Old 03-02-2013, 11:22 AM   #1
rd07luis OP
KTM REBUÇADO
rd07luis's Avatar
Oddometer: 36
Husaberg 450 FE does not want to work
Hi guys,
After a jet wash the bike doesn't want to start. The batery is good and the start engine is runing, have fuel.
What should I look for ?
Thanks for your help.
LD
rd07luis is offline   Reply With Quote
Old 03-02-2013, 12:02 PM   #2
4ReelMoto
Seasoned Rider
4ReelMoto's Avatar
Oddometer: 1
How high did you have the pressure set on the power (jet) washer?
Did you have the seat off when washing? If so, make sure the starter solenoid is still connected properly.
You mentioned that the battery is good, have you made sure you have at least 10.6 V while trying to start?, the Husa's fuel injection can be temperamental in regards to this.
I replaced the stock battery with a Shorai not long after the bike was new and this problem has never happened since.
4ReelMoto is offline   Reply With Quote
Old 03-02-2013, 03:29 PM   #3
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,855
On my Husky TE 450, water infiltrated my gear position sensor, and the bike would not start or if it started it would die immediatley when put into gear, Check to see if you have a gear position sensor on the bike.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 03-02-2013, 05:42 PM   #4
FamilyRider
FamilyRider's Avatar
Oddometer: 306
I have heard of others having trouble when the spark plug wire gets wet. Apparently water gets down inside the cap.
2014 KTM 350 XCF-W
FamilyRider is offline   Reply With Quote
Old 03-02-2013, 08:33 PM   #5
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 11,361
I ruined my stator by using a pressure washer, even by being careful.
Never, ever again.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is online now   Reply With Quote
Old 03-02-2013, 08:35 PM   #6
Huskylove
Oddometer: 54
Check the clutch disconnect switchy thing...I had that happen to my husky 450 2006. Wouldn't start wouldn't start, new battery, wouldn't start...figured her out eventually.
96 Xr600r, 644cc 10.5:1 Je, megacycle cam/rockers, fcr41 sudco, custom exhaust and a set of 17's <motor and frame for sale PM me
Huskylove is offline   Reply With Quote
Old 03-03-2013, 11:33 AM   #7
rd07luis OP
KTM REBUÇADO
rd07luis's Avatar
Oddometer: 36
Thanks guys I will check all the possibilities.
Old 03-03-2013, 11:38 AM   #8
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 722
Simply a water infused contact somewhere.
Every bike wash where I live has an air gun and if a bike won't start they just blast every point where water could cause a fault - spark plug, kill switch, sidestand switch, clutch switch etc. . .
Fixes everything. Alternatively, leave it alone for 24 hours so the water can dry out and it will likely start then.
Jacl-Kampuchea is offline   Reply With Quote
Old 03-03-2013, 02:58 PM   #9
kdennan
kdennan's Avatar
Oddometer: 628
listen to the manufacturer
NEVER PRESSURE WASH
If you want the bike spic and span, use Motoclean by motorex. spray on and rinse off with GENTLE stream from a garden hose.
kdennan is offline   Reply With Quote
Old 03-04-2013, 02:23 PM   #10
rd07luis OP
KTM REBUÇADO
rd07luis's Avatar
Oddometer: 36
Once again thanks for all your help.
Today I start to do a check and the fuel pump was disconected with the water or when taking out the air filter.
Problem solved
Times are GMT -7.   It's 10:10 PM.
