Old 03-02-2013, 06:46 PM   #1
brendonb11 OP
brendonb11's Avatar
Oddometer: 187
Question Switched to foam air filter
So, I got a chance to ride my 2007 KLR for about 130 miles today with the new uni filter. Upon starting I immediately noticed that my bike was louder. and it had a little more umfh!
It also sounds more wet, if that makes any sense. With that said, around 4k, especially in 4th gear, something weird happens- it doesn't surge or lunge (nothing drastic), but it gurgles! once I down shift, it goes away...
The last few months were 'winter maintenance', with an occasional ride (couple in Jan an 3 in feb). The new add after xmas was 16t front...it's made the highway rpm range awesome! and the low range perform slightly different- so maybe I'm not used to that yet..
or could it be that the new air filter isn't seated right- or over oiled?
I pulled the plug 'cause it seems like it's a 'lean issue', though it looks ok...[i think]
Typically, when switching from a K&N to a Uni, does one have to re-clip the carb needle? I rode it 2 weeks ago with the K&N and it was totally fine. so, I'd rather not mess with the carb (if it ain't broke, don't fix it)- Again, it's not surging or sputtering. It kinda gurgles, sounds like its under water- when I downshift and raise the rpms it goes away. Problem only appears approx 40-50mph ~4k rpm.
thoughts??
brendonb11 is offline   Reply With Quote
Old 03-02-2013, 06:53 PM   #2
gearheadE30
gearheadE30's Avatar
Oddometer: 999
That looks pretty lean to me, and I'd guess that the gurgle happens under those conditions due to the specific throttle position and rpm combination. try to replicate the condition in a different gear and see what happens.
Foam filters tend to flow a bit better than the gauze type like the K&N, so you are probably running lean due to that. If you have factory jetting, then you're exaggerating an already lean setup. Either try shimming the needle or moving to the next clip position (if you have other clip grooves) and then do plug chops from there to see what you need to do next, if anything.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 03-02-2013, 07:00 PM   #3
brendonb11 OP
brendonb11's Avatar
Oddometer: 187
That is what I thought off the bat- more air + same amt fuel= lean. Hence pulling the plug.
Ah, I failed to mention I have a stage1 dynojet kit in there...
I'll take her out tomorrow and try to replicate the problem in another range.
Old 03-03-2013, 03:53 AM   #4
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
You didn't say what exhaust you are running. The UNI filter, great. The KLX needle, great. But exhaust flow plays a huge part in carb setup as well....
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 03-03-2013, 06:09 AM   #5
jon_l
jon_l's Avatar
Oddometer: 3,458
Plug does look a little lean.
The K&N should flow more air, and the UNI would flow a little less, but filter better. Seems like it would run leaner with the K&N.
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 03-03-2013, 07:06 AM   #6
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Some independent tests have shown the K&N flows less air than even the stock filter, plus lets through larger particulate..... Go figure..
Old 03-03-2013, 07:42 AM   #7
brendonb11 OP
brendonb11's Avatar
Oddometer: 187
I have a Jardine exhaust...
Old 03-03-2013, 08:05 AM   #8
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,051
Nice full flow can. I had the best AF data across the RPM range under load when I was running the CVK40 with the KLX needle on the 3rd groove, 142.5 main, stock pilot 2 1/2 turns out, desnorkled, and L-mod, UNI filter.
Times are GMT -7.   It's 11:56 PM.
