Old 03-04-2013, 09:00 AM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 388
Vibration problem 990 ADV
I have a vibration on my 990 ADV that I have narrowed down to something involving the clutch. While riding the bike you can feel the vibration but if I put just a bit of pressure on the clutch lever, not enough to change the RPM, the vibration goes away. I pulled the outer clutch cover and checked the bolts holding the plates on and they are all tight. What should my next move be? Thanks.
skidxr screwed with this post 03-04-2013 at 09:08 AM
skidxr is offline   Reply With Quote
Old 03-04-2013, 10:09 AM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,884
Maybe the central nut is loose.
If you remove the pressure plate, you could check the 32mm nut holding the inner pannier. It has been reported to be loose.
Old 03-04-2013, 02:27 PM   #3
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 388
Well I took it all apart and put it back together. There was nothing noticeably loose to me but the vibrations are gone now. The only thing I changed was when I pulled the clutch plates they rotated so I didn't get them back in the exact same way.. I have the order of the stack the same though.
skidxr screwed with this post 03-04-2013 at 03:28 PM
Old 03-05-2013, 04:22 AM   #4
2upAussie990
Oddometer: 461
Warped clutch plates maybe, if they are not in the same place now means they may just be sitting flat enough to not vibrate
2upAussie990 is offline   Reply With Quote
Times are GMT -7.   It's 04:41 PM.
