Old 03-13-2013, 01:09 PM   #31
eebrumfi
eebrumfi
eebrumfi's Avatar
Oddometer: 52
-2012 KTM 990 Adventure-
-A DRUNKEN MAN'S WORDS ARE A SOBER MAN'S THOUGHTS-
eebrumfi is offline   Reply With Quote
Old 03-13-2013, 02:12 PM   #32
Dusty
Dusty's Avatar
Oddometer: 1,307
This has been a problem that was well documented in the OC several years before i joined.
If its a scorpion, get rid of it, its the tire.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 03-13-2013, 07:26 PM   #33
smj OP
smj's Avatar
Oddometer: 207
Got the bike back, and it is perfect! The shop had an almost new tire that they thought was good, put it on, it was not. So they then put a brand new tire on the front, end of problem. So, 1 out of 3 scorpion front tires worked well with my bike. I was told all the shop did was swap tires... Could it have been the rim wrap???? Maybe. Maybe the third time they got lucky? Or is it the tire? Both? Never touched the preload. All other adjustments were nice and tight.
Put the bike up to 60 and let go till it got down to 35 mph - not a hint of instability. Did this several times, on different road surfaces.
If the tire was bad to begin with, I would imagin that once the tire gets some miles on it and starts to cup - it could be horrible.
Not trying to talk trash about scorpion tires, just repeating what I was told and summing things up!
Thanks everyone!
Death is like an old whore in a bar, I'll buy her a drink but I won't go upstairs with her. Hemingway
smj is offline   Reply With Quote
Old 03-15-2013, 05:06 PM   #34
eebrumfi
eebrumfi
eebrumfi's Avatar
Oddometer: 52
I think I found your wiggle
http://www.youtube.com/watch?v=QJeUhHikQAQ
Old 03-15-2013, 07:59 PM   #35
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,447
that is exactly it.
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 03-15-2013, 08:17 PM   #36
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,873
You got it- thanks for saving me the effort.
Beautiful road, but damn those cars scare me. The bus, the cars coming out of driveways. And side streets. Made the wobble seem safe.
Well done
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 03-16-2013, 04:28 AM   #37
Deviant666
Present
Deviant666's Avatar
Oddometer: 536
Originally Posted by BillyD View Post
+1 on the Conti Trail Attacks for mainly pavement riding.
I was getting about 700 miles out of the stock Scorpions on my normal commute. The rear would be toast and the front worn enough to induce the wobbles described in this thread. The first time, I replaced only the rear because the front didn't look too bad, but the wobble was still there. Replaced the front and all was good for about another 700 miles.
Then I started using the Conti Trail Attacks on pavement. Same roads. Same rider. Now I'm getting closer to 2,000 miles from a set of tire. Plus, the bike can smoke many other pure street bikes. With the 21" front wheel, the front end feels a bit "vague" on initial turn in when pushed hard, but I've gotten used to it.
They don't listen, they don't listen....tststs..
KTM 990 Adventure White 2009 R specced
ZZR1400 ABS 2008
Deviant666 is offline   Reply With Quote
Old 03-16-2013, 04:35 AM   #38
Deviant666
Present
Deviant666's Avatar
Oddometer: 536
Thanks everyone!
Why did you put a Scorpion again is beyond me....trail attacks are very good for hard packed off roading (due to our excellent suspension) on anything loose they are worthless but so are the Scorpions...when the bike started its production Trailattacks weren't available but see what's on the new 1190s from stock...KTM did it right this time....
ZZR1400 ABS 2008
Old 03-16-2013, 04:39 AM   #39
smj OP
smj's Avatar
Oddometer: 207
You most certainly did! I suggest, change the tire and maybe check the rim strip! That is what fixed mine.
Old 03-16-2013, 04:42 AM   #40
smj OP
smj's Avatar
Oddometer: 207
The current Scorpion on my bike was at zero cost to me, and the problem is gone - for now any way. Any other tire, I'd have had to pay for, which having just bought the bike, I just couldn't bring myself to do that. I wanted the dealer to make it right with me, they did, I can live with the Scorpion while I get to know the bike!
Old 03-16-2013, 06:58 AM   #41
Deviant666
Present
Deviant666's Avatar
Oddometer: 536
But Ofc my bad...
ZZR1400 ABS 2008
Old 03-16-2013, 12:06 PM   #42
spencergt66
Oddometer: 808
Had the exact same issue last year on the way to the KTM rally people swore up and down it was suspension setting this that and the other. THe whole way there I tried more/ less preload on the front and the back played with clickers still same issue...
Got home took scorpion tire threw in garbage replaced with new conti up front problem solved
http://advrider.com/forums/showthread.php?t=825461
spencergt66 is offline   Reply With Quote
Old 03-16-2013, 12:18 PM   #43
jimmy650
South Canol Racing Club
jimmy650's Avatar
Oddometer: 403
My '07 developed a wobble between 30 and 50 mph shortly after I bought it. So I went to the dealer and he found the steering head bearings were loose. Adjusted and fixed... been great ever since.
Jim R
Jim R.
Engineer @ Zero Motorcycles
'07 KTM 990 Adv
2006 Alcan5000 Winner
jimmy650 is offline   Reply With Quote
Old 03-30-2013, 12:29 PM   #44
laramie LC4
crash test dummy!
Oddometer: 2,447
just got the front tire replaced under warranty and the bike is perfect now. no wiggle, or wobble, or shake. only thing that was changed was the tire. if your having this problem, take your bike in and make them switch the tire.
laramie
Old 04-03-2013, 01:12 PM   #45
eebrumfi
eebrumfi
eebrumfi's Avatar
Oddometer: 52
Great News,
My dealer just called and is replacing both tires with Conti Trail Attacks at no charge!!
Woo Hoo!!
Times are GMT -7.   It's 08:48 PM.
