Old 03-02-2013, 02:17 PM   #1
LateNate OP
Oddometer: 328
Last Accessory plug, heated grips or 12V?
On my 05 950 Adv I have the "hot" accessory plug left on my fuse panel. Should I hook the new 12V cig plug I just bought to it or my new heated grips?
I feel like I should hook the plug to it and run my KTM heated grips directly off the battery.
Thoughts? I have my GPS hooked up to my other accessory plug.
TAT
Copper Canyon
LateNate is offline   Reply With Quote
Old 03-02-2013, 05:37 PM   #2
dirtyac
Ktooner
Oddometer: 30
Your heated grips should be on a switched accessory circuit, so if you inadvertently leave them on, they don't drain your battery.
11 KTM 690 Enduro, 06 KTM 200XCW, 07 KTM 990 Adventure S, 86 Honda Nighthawk S
dirtyac is offline   Reply With Quote
Old 03-02-2013, 06:02 PM   #3
jonoabq
ow.
jonoabq's Avatar
Oddometer: 19
fused 12v supply
Add a centech AP-1 fused accessory block under the seat and run everything off of that. It will give the ability to expand later if needed, gives you the safety of "key off" circuits, and keeps all your electrics clean and tidy. It also frees up your last factory panel outlet to power a tankbag full of electronic goodies and radar/laser countermeasures.
jonoabq is offline   Reply With Quote
Old 03-03-2013, 12:23 PM   #4
ktm55
ktm55's Avatar
Oddometer: 31
Isn't there a factory circuit for the heated grips up in the head light area?
ktm55 is offline   Reply With Quote
Old 03-03-2013, 02:25 PM   #5
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
The right way to do it is a fused block with everything running off keyed power. If not, I guarentee you kill your battery dead a few times with your grips. If you want satisfaction with your grips, they should use a relay and run from the battery with relatively large gage wire. Also insulate from the bars. Use a rheostat because done correctly your hands will be hot, hot, hot.
DeepInIt is offline   Reply With Quote
Old 03-03-2013, 09:07 PM   #6
wcohl
Oddometer: 332
I agree with using a swirched circuit for heated grips. I killed one battery because I forget to turn them off, and I killed another battery when the someone or something bumped the switch. At least this was in the days when I could get a battery at Wal-Mart for $30.
wcohl is online now   Reply With Quote
Old 03-04-2013, 08:34 AM   #7
LateNate OP
Oddometer: 328
OK so looks like I will run the heated grips directly to the battery and the 12V will take up the "hot" ACC plug.
TAT
Copper Canyon
Old 03-04-2013, 10:12 AM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,925
You are talking about the same thing.
The hot ACC is constantly powered. Connection to the battery is also constantly powered. You need a switch somewhere for the heated grips.
Cheers.
Old 03-05-2013, 07:13 PM   #9
LateNate OP
Oddometer: 328
I am kinda not wanting to get a whole new fuse box. If I add more electric accessories onto it, then I must. I am thinking I can get away with the last hot spot for the 12v plug and go directly to the battery with the heated grips.
I just really have to make sure to remember to turn them off.
TAT
Copper Canyon
Old 03-05-2013, 11:43 PM   #10
chrish4ku
chrish4ku's Avatar
Oddometer: 795
I had my prior fog lights wired direct to the Batt with a switch. I drained my Batt twice in 6 months cause I forgot to turn the switch off. Just get a relay switch of some sort and hook it into the ignition. Then you never have to worry.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Times are GMT -7.   It's 10:25 AM.
