03-05-2013, 10:29 AM
#1 |
Renierd
Oddometer: 4
Speedo on 990 Adventure
Hi aal, hope someone has had the same problem, I have intermittent problem on my 990, the speedo occasionally stops working, and the ABS switches off as well, ABS light comes on, then it fixes itself again, and starts working again, and the ABS light goes off as well!!! Please help
03-05-2013, 04:27 PM
#2 |
Oddometer: 119
When this happened to me it was the connector on the side of the ABS pump that came loose. It has a clamping lever that needs to be pushed fully in or the connector can vibrate loose. There is also a connector under the headlight that you can get to and check without taking anything off the bike. Follow the cable up from the ABS sensor and you will find the connector hiding just inside the protective sheath on the loom. Give the sensor cable a wiggle all along it's length to make sure there are no breaks. Also check the fuse connection is crud free and making good contact. The speedo gets it's signal from the front ABS sensor so it should be a bad connection somewhere between the front sensor and ABS unit if it's knocking them both out.
Good luck...
ad astra per alia porci
03-05-2013, 04:47 PM
#3 |
Mmmm....Orange Kool-aid
Oddometer: 1,533
+1
You've probably rubbed the sensor cable to the point where it's broken just above the bottom triple clamp. Exact same symptoms as some of us have had.
Those who dance are considered crazy by those who do not hear the music. I am not the same having seen the moon shine on the other side of the world. - Radmacher 5 Cylinders vs. Moab..........My East Tennessee |
03-06-2013, 08:22 PM
#4 |
Renierd
Oddometer: 4
Speedo
Hey guys thanks for the feedback, have checked the things, and all seems fine, will get a front abs sensor. One strange thing though, when it does not work, and I apply rear or front brakes, it comes on again?
03-06-2013, 09:32 PM
#5 |
Oddometer: 1,533
That's odd...
Front or rear brakes means its probably not brake specific. Hmm...
03-06-2013, 11:26 PM
#6 |
Where fun goes to die....
Oddometer: 3,149
Sounds like a short in the system check your grounds and all connectors first that's the easy part, it goes down hill from there in the search for solutions
DSM8 - A different kind of mean SQL > SELECT finger FROM hand WHERE id=3 WWW.DSM8.whereamiriding.com |
03-07-2013, 02:57 AM
#7 |
Oddometer: 35
Had the same problem. Mine was the ABS switch on the dash was going out and then finally failed. Chased wires and connections for weeks before another inmate pointed me to the switch itself.
