03-03-2013, 12:06 AM
#1 |
Oddometer: 241
Split bars !
I thought my throttle was getting a little hard to turn/return. So I loosened the end bolt that secures the guard and tried to get a little light lube inbetween the bar and the throttle tube. Then I did up the guard bolt. Problem. The throttle stuck. Turns out the bar has a split and when I tighten the bolt in the end of the bar for the guard, it expands the bar inside the throttle tube !!
Has anyone ever seen this before? I have not. I did not over tighten the bolt at all. So some gorilla has worked on this bike at some stage. I havnt taken it apart yet. Im hoping I can get a small weld on the outside of the bar along the split and grind back. The things you find !! |
03-03-2013, 12:42 AM
#2 |
Oddometer: 274
Do not fix your handlebar! Replace it!
03-03-2013, 06:48 AM
#3 |
Oddometer: 39
Replace is right. Fatigued bars for whatever reason should not be trusted.
Treat yourself BIG and put a set of Flexx Enduro hi 15 degree bars. You will never go back. |
03-03-2013, 07:04 AM
#4 |
Oddometer: 63
What he said, don't do it! Even if you are a competent welder. The type of aluminum usually used should not be welded. You may be able to physically weld it , but the bar strength, will be seriously compromised. Most likely very brittle at and around the weld.
03-03-2013, 08:07 AM
#5 |
Confused Hack Nut
Oddometer: 2,518
get a tap and do the threaded bar end trick. That won't happen again.
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift! Member of the Maryland OHV Alliance |
03-03-2013, 06:35 PM
#6 |
Oddometer: 241
Not sure what this bar end trick is?
03-04-2013, 05:36 AM
#7 |
Confused Hack Nut
Oddometer: 2,518
Thread the end of the bars, install an insert, screw into the insert. The typical insert wedges in place and causes the bar to bulge or split. This is a much more solid and secure mount.
![]() http://www.brpmoto.com/index.php?pag...mart&Itemid=49
