Old 03-03-2013, 10:20 PM   #1
pdxmotorhead OP
pdxmotorhead's Avatar
Oddometer: 780
Arg.. Doing water pump repair...
Ok I decided to do a full winter service, so I bought he CJ kit and dove in.
I had a fair amount of trouble removing the front header pipe. Now I cant get the darn thing back on. Anybody else had trouble getting the front pipe on and off. It acts like the heat shield is in the way. I sat there quite a while just trying variations of threading the thing in. The area of interference is between the frame and engine near the clutch cover.
Also the carbon ring on that pipe was partially missing. The section of the pipe that goes into the ring had a fair amount of corrosion.
Dave
pdxmotorhead is offline   Reply With Quote
Old 03-03-2013, 10:46 PM   #2
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
remove the heat shield, replace the carbon gasket
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-03-2013, 11:13 PM   #3
crazybrit
crazybrit's Avatar
Oddometer: 8,552
+1 and even after this you'll have to experiment a little to figure out the correct way.
Also take care not to strip the heads holding the heat shield on. the bolts tend to seize into the header and they are A2-70 stainless. If you do, you'll have to extract them. Fastenal on SE Taylor sells 10.9 equivalent in zinc and use some anti-seize.
crazybrit is offline   Reply With Quote
Old 03-04-2013, 07:16 AM   #4
pdxmotorhead OP
Oddometer: 780
I was afraid of that, I tried to get the heat shield bolts out (Lightly,,, ) none of them want to turn. Guess I'll give them a soak with some pb or something and try again..
Thought I had this knocked,,, it came apart easy and everything went right back together easy till the pipe.. I'm tempted to have a welder friend add a band junction in that pipe.
Thanks ,, !!
Dave
Old 03-04-2013, 07:31 AM   #5
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,896
Thanks ,, !!
Dave
The pipe slips out easily without the shield on. I'd find a replacement for the heat shield rather than messing with the pipe. The best solutions move the shield off of the pipe.
Orangecicle is offline   Reply With Quote
Old 03-04-2013, 10:20 AM   #6
CamelBill
Ride It!
CamelBill's Avatar
Oddometer: 514
Very Trick! I want. How would one acquire such a sweet piece? Looking forward to meeting you on the MO SB Ride . . .
Camel
KTM 1190R, 950S, 500XC-W
FJR, Wing
CO Single Track RR http://advrider.com/forums/showthrea...0#post24875020
CamelBill is offline   Reply With Quote
Old 03-04-2013, 10:36 AM   #7
pdxmotorhead OP
Oddometer: 780
Yes where did that come from ! Normally I wouldn't be in that farkle zone but this pipe has me pissed..
Freeking shop not open today and we are getting the first blue sky break of spring...
Guess I'll have to finish the canisterectomy off correctly,, (PO had someone do it and they re-routed all the hoses in a bizarre fashion.. )
Cheers
Dave
Old 03-04-2013, 10:43 AM   #8
Orangecicle
On a "Quest"
Oddometer: 2,896
It's been "in development" . . . for a year or more. Any solution like this works very well. You just get the shield off of the pipe so that the shield does not act as a heat sink. Carbon fiber works well as long as it does not directly touch something like a header. CF can handle very high temps, so you just need an epoxy that can take it. Many out there can take temps up to 400 degrees, so you can build a heat shield out of the stuff as long as you keep it off the pipe. Mine's been on my bike for some time without any problems at all.
The problem I ran into with making this a production part is that the fitment is different between the 950 and the 990. Also, the screws that attach it to the clutch cover will eventually crush the epoxy. I think my next iteration of the part will be to just make it a bit more straight and flat and ziptie it to the crashbar. But for now, it's in development.
Old 03-04-2013, 09:30 PM   #9
pdxmotorhead OP
Oddometer: 780
Sounds like a job for stainless zip ties.
I've used them for pipe guards before..
To keep from crushing the carbon, just insert a bushing in the carbon.. ?
Cheers
Dave
Old 03-05-2013, 03:17 AM   #10
DirtyADV
DirtyADV's Avatar
Oddometer: 2,322
Is this on a 990? Never had any problem getting the front pipe in and out on the 950 ...well some wiggeling and the correct angle is needed but not that hard.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 03-05-2013, 06:46 AM   #11
Orangecicle
On a "Quest"
Oddometer: 2,896
Riceless has a video on YouTube and he shows how to get the pipe in and out without problems. Just do a search for KTM water pump rebuild. Of course, he has the shield off. :)
Old 03-05-2013, 07:20 AM   #12
pdxmotorhead OP
Oddometer: 780
Yep the shield is definitely the problem, it came out harder than I expected, now the angle of the thing wont pop back past the engine. And those little screws are not coming out without a fight.. Going to the tool store today to buy a socket allen wrench set.. My current ones are ball style and are not going to do the job... Oh well I got everything else buttoned up last night,, get this detail fixed and its time to ride it..
Dave
Old 03-05-2013, 07:33 AM   #13
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,541
This^^^^
My bolts are now broken inside the SS nuts welded to the header.
I could extract them,....but I just sold my fancy carbon heat guard from CJ and said F-it.
Heat guard is not really needed right there IMO
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 03-05-2013, 08:10 AM   #14
Orangecicle
On a "Quest"
Oddometer: 2,896
Originally Posted by Apple Jam View Post
This^^^^
Hmmmm. I've melted non-cotton pants and burned cotton pants WITH the stock heat shield in place. That was why I started down the path of creating a CF shield that didn't touch the pipe.
Times are GMT -7.   It's 10:39 PM.
