Old 03-13-2013, 07:53 AM   #31
KickStart1
Lurking,with intent
KickStart1's Avatar
Location: Marshall,Minnesota Scandinavian Prairie Ghetto :)
Oddometer: 224
Rd 350
Go to Walmart get some Castrol 10W30 or 10W40.I would get some plug's for it as the Coil's are notoriously weak and it's better to get it to fire on new plug's.If you could take some Pic's, with good lighting and get a shot of the area around where the carb meet's the head.Post them here and that should tell (if) you have an R5 or an RD as it's just a guess, right now.There is not a lot of difference Motor wise in the two,other than the Reed Valve and extra Intake Port's that the RD has and R5 did not.The RD has 7 ports and the R5 has 5 port's.But both still go like STINK,that is the truth
Heavily Medicated,for your protection
and sometimes,released out in to the
Real World for a ride !
KickStart1 is offline   Reply With Quote
Old 03-13-2013, 08:09 AM   #32
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 5,046
there you go..
already have this oil, is that ok the R5 trany?
cheers, Juanjo
Juanjo_NY is online now   Reply With Quote
Old 03-13-2013, 10:24 AM   #33
KickStart1
Lurking,with intent
KickStart1's Avatar
Oddometer: 224
Rd 350
Yes, you do have an RD350 as I,can see the square rubber,ReedValve intake's. This bike appear's to be in very good shape, as no one has dipped them in real harsh Carb cleaner.Those little rubber boot's on top of the carb's be very careful not to get any carb cleaner etc on them.They will just melt and fall apart DAMHK. I would use the Castrol 10W40 should not be problem as factory was 10W30 and the 40W better in high temp's.I hope this all go's well for you in this RD project,you will like it
Old 03-13-2013, 10:33 AM   #34
KickStart1
Lurking,with intent
KickStart1's Avatar
Oddometer: 224
Also it (appear's) you have,1975 RD350 High top carb's and can not remember,what the difference or advantage was with them as that was the last year of the aircooled RD 350.
Old 03-13-2013, 10:39 AM   #35
MacNoob
MacNoob's Avatar
Oddometer: 1,674
Transmission oil: Oil that does NOT SAY "Energy Conserving" in the round API donut symbol on the label will be fine.
"Energy Conserving" oils contain additives that can cause clutch slip.
"Persuade thyself that imperfection and inconvenience are the natural lot of mortals, and there will be no room for discontent, neither for despair."
MacNoob is online now   Reply With Quote
Old 03-13-2013, 11:39 AM   #36
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 5,046
thanks again,
the guy who did all the stuff to this bike was an older DR fan, beside of whatever he did with the piston/head, he change every single bolt for stainless steel. Even the bolts under the seat pan!
ok, to finish with the oil questions.
is this good for the transmission?
cheers, Juanjo
Old 03-13-2013, 11:42 AM   #37
MacNoob
MacNoob's Avatar
Oddometer: 1,674
Should be just fine - it doesn't say "Energy Conserving" in the round API symbol.
Old 03-13-2013, 11:42 AM   #38
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 5,046
cheers, Juanjo
Old 03-13-2013, 12:42 PM   #39
Shocktower
Shocktower's Avatar
Oddometer: 9,485
Welcome to the smokey room , where there is a smoking sign
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 03-13-2013, 05:50 PM   #40
smokin2stroke
smokin2stroke's Avatar
Oddometer: 18
I'll be honest with ya. the two bikes I have called for motor oil in the trannies and I changed them to gear oil and didnt notice any difference in the cold vs warm weather. Gear oil has the consistency of 30w without all the additives they put in motor oil today, which helps a wet clutch keep from slipping. Just my .02.
75 S3A-RA, 71 RT1B, 77 CT125, 83 HD 1000 Sporster and other toys. Next up.....a 74 H2B in pieces. It'll be just like putting together a big puzzle.
smokin2stroke is offline   Reply With Quote
Old 03-14-2013, 01:23 AM   #41
Shocktower
Shocktower's Avatar
Oddometer: 9,485
That what I have been told from another site which is all 2 strokes
'08 KTM 530 EXC
79 RD 400 Daytona
Old 03-14-2013, 02:05 AM   #42
PeterW
Oddometer: 2,753
One thing you need to remember, particularly first ride.
Those things use a LOT of fuel - so fill up every chance you get until you get a feel for it.
Pete
PeterW is offline   Reply With Quote
Old 03-14-2013, 12:50 PM   #43
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 5,046
ok, I think I'm ready to put this thing in the curb.
I changed the oil in the trany, fill the tank with 2-t oil, put a tea spoon of oil in each cylinder, the spark plugs are NEW.
Filled the tank with 91 octane fuel, and kick the hekk out of this thing and nothing..
Choke, no choke, with and without throttle.. the best I got was a puff.
Also there is gasoline coming out from the middle of the bottom of the engine.
I'm not spending a dime more on this damn thing.. anyone care for a R5 with DR350 heads! $1700 with title, manual, already got the seat and chain.
ALso new drag bar and on the way 4 new spark plugs and 16oz of redline 2t oil.
cheers, Juanjo
Juanjo_NY screwed with this post 03-14-2013 at 01:02 PM
Old 03-14-2013, 04:50 PM   #44
RodT
Oddometer: 350
Big mistake putting straight oil in the plug hole, that's a sure way to oil foul a plug. Is your battery fully charged? this bike requires a fully charged battery or it won't run. Also check the points and maybe file the a little. the R5 had weak coils and everything had to be right. I had to change plugs every 400 miles or it wouldn't run very good.
Any fool can criticize,condem and complain and most fools do. Ben Franklin
RodT is offline   Reply With Quote
Old 03-14-2013, 05:26 PM   #45
Juanjo_NY OP
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 5,046
the thing is that I didn't grow up with 2-stroke bikes, I had the curiosity, but definitely not the patient!
I put the battery to charge overnight.. just got pup pup pup pup!, much better than just PUFF!
Fingers Xed that tomorrow with a fully charged battery this thing fire up..
Thanks again for all the help! if the bike start I'll make a video to share it here..
cheers, Juanjo
Times are GMT -7.   It's 05:58 PM.
