Old 03-02-2013, 07:24 PM   #1
jmklint OP
Oddometer: 33
Installed Rox 1 3/4 risers, cables too tight. help
I got my new 2012 R adventure yesterday and started adding all my accessories. The Rox 1 3/4 risers make my cables incredibly tight so I had to go back to the stock set-up. From reading earlier post, most people said there was plenty of give to add the 1 3/4" risers. Any ideas? Thanks.
jmklint is offline   Reply With Quote
Old 03-02-2013, 07:52 PM   #2
DuctTape
Oddometer: 351
You have two choices.
You can undo the the throttle cables and rotate the housing so the cables are under the bars. Picture here http://www.advrider.com/forums/showp...74&postcount=2
or you can do like I just did and actually reroute the cables from the left hand side of the frame over to the right hand side by just removing the black door you see up front on the frame.
I like the reroute myself.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape screwed with this post 03-02-2013 at 08:00 PM
DuctTape is offline   Reply With Quote
Old 03-02-2013, 09:00 PM   #3
Maoule
Maoule's Avatar
Oddometer: 549
I added some Renthal RC highbars as well as 2" Rox extenders; I had to do both the right side relocation and the throttle cable down turn.
Maoule is offline   Reply With Quote
Old 03-02-2013, 09:25 PM   #4
Weldit
Weldit's Avatar
Oddometer: 336
the above mentioned is great for throttle But my problem was the ABS bikes have
a line that goes to module under seat and then comes back front to go to the calipers
there was only enough slack in the hose to the bars for 1.5" on my bike
you could force it to 2" but that would be to tight for me
this is after switching the hoses in the clips on the frame so the line to bars is on top
stock the line to caliper was on top
if you don't have abs - no problem
some reading:
1Riser height, what's the max - ADVrider
2How are your risers working out? Need more cable? - ADVrider
3Dirtinblood Riser Install - ADVrider
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 03-02-2013, 09:29 PM   #5
DuctTape
Oddometer: 351
some reading:
I have ABS and not a problem? I guess it could be the Flexx bars I'm using?
2010 Ducati 1198S
DuctTape screwed with this post 03-02-2013 at 09:42 PM
Old 03-03-2013, 08:22 PM   #6
jmklint OP
Oddometer: 33
good info
thanks for the input, I will tear into it this weekend
Old 03-03-2013, 08:26 PM   #7
jmklint OP
Oddometer: 33
I have the adventure R so no ABS but I'm gonna flip the throttle cables
Old 03-05-2013, 01:14 PM   #8
srad600
srad600's Avatar
Oddometer: 683
I also have an 11 with ABS, stock bars and 2 Rox risers. The abs lines were not an issue, and they have plenty of slack. I did have to rotate the throttle 180 though.
srad600 is offline   Reply With Quote
Old 03-05-2013, 10:51 PM   #9
chrish4ku
chrish4ku's Avatar
Oddometer: 861
+1 on ABS shouldn't be a problem. For me it was just the throttle flip and took less than 10 mins. Seems to be plenty of play.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 03-06-2013, 05:36 PM   #10
Weldit
Weldit's Avatar
Oddometer: 336
I guess my brake lines are shorter than everyone else ?
or my definition of "plenty of slack" is different
what ever works for you ?
even at 1.5" riser on BRP top clamp and stock bars the brake line is tight
YMMV
'11 Dakar 990
Old 03-07-2013, 03:23 AM   #11
DuctTape
Oddometer: 351
Well the brake master/lever and bars can be rotated so maybe that's the problem. Where you want them is different then the rest of us?
2010 Ducati 1198S
Old 03-07-2013, 02:04 PM   #12
Weldit
Weldit's Avatar
Oddometer: 336
Don't think that's it - any other idea ?
as I am 6'8" and have a long reach my bars are forward and the brake lever is
rotated down to help with the length of brake line - which is ok for standing but
actually a bit to far down for sitting.
I am just trying to help others to check for slack when adding risers as not all bikes
seem to be the same.
---- and check with the bars at full lock both left and right ----
mine comes snug when the bars are full right turned.
'11 Dakar 990
Old 03-07-2013, 05:09 PM   #13
srad600
srad600's Avatar
Oddometer: 683
Is your suspension stock height? Are the lines routed correctly?
Old 03-07-2013, 10:49 PM   #14
Masa
Masa's Avatar
Oddometer: 303
I have a '11 ABS and 2" Rally Risers. The brake line is indeed a bit on the short side. I too switched lines in the clips to get more slack. It's still not as loose as I would like it to be, but I chose to live with it. Some have re-routed the line inside frame or bought longer hose.
Masa is offline   Reply With Quote
Old 03-09-2013, 07:04 AM   #15
SauceSquatch
SauceSquatch's Avatar
Oddometer: 283
I installed a set of the ROX 1 3/4" risers without a problem on my ABS, you have to flip the throttle on the handle bar but also follow the wires down to the right side of the frame. For the brake, I had no problem but did have to snip a couple zip ties, move around and then re-zip tie.
2010 KTM 990 Adventure
2006 DRZ
1978 Harley FX cut down
SauceSquatch is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
