Old 02-11-2015, 05:51 AM   #1
chasesa OP
Oddometer: 16
Bultaco Alpina Forks Issue
Hi gang,
I'm re-building forks on my '75 Bultaco Alpina.
Cannot understand how to tighten the allen bolt holding the lower leg to the inner shock component (lower part of shock tube - name of part escapes me). When the bolt engages the inner part simply turns.
Seems to me there must be a special tool to hold the inner shock from turning. It's a long reach from the top of the tube!
chasesa is offline   Reply With Quote
Old 02-11-2015, 07:10 AM   #2
Rich B
Rich B's Avatar
Oddometer: 785
Talking
The top of the damper tube has like a pin through it to use a special tool to hold it from turning. Sometimes you can find a long screwdriver with a thin blade to reach and hold it from turning. It helps to have the fork fully compressed.
Make sure the threads in the damper rod are clean as well as the threads on the allen bolt that goes into the damper rod.
Sometimes, you get lucky and installing the spring and fork cap provides enough resistance to keep the damper rod from turning.
LIfe is too short to drink bad beer!
Rich B is offline   Reply With Quote
Old 02-11-2015, 08:15 AM   #3
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,280
this is usually the quick and easy way.
flip forks upside down.
get your air impact setup. press down hard on forks to compress spring against damper rod.. this preloads the damper, keep forks compressed then hit it with the rattle gun and zoom they are in. removal is identical.
as mentioned, make sure threads are clean on damper rod and bolt. and you have a nice positive engagement with bolt/rattle gun...
current bikes
stainlesscycle is offline   Reply With Quote
Times are GMT -7.   It's 03:42 PM.
