Old 03-03-2013, 04:36 PM   #1
erin OP
Oddometer: 4
How to pass AZ emissions
I am looking for advice in passing Arizona emissions with a 06 950 with Wings, Head2Wind’s jetting and a cannisterectomy. I used flexjets to possibly lean-out the idle mixture too much yesterday when I failed the test with CO readings in the 9’s (it must be 5.5 to pass). I have been reading about using 4-5 cans of dry gas and a gallon of fuel to drop the CO about 3 points – that’s not going to do it. Any help would be greatly appreciated.
erin is offline   Reply With Quote
Old 03-03-2013, 06:28 PM   #2
It'sNotTheBike
Oddometer: 704
Sounds like you need to set the bike up using a sniffer
which is owned by someone other than an inspection
station, and THEN take it to be inspected.
Also, if you can install the OEM mufflers which have catalytic
converters inside you will have a better chance of passing
the test. When you defeat most of the emissions system,
the emissions of the bike will be adversely affected and now you are
having to deal with that reality.
It'sNotTheBike screwed with this post 03-03-2013 at 06:36 PM
It'sNotTheBike is offline   Reply With Quote
Old 03-03-2013, 07:52 PM   #3
sonoran
incognito
sonoran's Avatar
Oddometer: 16,002
If you need a stock set of cans with catalytic converters in them to get thru testing let me know. I have a couple pair collecting dust. I'm in Gilbert.
sonoran is offline   Reply With Quote
Old 03-03-2013, 08:37 PM   #4
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,670
You do not need the stock cans....... You need to see if the kit H2W set for you has the 45 pilots. If so get them out of it and reinstall the stock 42's........
If you need some help let me know...
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
Originally Posted by Beefeater Steve View Post
✧The KTM is the kind of bike you take behind the middle school and get pregnant. It's the kind of bike that, from the moment you light the fire, you know is downright nasty and makes you want to meet in the Burger King bathroom and lick its butthole.
KTMSER is offline   Reply With Quote
Old 03-03-2013, 09:34 PM   #5
Qwik
Two Wheeled Addict
Oddometer: 5,247
ECS Dyno in Gilbert. Walter sprout is one of the best
Speed bumps never seem to make me go any faster
Qwik is offline   Reply With Quote
Old 03-03-2013, 09:38 PM   #6
sonoran
incognito
sonoran's Avatar
Oddometer: 16,002
Tossing on the stock cans is alot easier than swapping pilot jets.
My '04 950 had the H2W kit with 45 pilots and akro cans. It wouldn't pass emissions with the akros but dump a couple bottles of Iso-Heet in the tank and throw on the stock cans.. all good.
It's worth a try before digging into the carbs.
Old 03-04-2013, 07:16 AM   #7
erin OP
Oddometer: 4
Thank you for your replies, and Sonoran, thank you for your offer - I’ve also got stock cans that I had hoped would remain dusty. As I bolt them on for what may be the annual “swapping of the cans”, I’ll be debating whether a dyno test / return to the stock idle jet makes better sense.
Just for interest, has anyone with a similar set-up – Head2Wind jets, non-catalyzed cans, and no SAS, been able to tune their way to pass the inspection?
Old 03-04-2013, 06:52 PM   #8
booger1
booger1's Avatar
Oddometer: 704
Got a differant set of pipes (akro's) and it passes no problem. Listen to Ktmser, he knows these bikes inside and out.
If you need help in a few weeks I have a 4 gas analizer.
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is offline   Reply With Quote
Old 03-04-2013, 07:26 PM   #9
DOD
idiot dirt rider
DOD's Avatar
Oddometer: 1,917
Mine passes with a Scorpion pipe, no problem. I set it up to KTMser specs.
Also runs great.
-dod
This is my only chance to assemble a disreputable past
DOD is online now   Reply With Quote
Old 03-04-2013, 08:30 PM   #10
erin OP
Oddometer: 4
Are you using the stock 42 jets with a pre-filter?
Booger1, 4-gas analyzer!
Old 03-05-2013, 09:29 AM   #11
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 719
Pull the pre-filter for the emission test.
pfdskipper is offline   Reply With Quote
Old 03-05-2013, 05:45 PM   #12
booger1
booger1's Avatar
Oddometer: 704
Yes, stock pilots, with a pre filter, but against KTmser's better wishes, also a k&n style filter.
It passes and I have more power and fuel milage than I did when purchasing the bike from Cali.
Remember they only idle test bikes, so that's where the smaller pilot comes into play. Good luck.
Old 03-05-2013, 07:46 PM   #13
DOD
idiot dirt rider
DOD's Avatar
Oddometer: 1,917
42 jets, pre-filter and the KTMser airbox mod.
-dod
Old 03-05-2013, 09:58 PM   #14
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 1,439
Just wait
I am told the bike testing is ending at the end of March... I am waiting to see if thats true.
Reidy008 is offline   Reply With Quote
Old 03-06-2013, 03:40 AM   #15
booger1
booger1's Avatar
Oddometer: 704
I've been hearing that for over 7 yrs.
I hope it stays in place, it seems to really piss those Harley guys off.
Times are GMT -7.   It's 10:54 PM.
