Old 03-05-2013, 05:27 PM   #1
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 4,811
my first 2-stroke.. 72 RD350 NEED HELP!
Hi,
just bought a 1972 Yamaha RD350.
Is a project 90% done.
NEW PISTONS/RINGS and bunch of things the previous owner did.
What it needs is to connect the carburetor hoses, few cables, seat foam/cover, grips and chain.. and go from there I guess.
My question is.
What oil should I use for the engine?
and what kind of chain this thing uses?
any good place to buy stuff for this old bikes?
Thanks in advance.
cheers, Juanjo
Juanjo_NY is offline   Reply With Quote
Old 03-05-2013, 08:43 PM   #2
RodT
Oddometer: 340
I use Yamalube 2T in my old Yamaha's autolube system and it does a great job. Make sure you bleed the oil pump before you run the bike. If you took the autolube off, than premix the yamalube at 40-1 and you should be fine. I use E-bay for alot of stuff, and also Speed and sport. Bike bandit has NOS yamaha parts , but it is limited. I do not remember what the chain number is but you should be able to look it up on the internet.
Any fool can criticize,condem and complain and most fools do. Ben Franklin
RodT is online now   Reply With Quote
Old 03-05-2013, 08:47 PM   #3
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,850
That's an R5,not an RD. R5 has no reed valves in the intake,no disc brake on front,must be a few other things. If youve never had a 2 stroke it will be a learning experience. Dont run it too lean,ask an expert if your in doubt.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-05-2013, 08:50 PM   #4
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 4,811
thanks,
About the reed valves of the 73, looks like is something the previous owner up-grade.. Personally I have no idea of what that is or what it does.! ;)
"This bike was completely disassembled frame off and redone 5 years ago. It has sat ever since. It now needs a major cleaning. I did put a new battery in it and she still fires right up if you spray fuel in her. Numbers matching 1972 R5 that has been 99% redone with 1973 reed valve jugs. Excellent + condition. All bushings, bearings, seals, piston rings, pistons, tires and tubes, hoses, points, plugs, clamps, etc have all been replaced. The nuts and bolts were switched to stainless in most spots. Even has new grease fittings. I have the tool kit, owners manual, shop manual and key. I also have some extra coils, fuel lines a brand new battery and a spare harness. Everything was repainted or cleaned. It needs a couple of things to finish it up. It needs seat foam and cover, grips and a couple of sticker/emblems and a chain thats pretty much it as far as I remember. It was drained and winterized before storage."
cheers, Juanjo
Old 03-05-2013, 09:02 PM   #5
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 4,811
to be double sure, the Yamalube 2T oil is for the ENGINE, not for the fuel mix right?
For the fuel mix any 2t oil you can find in Autozone will do?
cheers, Juanjo
Old 03-05-2013, 11:44 PM   #6
Tim McKittrick
Oddometer: 1,717
The Yamalube is indeed for the engine- it goes in the mix oil tank and is injected to lube the engine. So yes, its for the engine, and yes its for the fuel mix... the bike is supposed to mix it automatically.
There is also oil in the transmission.
Tim McKittrick is offline   Reply With Quote
Old 03-06-2013, 06:33 AM   #7
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 4,811
haha,
I'm still thinking in 4 stroke bikes.. Ok, I guess when I say ENGINE, I'm referring to the oil in the transmission.
What kind of oil should I use in the transmission!
cheers, Juanjo
Old 03-06-2013, 08:37 AM   #8
Skowinski
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Honestly, that bike looks like a lot of trouble. You'd be better off if you didn't put yourself through the grief and expense of messing with it. PM me your address and I'll have my brother come pick it up before this goes any further. I can get it from him in a few months.
Just trying to help.
"The atoms or elementary particles themselves are not real; they form a world of potentialities or possibilities rather than one of things or facts."
- Werner Heisenburg
Skowinski is offline   Reply With Quote
Old 03-06-2013, 08:38 PM   #9
RodT
Oddometer: 340
You can use a standard 10/30 wt. oil in the transmission
Old 03-06-2013, 08:40 PM   #10
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 4,811
a friend told me to put 75-90 gear oil, which you think is more appropriate?
cheers, Juanjo
Old 03-06-2013, 08:47 PM   #11
RodT
Oddometer: 340
The manual says 10/30 for the transmission. Your clutch also rides in this oil, if you put 75/90 gear oil in it , the clutch won't work right.
Old 03-06-2013, 08:48 PM   #12
tenfiddy
Demotivational P C
Oddometer: 186
You should double check with a manual but I remember putting 30 weight in my RD400 per the specs. Good luck. Looks like a fun bike!
2000 XR650R - Big.. Red... missile toward the next tree/ditch, wahtevar!
1999 KTM 200EXC - ANF Bomber
2002 Super Sherpa - Hers!
"Unlimited foobar until epoch called!"
tenfiddy is offline   Reply With Quote
Old 03-06-2013, 08:49 PM   #13
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 4,811
Thanks,
is synthetic ok for this old bikes?
also, 10-30 motorcycle oil or car oil?
cheers, Juanjo
Old 03-06-2013, 08:51 PM   #14
RodT
Oddometer: 340
Do not use synthetic oil, the clutch will slip. Just use any 10/30 motor oil like castrol.
Old 03-06-2013, 08:55 PM   #15
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 4,811
thanks,
yesterday ordered the chain, a drag bar handlebar and grips.
I'm shopping around for a seat, but the prices on ebay are very high for no so good condition seats, even some seat covers cost almost $100
Any tips on where else to search for a seat for this bike? I want original, no Cafe bs.
cheers, Juanjo
Times are GMT -7.   It's 10:10 PM.
