Old 03-09-2013, 07:16 PM   #1
Williamldarby OP
Oddometer: 12
1973 RT3 yamaha
Hello,
I currently own a 1973 yamaha RT-3 and i am expiriencing alot of vibration in the seat past 50 mph. so bad that after 5 min over 50 mph and my butt has gone completly numb. Is this normal? Enginge sounds fine and the seat has all of the rubber dampers as far as i know.
Best Regards,
-William
Williamldarby is offline   Reply With Quote
Old 03-09-2013, 07:55 PM   #2
MightyChosen1
I wanna be sedated
MightyChosen1's Avatar
Oddometer: 1,357
What kind of tire are you running on the back? I would look at that first. Maybe its out of balance or like a lot of bikes I have owned mounted in the garage and never balanced at all.
I just sold my 73 RT-3. I still have some parts left over including a rare Hooker exhaust and most of the lights.
Formally known as Furious D, I'm getting to old to be furious.
MightyChosen1 is offline   Reply With Quote
Old 03-10-2013, 05:43 AM   #3
ken_the_carp
ken_the_carp's Avatar
Oddometer: 76
Check your engine mounts are tight.
ken_the_carp is offline   Reply With Quote
Old 03-10-2013, 08:14 AM   #4
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
As mentioned above.. look for loose, missing engine mount hardware. They shook like a whore in church when they were new anyway...
Omly the seat? Bars? Footpegs?
Old 03-10-2013, 08:19 AM   #5
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
Its a large-ish old 2 stroke,they vibrate and buzz lots at the best of times.
Possibly a fresh tube of Vagicil can help.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-10-2013, 09:37 AM   #6
Williamldarby OP
Oddometer: 12
Hello
I am currently running a cheng shin but it dose not look like there is any weights on it to balance the rear tire. Bearings are all tight.
Best Regards
-William
Old 03-10-2013, 03:08 PM   #7
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 1,415
what gearing are you running? stock? or geared down?
2006 HD 1200C, 2006 Tri Scrambler, 2001 Duc M900, 2001 Hon XR650L, 1994 HD Heritage, 1989 Hon Hawk GT, 1978 Hon CB750K / sidecar, 1977 Guzzi 850 LeMans, 1976 Hon CB750K, 1965 Hon 305 Dream, 1973 Nort 850 Commando, 1971 Tri Trophy 650, 1970 Hon Trail 90, 1970 Tri Tiger 650, 1973 Hon Z50, 1984 Yam Virago 1000, 1981 Hon Passport 70, 1970 Suz T250, 1971 Yam RT1 360, 1965 Hon CT200
lrutt is online now   Reply With Quote
Old 03-10-2013, 05:14 PM   #8
Williamldarby OP
Oddometer: 12
I am running stock gear I believe it is 16/39 if I remember correctly.
Old 03-11-2013, 06:10 PM   #9
smokin2stroke
smokin2stroke's Avatar
Oddometer: 18
If the vibration was engine related, you should experience the same vibration at the same RPM in a different gear. Could be a crank out of balance, worn crank bearing, or loose engine mounts.
If it's speed related, it could be the tire youre using, say a knobby on the street with big cleates or an out of balance wheel, providing all the bearings and swingarm busings are tight.
If you drive the bike in 3rd of 4th the same RPM, does it vibrate the same?
smokin2stroke is offline   Reply With Quote
Old 03-12-2013, 10:20 PM   #10
Williamldarby OP
Oddometer: 12
The is currently not running. The condenser just went out and should be here on Thursday. I will take it for a ride then and test the rpm in different gears. But as far as I remember it did not vibrate untill over 50 mph. I also just noticed the sproket is loose and I hear this is a common thing for this bike. Would that cause any vibration?
Old 03-13-2013, 06:03 PM   #11
smokin2stroke
Oddometer: 18
You'd probably notice the engine a bit more jerky and snatching because of the slop when you let off the gas and hit it again, or it snatches a little on takeoff. I wouldnt rule out any part I found loose inn the drivetrain making for a weird ride.
If it feels more of a shake in the seat than a hum or buzz, likely its the tire out of balance unless it has some wierd cleat pattern that constanly rippling the tire on the asphault. you can try adding 5lbs to the tire and riding it again and see if the vibration changes. That would rule out the tread.
I'd think if the engine had the vibration, you may notice your hands getting tingly after a long ride at speed or parts on the engine vibrating loose, say stator cover or oil cover screws.
Have you tried jacking up the back of the bike, blocking it up,and running the bike in gear to watch the wheel and chain? If you can get someone on the bike and control it well, they should be able to turn the wheel fast enough to see if it starts hopping, rims bent, or tire is worn funny.
75 S3A-RA, 71 RT1B, 77 CT125, 83 HD 1000 Sporster and other toys. Next up.....a 74 H2B in pieces. It'll be just like putting together a big puzzle.
Old 03-13-2013, 09:52 PM   #12
Williamldarby OP
Oddometer: 12
Well i think i may have found my problem. not 100 percent but i pulled the front sprocket cover off tonight and there sat a 13 tooth sprocket! stock is a 15 tooth sprocket. i have checked the runout in the rear tire and it is only 25 thousands. i still need to balance the rear tire but i think the gearing is my main cause of the vibration because of the increased rpm. Let me know if that sounds correct.
Best Regards
-William
Old 03-14-2013, 05:34 PM   #13
smokin2stroke
Oddometer: 18
The 15 would definitely bring the revs way down. I'd give it a shot. I'm sure the engine would thank you. I'm surprised you got it that fast with a 13. It would have to be wound tight.
Old 03-16-2013, 06:03 PM   #14
Williamldarby OP
Oddometer: 12
Actually I was ridding up to 65 but it was revving pretty high that's why I checked the sprocket. But I am having a small problem around 3500 to 4500 rpm the engine is really jumpy like the felling you get when you ride a modern 125 and you are right on the edge of the powerband.
Times are GMT -7.   It's 06:22 AM.
