Old 03-03-2013, 09:20 AM   #1
GS Addict OP
Pepperfool
GS Addict's Avatar
Oddometer: 2,571
Tire Pressure Sensors - Hexheads
A couple of questions......
Ref: 2008 R1200GS
The Max fiche shows separate windows for front and rear yet the part numbers are the same.??
Is this a dealer programming thing after they are installed?
Further to this can they be moved around from bike to bike?
I am in in the process of replacing the batteries (lots of mining going on )
and preparing to install on a friends bike.
A pre thanks to all responders
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 03-03-2013, 09:34 AM   #2
LaurelPerryOnLand
Oddometer: 2,422
Maybe?
http://www.advrider.com/forums/showthread.php?t=728599
As I read this and other threads...you CAN add a 2nd set of sensors (to swap 2 different sets of tires) if you had TPS added at the factory..but NO...you can't ADD TPS after it's left the factory.
Adding the 2nd set of sensors requires Dealer assistance to program computer to recognize different TPS's.
Anybody else read this differently?
YMMV.
LaurelPerryOnLand is offline   Reply With Quote
Old 03-03-2013, 09:43 AM   #3
El Gato
El Gato's Avatar
Oddometer: 491
YMMV.
This is correct. I just did this at the dealer yesterday. If the bike already had TPM from the factory, then the computer can be programmed to read a second set of sensors. The dealer has to program this. The P/N for the sensor is the same for front/rear and for forged and wire wheels.
El Gato is offline   Reply With Quote
Old 03-03-2013, 09:58 AM   #4
Iron Rey
Oh shit, not him!
Iron Rey's Avatar
Oddometer: 729
YMMV.
Agree.
If you do not have it from the factory, you are sol but there are some good aftermarket solutions.
Iron Rey is offline   Reply With Quote
Old 03-05-2013, 07:55 PM   #5
seniorasi
Oddometer: 603
Is it possible to use a GS911 for this?
2012 R1200 GSA
FYYFF
seniorasi is offline   Reply With Quote
Old 03-06-2013, 02:30 AM   #6
WOLVERINE
Keep her pinned!
WOLVERINE's Avatar
Oddometer: 601
Just did it yesterday with the new software update, 1211.5! Works like a charm. You don't have to go to the dealer anymore if you have a GS911 or know someone with one close by...
If you think you're free, there's no chance of escape!
2008 R1200GSA
WOLVERINE is offline   Reply With Quote
Times are GMT -7.   It's 03:25 AM.
