off the WOTF link I found number for a solenoid: 58211058000
Google search gave me result for a $50 part at cheapcycleparts .com.
Anybody use them before?
83 Honda XR500R
03 Honda RC 51
04 Katoom 950
06 FJR Boomer
05 XR650R
99 Husa Fe501
WWW.BMWRA.ORG
Eriksson is offline   Reply With Quote
Old 05-23-2013, 08:22 AM   #4
Motomedic
Motomedic's Avatar
Oddometer: 2,510
If I remember correctly, a "5" in the beginning of the part # indicates it's for a single, rather than the twins (A 640A maybe?). I used one for a little bit-gotta make sure you put the leads on the correct terminals. It's backwards from our twins.
I currently have a relay from a Suzuki DL1K 'Strom on mine- was cheaper and quicker to order than the KTM part, no reversing of leads necessary.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 05-27-2013, 09:47 PM   #5
Eriksson
Eriksson's Avatar
Oddometer: 368
Originally Posted by Douf View Post
Have they all failed in the winter/cold weather perchance?
Douf
No, it seems to be a significant weakness with the KTM line, and their lack of dealership network support. Mine's an '04 with 24K miles. I'll look to the Suzuki solution, and then a Tenere.
83 Honda XR500R
03 Honda RC 51
04 Katoom 950
06 FJR Boomer
05 XR650R
99 Husa Fe501
WWW.BMWRA.ORG
Old 06-16-2013, 02:54 PM   #6
Eriksson
Eriksson's Avatar
Oddometer: 368
You were correct, it's not a match for the 950 twins.
Anybody need one cheap?
83 Honda XR500R
03 Honda RC 51
04 Katoom 950
06 FJR Boomer
05 XR650R
99 Husa Fe501
WWW.BMWRA.ORG
Old 06-16-2013, 03:24 PM   #7
Motomedic
Motomedic's Avatar
Oddometer: 2,510
It works, just swap the battery/power leads. IIRC if you use the 640 version the battery goes to the "outside" terminal rather than the "inside" terminal.
Feike
Old 06-17-2013, 03:32 AM   #8
Eriksson
Eriksson's Avatar
Oddometer: 368
The connection spades are different size; much larger and do not fit the connection on this '04 950. Am I missing something? Is there a "spade swap" to do as well?
83 Honda XR500R
03 Honda RC 51
04 Katoom 950
06 FJR Boomer
05 XR650R
99 Husa Fe501
WWW.BMWRA.ORG
Old 06-17-2013, 08:43 AM   #9
Motomedic
Motomedic's Avatar
Oddometer: 2,510
Now that I think about it, I might have made a quick "jumper harness" too. It's been a few months since I did this.
Feike
Old 06-17-2013, 09:28 AM   #10
vicster
Oddometer: 1,138
Another possible method is to take the bad starter relay to an auto parts store for a possible match. Worked for me on my Triumph. Think I paid $14.
vicster is offline   Reply With Quote
Times are GMT -7.   It's 04:16 AM.
